Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
1 qt oil every 1000 miles
2005 harley dulce have no oil leak and pipe are clean where is a qt. of oil go every 1000 miles
Kev, check you have the right level on your dip stick, oil must be on upper mark when donk cold.also ensure you are running the correct oil weight for your donk.
engine may be running hot; which means one way oil can go missing is its being burnt.
also check your primary drive,clutch oil level ,not sure as i have 80cube evo, but you may find your oil in there due to bad oil seal internally. im no expert but these may be of help.
regards george
Posted on May 14, 2009
My infiniti is consuming oil at least 1 qt, i have to refill every week. what can it be somepeople have telling me the PVC valvue, the oil pressure o rings, bad pistons and people telling me that they...
1 a simple compression test will tell you if the rings and valves are bad. thats where you start.. 2 it could be an oil leak under the vehicle , you will see a black spot. do this first it only takes a look whee you park it on dry clean pavement or place a clean piece of cardboard under it.
Mar 02, 2015 | 2005 Infiniti G35
Oil in intake
Hi Anonymous, no your breather system just got a little over taxed because of the heavy load and the mountains, you will be fine have nice day.
Jul 07, 2013 | Harley Davidson FLHTCUI Electra Glide...
WHAT IS THE NORMAL OIL CONSUMPTION FOR A STOCK 88 CU IN? I CHANGED THE OIL(AMS SYNTHETIC), RIDIN ABOUT 1000 MILES AND IT IS A QUART AND A HALF LOW. NO OIL LEAKS ANYWHERE. IT HAS A STAGE 1 BREATHER KIT...
oil comsumption varies depending on how hard and under what circumstances you ride, but you are losing more then normal.
my 06 Roadking only uses about 1/4 Qt. after 2500 miles of hard riding and I have the VO2 high flow breather from V&H
Sep 15, 2011 | 2006 Harley Davidson FLHX Street Glide
Burning 1 qt oil 2007 grand caravan sxt per 1000 miles. changed pcv vale still happenung
Is it really burning it, or just losing it? If you have blue smoke coming out your tail pipe, and oily black spark plugs, there's really not a whole lot you can do about it short of a rebuild of your engine. It really sounds like a rear main seal leak, or a faulty oil filter.
May 07, 2011 | 2007 Dodge Grand Caravan SXT Minivan
'01 Durango R/T slight oil consumption. 1/4 - 1/2 Qt a month. about every 500-1000miles. Is this normal is signs that gaskets need replaced. If so what gaskets?
Anything over 1 quart in 1000 miles might be considered excessive. It probably is not gaskets unless there is a leak. If there is a leak there might be a puddle of oil on the ground where you park it. If there is a puddle or drips of oil look at valve cover gaskets, oil pan gaskets, crankshaft seals , etc.
Oct 27, 2009 | 2000 Dodge Durango
What type of motor oil used in 1994 harley davidson 883
harley recomends that you use their oil but i would be carefull because it is a cynthetic now if you were using regular oil what that will do is clean all the old build up out of the motor this can be bad because after time there are pin hole leaks that occure but the build up stops it from leaking but if you use cynthetic you cant go back to regular oil it will gum up on you and ruen your motor so you got to find out what has been put in it. but use a 10-30
Jun 05, 2009 | 1993 Harley Davidson XLH Sportster 883...
What kind of oil to us my car uses a qt every 600 to 1000 miles in between oil change change oil every 3000 miles it don't smoke or leak
5w30 is comon, sounds like its got a few km`s on it , chech tailpipe for oil deposits, it may burn but you dont see it that easy
Apr 25, 2009 | 1999 Saturn SL
What is the tire size on a 99- prizm. i bought this prizm with 62k, i had it about a year and a half, it uses about 1-qt. oil every 1000 miles theres no sign of leakage ( engine is clean ), and it does not...
call a tire shop or the dealer for the exact tire size. The oil has to be going somewhere. If it's not leaking it's burning. check the plugs for oil, ck for mixture of anti freeze & oil mixing together, if it runs hot/ overheats it may be a head gasket. Or a crank or cam seal that's leaking only while driving. Have it checked, the system is supposed to be sealed.
Aug 02, 2017 | 1999 Chevrolet Prizm
2007 street glide in need of help(dealers say no problem)
What's your miles between changes?1500 to 2500 miles 1 qt. aint bad.Are you injected?do computer thing for ign/timing and air/fuel settings.If you're carb do jet cleaning and check float bowl setting.Check that float isn't leaking[full of fuel].Check plugs for good color and look for black residue in rear pipe,signs of bad air/fuel mixture and bad burning plug[coil voltage].If your carb doesn't have float check setting of rod that operates the fuel diaphragm.Do computer check for ign timing.Yea, if the plugs are oil fouled then forget what I said bout oil consumption.Baby it till winter and get top end done.Don't worry,2007 is too new for a top end.General tune-up should fix you up.New coils maybe.
Mar 21, 2009 | 2008 Harley Davidson FLHX Street Glide
Lands Phones Logo
138 people viewed this question
Top Harley Davidson Lands Phones Experts
David Payne
David Payne
WTF Chuck.....
WTF Chuck.....
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
