Question about Gateway M320X Notebook
My laptop will, once in a while (every couple months), have3 "issues" with its brightness/contrast. If I leave the brightness alone, it will turn most of the screen red. If I lighten the brightness AND the contrast, it will remove most of the problem. Usually, I have to let it sit for a few days, then it fixes itself. Is there anything I need to replace?
  • Gateway Master
  • 32,281 Answers
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on May 14, 2009
How to adjust contrast on dell 610
You can only adjust brightness. There is no contrast control.
Jan 17, 2014 | Dell Latitude D610 Laptop Computer -...
Unable to reduce brightness windows7 ultimate hp1670
laptop ot desktop monitor ?
Adjust your monitor's brightness and contrast
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.)
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor.
Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
Brightness and contrast symbols
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Laptop display. Laptop displays don't have brightness or contrast buttons on the front.
For a majority of laptops, there isn't a control for setting the contrast.
However, you can set the brightness of many laptops by pressing and holding the Fn key, and then pressing a function key to decrease brightness ( ) or increase brightness ( ).
http://windows.microsoft.com/en-US/windows7/Calibrate-your-display#
When using Display Color Calibration on a laptop, set the display to the maximum brightness setting.
Adjusting brightness automatically using adaptive brightness
Adaptive brightness is a feature in Windows that uses a light sensor to automatically adjust the display brightness to match the lighting conditions in your computer's surroundings.
To use adaptive brightness, you must have light sensors installed and enabled on your computer.
To determine if your laptop or computer monitor supports adaptive brightness, look for the Enable adaptive brightness setting in Power Options (mentioned in the following procedure) or check the information that came with your computer.
To turn adaptive brightness on or off
Open Power Options by clicking the Start button , clicking Control Panel, clicking System and Security, and then clicking Power Options.
Under any plan, click Change plan settings.
Click Change advanced power settings.
In the list, expand Display, and then expand Enable adaptive brightness.
To turn adaptive brightness on or off when your computer is running on battery power, click On battery, and then, in the list, click On or Off.
To turn adaptive brightness on or off when your computer is plugged into an outlet, click Plugged in, and then, in the list, click On or Off.
Click Apply. Click OK.
hope this helps
Jul 26, 2012 | HP...
I in mi aoc tv lcd l22w89 the option picture blocking, contrast and brightness to 100% and I can not change
In the menu system there is a reset (I believe it's all reset, or reset all...something like that) which should fix the issue.If not, leave the TV unplugged for 4 hours and plug it back in then turn it on.
Nov 26, 2011 | AOC L22W898 22 in. LCD TV
I have installed recently WIN XP SP3 on my samsung netbook N100. I observed the LCD gives sufficient brightness and Contrast when charger is on while with battery backup brightness & contrast...
I believe there's a setting in your control panel > power options to change the settings of the brightness and contrast depending on the source of power. it is set there to change the brightness and contrast of the LCD on how it will change once you remove the ac adapter from the laptop.
Hope this helps!
Sep 21, 2011 | Computers & Internet
Since yesterday, the picture on my laptop has been distorted and I can't figure it out. Looks like the contrast is off. Can't find how to adjust it and I tried to calibrate without any luck. I turned it...
Hi. Restart your system and press F2 key when you see the Dell Screen. You can adjust the Screen brightness or contrast from there. See if that'll help!!!
^_^
May 06, 2010 | Dell Studio 15 Laptop
Need help to adjust the colour, contrast and brightness on my CMV
install the monitor driver, you can down load the driver to your monitor manufacturer..
update the video card driver and install the video card application software...the video card application software have setting and configuration options
Mar 16, 2009 | E-Machines eMachines Monitor E15T4
Toshiba Sat A75-SP231, Display too bright no contrast
There is a brightness setting on your keyboard on ours it is Fn F6 to turn down the brightness. Just look for a sille "sun" symbol with a downward triangle symbalizing down. Try this and get back to me if it does not fix the problem we can try something else
Jan 13, 2009 | Computers & Internet
Loewe articos hd tv rear projection. contrast too shiny
Try lowering Brightness first.Not contrast leave it up middle range.
Dec 26, 2008 | Loewe Articos 55 55" Rear Projection...
FOGGY-HAZY PICTURE
The contrast setting should always be more than the brightness setting, it's purely common sense to have the black levels dark and the white levels light. I advise your brightness to be 40, and your contrast to be set to 60.
You shouldn't alter the hue, as most manufacturers would have spent significant time balancing this anyway, so set this to 50 and leave it alone.
The saturation shouldn't be altered too much, the best bet is to set this to 55 and let it be. Also, the colour temperature shouldn't be changed atall, so set this to the default setting and leave it alone.
As for the sharpness setting, this should definitely be set quite low. I advise setting the sharpness to 40, and the reason for this is most people assume that the higher the sharpness the better quality and detail, and they're completely wrong.
If you do what I said, you should end up with a crisp, smooth and colourful picture.
Nov 29, 2008 | Televison & Video
Yesterday, I bought a Sanyo 26" flat screen TV Model DP26648. The color is poor and I have tried to cursor up and down in the color, tint, contrast, brightness, etc. I don't seem to be able to seem...
SET CONTRAST AT ABOUT 75 PER CENT COLOUR 50 PER CENT BRIGHTNESS 40 PERCENT LEAVE TINT ALONE.
THIS IS A ROUGH GUIDE BUT I HOPE IT HELPS.FOR BETTER RESULTS USE A DVD LIKE RATATOUILLE AND USE THE SET UP MENU.
CABLE GUY.
May 21, 2008 | Televison & Video
Gateway M320X Notebook Logo
130 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
