I would drain the oil and gas or whatever is in it. I would also drain the 2 cycle mix from the gas tank and start with a fresh gas and oil mix and fresh bar oil. The mix for the Poulan Wildthing is a 40:1 mix.
You are definitely going to smell gas when using any chain saw.
Engine oil goes in the gearbox/transmission. Two stroke oil (also know as pre-mix) is mixed with the gas and oil in a separate gas can (to thoroughly mix the pre-mix and gasoline) and then the mix is poured into the fuel tank.
Mix the oil and gas together first. Or you can add some gas into tank, then add some oil, then add more gas, then bit more oil ... so oil-gas mixture is uniform.
Regular unleaded gas mixed with 2 cycle oil. (You need to check your model for mixture ratio but 30:1 (thirty parts gas to one part oil mix) is usually a good place to start) You can find mixing instructions on the back of the 2 cycle oil container
go to your hardware store and ask for some 2 cycle 50:1 oil, mix that with a gallon of gas and you're good to go. Before you mix, make sure that you read the oil container for it's recommendations! You can purchase a small container of oil that is all measured for 1 gallon of gas
If this is a 4 cycle mower (seperate places for gas and oil) and you are using a oil and gas mix as I am reading from your post that is your problem. When you use a gas&oil mix in a 4 cycle you get smoke and if fouls your spark plug. Also be more specific where the oil and gas mixed is leaking from. I SUGGEST THAT YOU DRAIN OUT THE GAS&OIL MIX AND CLEAN THE SPARK PLUG OR REPLACE AND FILL WITH STRAIGHT GAS AND SEE HOW IT RUNS.
The Left knob needs chain oil. Available in most hardware stores. The right is gas mixed with 2 stroke motor oil. Usually a 50:1 mix. Ie. 50 parts gas to 1 part oil. 2 stroke oil comes with a built in measuring tool and directions printed on the bottle.
