Question about Toshiba 32AF43 32" TV
No picture (black screen)
The green color was missing and the next day there is no picture when tv is turned on (sound is ok). What's the possible problem? Is it worth to have a service call? Thanks!
    An expert who has answered 500 questions.
  • 556 Answers
Re: no picture (black screen)
you need tech. help.
Posted on Oct 15, 2007
0 characters
3 Points
Sound ok but no picture
see the b. diagram and test the power supply ;transistor, fuse, filter, switch, c.breaker rectifier,IC regulator voltage.
measure the horizontal output =125vdc
all other circuit:12vdc
Oct 17, 2012 | JVC Standard (CRT) Televisions
I gotta a green screen
It is possible that you have a shorted green CRT, you can remove the front speaker cover, and you will fine a focus block, and if you turn down the green screen voltage, very slowly, the green should turn down. if not then the gun (CRT) will have to be replace, If it does turn down, then go into the menu and turn the color are the way down and that should give you a black and white picture. If it is not black and white. adjust the red, blue, and green screen voltages until you receive a good black and white picture. Turn slowly they are touchy, and if turn to high, you will get retrace lines and the TV will shut down.
Nov 14, 2010 | Toshiba 61A60 TV
Sony trinitron wega kv-36fs200 36' tv is missing green color
sounds like a major fault with the line output transformer/power board. if no green on screen, tube is on it's last legs. Advise to scrap, not to repair, cost in excess of £200
Oct 23, 2009 | Standard (CRT) Televisions
Green tint I can't seem to fix
Hopefully someone on here has a manual and can tell you exactly where the tint controls are. Also need to try adjusting the color level, turn it clear down so you have a black and white picture.
Is the picture still green over the screen with the color control
set clear down to black and white? If it does, you might
have an issue with the green gun going out or problem in the
circuitry to it.
By the way, the best way to adjust the picture settings on a
tv are to first turn the color control clear down, then adjust
brightness and contrast for best black and white picture, then
bring up the color level to where it should be and adjust the
tint for best red/green ratio.
May 20, 2008 | Mitsubishi CS-27205 TV
Click click repeatedly faded then red blinking light
Go to the video menu and turn the color control to minimum. Determine if you have a black & white picture or is it green & white. If the picture is greenish, you have a problem in the screen circuit or possibly a bad picture tube. If the black & white is ok then I would suspect a problem in the chroma circuit such as a bad video jungle IC or a crystal. However, because your set had a red blinking issue prior to your existing condition I would lean towards the picture tube as the source or your troubles. You can try a simple test to determine if you have an intermittant short . Take the back off the set, and with the insulated end of your screw driver, very very lightly tap on the neck of the picture tube near the socket. If you see green flashes or hear loud snaps in conjunction with your taps or the green tint goes away, chances are the tube is the cause. If so, you might try installing an isolation transformer on the picture tube. Good luck
Nov 29, 2007 | Toshiba 36A61 36" TV
Green screen
No! that is difinitely not an easy fix. there is something wrong with the picture tube. it is the part that emits light and colors. you need to bring that to a local repair shop.
hope this helps.
Nov 19, 2007 | Standard (CRT) Televisions
Red picture
sounds like u may have a picture tube problem/CRT, would be high price repair
Oct 27, 2007 | Zenith A25B33W 25" TV
Picture problems
CRT green gun is not working properly , maybe dry soldered or no green drive signal. Pink and red colour is due to missing of green colour.
Sep 09, 2007 | Sanyo DS27820 27" TV
Television has audio but a black screen
Bad technicians always say picture tube problem when the TV has black screen with sound. This a false statement and in some cases techniciacns use this to scare the owner or the charge a hefty amount. The truth is that picture tube outlast most component in the TV. If it will fail, it is gradual like the colors will fade or one or several color will be missing. This condition is the degration of the filament in the gun (CRT tv has three -Red, green , blue) I started to repair TV in the early 80's and only in one occasion that the Tube fail and it is a crack in the neck. For black screen with sound, the most common cause is the HV supply problem / Horizontal section. This can be caused by many things, like flyback transformer failure, horizontal outout transistor, horizontal drive, etc. For the cost-depends on where you are, in some countries labor is dirt cheap, in other ountries the parts are expensive.
May 22, 2007 | Mitsubishi CS-40505 TV
RCA MM36100 color problem
sounds like you have a deguassing problem with your TV .. have the repair person bring out a deguassing coil and see if thsat helps.. This will only be a temp repair as you will have to have the problem that caused this to be fixed. good Luck
Aug 12, 2006 | RCA MM36100 36" TV
Toshiba 32AF43 32" TV Logo
57 people viewed this question
Top Toshiba Standard (CRT) Televisions Experts
Jaime Hernandez
Are you a Toshiba Standard (CRT) Television Expert? Answer questions, earn points and help others
