Question about Dell A960 All-In-One InkJet Printer
Copying My printer works fine when it comes to printing, scanning and faxing, but when I go to copy, it scans my item, and the paper feeds halfway down the backside paper tray. I know there is no jam or anything, because all of the other functions work just fine. Even Dell support couldn't help me, the service tech got frustrated and hung up on me! In fact - his name was Omer. Anyways, does anybody know what the solution could be?
  • ottjl Jan 24, 2008
    Having the same problem. Hopefully if I post this it will get bumped up and someone can help
I just had this exact same problem. It would print fine from the computer, but once I tried to copy or receive faxes, all that would happen was that the paper would get pulled down a little bit into the printer, but then it would stop and then no printing would actually occur.
Just now I thought to unplug the plug from the power strip and plug it back in. Worked like a charm. I have no idea why it works, but I can copy now. Hope this helps someone!
Posted on Apr 09, 2008
  • 2,351 Answers
5650c not scanned. making paper jam. rollers replaced. making big noise.document page stop halfway through
PDF]fi-5650C Image Scanner Operator's Guide P3PC ... - Fujitsu
FujitsuThank you for purchasing the fi-5650C fi-5650C duplex color scanner product. ... 6.1 Removing jammed documents ..... store where you purchased the scanner or an authorized FUJITSU Image Scanner service provider to make repairs to this .... It is adjusted to the width of the paper in order not to scanned skewed pages. 5.
Okidata User's Guide OKIFAX 5650 Error sure a new drum is available, and replace the drum ... to be faxed or scanned hasjammed in the scanner. Refer to the "Problem Solving, Clearing aTroubleshooting - Oki Printing Solutions in New Electric Industry... MB491 ES4191. FAQ: Paper Jam Clearing MB451 MB471 MB491 ES4191 ...MC361 MC362 MC561 MC562 How to setup scan to email. Open the attached ..... Can I disable Colour Copying and make only B+W Copying available? No, it not possible to disable Color Mode when copying via the Scanner Operator Panel.
Jan 29, 2016 | Office Equipment & Supplies
We have a Canon Image Class MF5900. When we put items through the feeder on the top of the machine to feed through for either copying or scanning we get the copies/scans but they also have line through...
Yes, this machine has what the call a scanning glass.Its the small thin glass where the paper goes down through the doc feed.its on this glass. A real close visual or take a clean piece of paper. Wad it up a and clean glass with that paper. It works. But if you don't have a line when you print or from the platin.(glass,main).its on that reader glass.
Feb 13, 2015 | Canon Office Equipment & Supplies
Fax on Lexmark 901 pro not feeding
Does it also jam when you're just copying or scanning? Try to check if the scanner is closed all the way down. The cover needs to be closed all the way down for the paper to flow properly from the ADF to the exit tray.
Oct 27, 2012 | Lexmark Pinnacle Pro901
Blue Color On Copies
Check your settings for copying through your printer software.You might have accidentally messed up some copy settings there (Contrast, etc.)
Rollers do not have anything to do with this because your regular prints and copy prints are fed through the same roller.
Try removing your printer from Device Manager. Completely remove your printer software and reinstall all this stuff like you're installing a brand new printer. There is a 90% chance that your printer will be find after this.
Hope that helps.
Feb 19, 2010 | HP Officejet K60xi-Printer/Fax/Copy/Scan -...
Double sided copying
here is the manual p4 and p16 discuss the topic:
Duplex printing 1
The supplied printer driver supports duplex printing.
Guidelines for printing on both sides of the paper 1
�� If the paper is thin, it may wrinkle.
�� If paper is curled, turn over the stack, straighten it and then put it back in the paper tray or the Manual Feed
�� If the paper is not feeding properly, it may be curled. Remove the paper, straighten it and turn over the
�� When you use the manual duplex function, it is possible that there may be paper jams or poor print quality.
If there is a paper jam, see Paper jams in the User’s Guide. If you have a print quality problem, see
Improving the print quality in the User’s Guide.
Manual duplex printing 1
The machine prints all the even-numbered pages on one side of the paper first. Then, the Windows® driver
instructs you (with a pop-up message) to reinsert the paper. Before reinserting the paper, straighten it well,
or you may get a paper jam. Very thin or thick paper is not recommended.
Simultaneous scanning, printing and faxing 1
Your machine can print from your computer while sending or receiving a fax in memory, or while scanning a
document into the computer. Fax sending will not be stopped during PC printing. However, when the machine
is copying or receiving a fax on paper, it pauses the PC printing operation, and then continues printing when
copying or fax receiving has finished.
�� Manual Duplex
Check Manual Duplex. In this mode, the machine prints all the even numbered pages first. Then the
printer driver stops and shows the instructions required to re-install the paper. When you click OK the odd
numbered pages are printed. There are six types of manual duplex binding directions available for each
�� Booklet Printing
When you want to print a booklet, use this function. To make the booklet, fold the printed pages down the
�� Binding Offset
If you check the Binding Offset option, you can also specify the offset for binding in inches or millimeters
May 14, 2009 | Brother MFC-7440N Laser Printer
There are verticle lines when faxing, copying, and scanning.
This print defect can be caused by a foreign object or substance on the outside of the scanner assembly, usually located on the plastic cover that the paper passes over.
Feb 04, 2009 | Lexmark X7170 All-In-One InkJet Printer
Lexmark x7550 Printer, Scanner, Fax - Clicking Noise Question
top feeder for the scanner (on my x6570) had a loose piece of rubber stuck between the feed wheels. The rubber is part of the guiding mechanism that guides the paper to the feed wheels. Remove rubber strip and reattach it where it belongs.
Feb 19, 2008 | Office Equipment & Supplies
Dell A960 All-In-One InkJet Printer Logo
62 people viewed this question
Top Dell Office Equipment & Supplies Experts
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
