Question about Gateway MD7820U Notebook
Webcam won't work with AIM My camera works on its own,but won't work with messenger programs for video conferencing.
How can i use de webcam.
Webcams are used for video conferencing or video chat in those applications which need the webcam hardware. Look for programs installed in your PC/laptop. If it has a webcam, it would have a program. Alternatively chat client applications like Yahoo messenger/msn messenger/gtalk have the ability to enable webcam from their interface. You just have to select start my webcam.
Jul 18, 2011 | Computers & Internet
How do download a splitcam
There are many splitcam programs out there. I recommend giving Fit splitcam a chance.
Fit splitcam is a multi-camera solution that allows you to easily multiply your webcam video in any conferencing software such as Skype, AOL, AIM, ICQ, Yahoo, MSN etc.
Usually, if you have a webcam connected to your computer, you cannot use it in more than one application at the same time, and there is no standard Windows options to make this possible.
With Splitcam (and other multi-cam software) you can use several different video conferencing applications at the same time all through one input source such as your webcam.
Look here to see a fuller description of this popular SplitCam application: http://download.cnet.com/SplitCam/3000-2348_4-10500269.html
Good luck and thanks for using FixYa.
Apr 12, 2011 | Computers & Internet
I have just bought a logitech webcem c250.i need to know how to connect in AIM etc
install the drivers, then plug in the webcam (in that order). in programs such as Skype, AIM, etc, that have video conferencing options there will usually be an option to choose the video source, sinple choose the C250.
Feb 07, 2010 | Logitech QuickCam Communicate STX Personal...
How to use webcam using AIM?
Normal 0 See section D. AIM AOL Messenger in the info below to setup the Audio & Video.
Also send this to your family and friends so they have their computer setup properly.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
D. AIM (AOL) Messenger
http://dashboard.aim.com/aim
  1. On the VIM sign-in window click on Edit.
  2. Then click on Settings Enhanced IM.
  3. Next click on Enhanced IM.
  4. Then click on Audio Video.
  5. The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
The Audi Video drop downs are
Microphone Speaker
Camera The audio and camera should function now.
Additional info to use with VIM settings.
Adjust Your Audio and Video Settings: In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly. Follow the on-screen prompts.
Notes:
  • The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly. Follow the on-screen prompts.
  • images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends. Hope this helps. Bud
May 13, 2009 | Logitech QuickCam Communicate STX Personal...
Webcam and AIM on Aol
Also send this to your family and friends so they have there computer setup properly.
Go to this site http://dashboard.aim.com/aim and Launch AIM AOL Messenger.
Microphone Speaker
Notes:
Mar 24, 2009 | Logitech QuickCam Communicate STX Personal...
Blue screen using AOL 9.1
D. AIM (AOL) Messenger http://dashboard.aim.com/aim
Microphone Speaker
Notes:
Feb 25, 2009 | Micro Innovations IC445C Webcam
Unable to chat on AIm with camera that is already set up
Which ever Messenger or Skype you are using has to be setup in order to function. Same way wih AIM. Normal 0 I'll assume that you are using YAHOO MESSENGER and walk you through the setup. All Messengers and Skype have an Audio & Video setup in them so the camera and microphone work properly with their program.
Bring up Yahoo Messenger and on the top left click on MESSENGER.
Then click on "Messenger Preferences."
Next in Category click on "CALLIN & DEVICES."
When that comes up check and check to see that Microphone is set to your audio card.
Next insure that the speakers are set to you audio card.
Then go to "Test Audio"
In Blue "Open the call setup Assistant"
When the window opens follow the instructions. When finished your camera audio should function properly.
Also you need to go to the Video setup and do the same so it will broadcast the pictures.
Jan 05, 2009 | Microsoft LifeCam VX-6000 Webcam
Help me
You need a messenger/video conferencing program. MSN, Yahoo and Skype all have video conversation capabilities
Oct 17, 2008 | Acer Aspire 5050-3242 Notebook
Logitech to Mac
I had a search and found these Q&A's, so see if these can sort out your problem. Q. Can I talk/see to Windows users? A. Yes, there are video conferencing standards in existence, and if these are adhered to and implemented properly it should mean that Mac applications could connect to Windows applications - or even dedicated hardware solutions. However, at the moment, the simplest way is to use iChat on the Mac, and AIM on the Windows system. The results are nowhere near as good as an iChat to iChat link, but it works. Also, consider iVisit, Yahoo Messenger, SquidCam or ohPhoneX. Q. Can I use Virtual PC on the Mac to use MSN Messenger, and so talk to Windows users that way? A. In theory it might work, in practice I've not got it to work using Virtual PC 7 and a USB Logitech webcam. (Virtual PC will definitely NOT support the FireWire iSight camera). The USB camera required drivers to work on the Virtual PC, and installing them caused my iMac G5 to crash. Even if it did work, Virtual PC is NOT fast at this kind of thing and would probably not work very well at all with video conferencing. If you really need MSN Messenger to work quickly with video, it's almost better picking up a cheap PC.
Feb 07, 2007 | Logitech QuickCam Express Web Camera
Open Questions:
Gateway MD7820U Notebook Logo
88 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
