Question about Logitech 9313960403 Mouse
Mouse Is Recongnized but wont Move
Hey, My Logitech Invisibble Optic mouse used to work until one day I connected to my other computer and although it recongnized the mouse, when I moved it there would be no movement on the computer. Ive tried it on other computers and the same problem occured. The computer doesnt freeze, the only thing that happens is that the pointer on the screen wont move. Can any one please help me? Thank You
  • obesechicken May 16, 2009
    I have the same problem
    This style mouse doesn't have a reconnect button on the usb port, but it does have a reset one under the mouse. I've clicked this and it still does not work. The software downloads when I switch it to a new computer or a new usb port, the computer just doesn't recognize when I move the mouse. The lights are all on on the mouse. The computer recognizes the USB. So I think maybe the transmitter on the mouse or the reciever on the usb is broken. Any help?
  • 433 Answers
On the bottom of the mouse is a little tiny button that say: connect or reconnect. Place the mouse close to the transmitter dongle (the do hicky comes out of a USB) and look for that button on the transmitter and the mouse to reconnect the signal.
(batteries are good ?)
Posted on May 14, 2009
Computer does not respond to mouse. Move from pad
Do you mean you might used it on you lap rather than the desk and have changed the angle of the mouse? It will be the lazer, (if changing the angle of the mouse works). Disruptions occur with the lazer, hey they don't wear like a ball mouse does. You can have it repaired, just have to decide if it is cheaper or easier to just replace it. (Tip, don't leave it in direct sunlight when you are away from the computer. It shortens the life of a lazer mouse).
Nov 25, 2009 | Logitech Cordless Mouse
My mouse cursor wont move and the buttons won't click.
Try restarting your computer with your logitech mouse plugged. If you said you have successfully installed, the system will automatically detect your mouse.
Jul 19, 2009 | Logitech V450 Nano Cordless Laser Mouse
How do I install/begin using wireless mouse? It worked before then batteries ran out and I can't remember if I need a disc to re-install.
Most Logitech wireless mouse are just Plug-n-Play and it does not require any driver installation. All you have to do is to plug the wireless dongle to the computer and connect the mouse. Here's what you need to do:
1. Make sure that the batteries are fresh or fully charged.
2. Turn ON the mouse using the switch button.
3. Locate the connect button on the dongle (receiver) and then press it once.
4. Hold down the connect button underneath the mouse for 5 secs. and then release it. And the mouse should work.
If the mouse is not responding, then hold down the connect button on the dongle and on the mouse at the same time for 5 secs. and then release them both. Move the mouse around.
Hope this helps and have a great day!
Jul 17, 2009 | Logitech Cordless Mouse
Logitech v220 cordless mouse - worked fine for 6 mths - recently changed battery. worked fine. today, would not move cursor when on a white / light surface (although it has previously just fine). It...
Most opticals do not track on smooth white surfaces. It needs textures or color. Try pressing the "CONNECT" button on the bottom of the mouse and on the remote sensor.
Jun 17, 2009 | Logitech Cordless Mouse
Wireless Optic Logitech mouse performace
I had the exact same problem with my original Logitech wireless mouse that came with a wireless keyboard. I eventually figured that the button component inside the mouse wasn't making consistent contact causing unintended double clicking or dropping while dragging. I fixed it by doing some soldering to switch the left mouse button with the right mouse button, since I didn't have to use double clicking or dragging with the right mouse button. It worked pretty well for several months until the switched left button started showing the same problem again. Now my newer Logitech mouse (it's more expensive Nano wireless mouse) is having the same problem after about 1 year using it. I think there's a serious durability problem with the button component that Logitech is putting on their mice. I may do the same trick again on this mouse, but now I don't consider Logitech as a good mouse manufacturer anymore. They used to make good quality hardwares but I guess they aren't that good anymore with all those cheap Chinese suppliers for their parts. :(
Apr 28, 2009 | Computers & Internet
Mouse running all over without touching it
Could be a virus - there are ones that do this.
Run a full virus scan.
Apr 25, 2009 | GE 97985 Mouse
I have a logitech which used to work with window vista home premium 64 bits version. Today it is not connecting although i replaced the batteries and the light in the back of the mouse is dim and sometimes...
THE MFG MAY HAVE A CERTAIN BATTERY REQUIRMENT, NEED TO GO LINE AND LOOK UP THAT INFORMATION, DEPENDING ON THE MFG AND THE BATTERY COMPANY THEY WANT YOU TO USE IF YOU DONT USE THERE BATTERY REQUEST THAN YOU WILL END UP BUYING A NEW KEYBOARD OR MOUSE WHEN THE BATTERIES RUN LOW.
LOOK FOR A LITTLE PIN HOLE ON THE BOTTUM OF THE MOUSE ALSO EVERY TIME YOU CHANGE THE BATTERY YOU LOOSE THE FREQUENCE THE MOUSE USES, SO DEPRESS THE BUTTON UNTIL THE COMPUTER SAYS IT HAS FOUND A NEW PIECE OF HARDWARE, THAN THE MOUSE SHOULD WORK FINE.
GO ON LINE AND SEE IF THERE ARE ANY NEW UPDATE FOR THE MOUSE
RODGANDYSR
Mar 05, 2009 | Logitech Cordless Mouse
Wireless keyboard and optical mouse
Thanks! I fixed the problem by installing a USB mouse and using fn+f9. That unlocked the mouse so I could use the pointer leaving just the keyboard problem. I then tried reconnecting the wireless keyboard (by using the button on the receiver and under the keyboard) Hey Presto!!
Feb 02, 2009 | Logitech Wireless Access Duo Optical...
Do i need a disk for mouse to work
Hey bigbufford,
You may want to search for the drivers from the manufacturers site if it's offered in the paperwork. If not, I have always found drivers by just typing in the brand, model and manufacturer on a Google search.
Here's the site I have used
http://www.toggle.com/lv/group/view/kl48731/Driver_Logitech_LX7_Cordless_Optical.htm
Mar 16, 2008 | Logitech Cordless Mouse
Logitech 9313960403 Mouse Logo
161 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
