Question about Hobart Handler 140 Mig Welder
I have a century mig wleder that will not feed but you can hear it click when you pull the triger
  • remington445 May 18, 2009
    the wheel does not turn and its getting 24v too it
  • 3 Answers
Tighten the drive wheel on the wire
Posted on May 14, 2009
Lincon mig stops feeding wire
Been welding for a while, open side, check for proper tension on the feed wheel inside side panel, hit the trigger, if feed motor continues to spin tensioner needs tightened or mig wire may be getting hung up inside main cable lead. If motor is off on off on then its probbably the switch on the trigger getting a bad good connection, hope this helps o and check welding tip on gun end, may need replaced if worn or melted, unscrews.
Mar 05, 2012 | Welding Tools
I have a Marquette m12209 mig that wont feed. fan runs and lights are on and fuses are good. anyone have a wiring schematic?
check the wire drive motor it may have burnt out also check the wire wheel drive teeth they may be slipping and dont try using rusty wire it rips the teeth off the wire drive wheel if this is all good check the neck triger switch if thats not working the wire feed wont work then take out the nippel and pull the wire through it to check its free in the feed tude with no kinks in it,,,
Mar 10, 2010 | Welding Tools
I have a miller maxstar 140 str that does not work I get no weld output. the ready light comes on initially then fades and blinks once.
i have a miller 210, when i pull triger it makes clicking noise and does not feed wire, then when i pull trigger again it works, does this sound like a gun problem or controller problem
Feb 03, 2010 | Miller Welding Tools
Century mig welder. The wire speed is spinning at max speed as soon as the machine is turned ON. Will only stop when machine is OFF.
My Century 225 mig has lost its power ...with adjustments to max it leaves a high weld deposit and low penertration.
What is the fix ?
Aug 14, 2009 | Lincoln Electric LE 83180 Century...
Owners manual for a century wire feed 83160 mig welder
I believe century was bought by lincoln. call 1-866-236-0044 ext 3. Ask for century parts.
Paul
Apr 19, 2009 | Lincoln Electric LE 83180 Century...
Welder feeding or arking
Release the wire feed rollers,turn the wire feed dial up to maximum ensure you are well away from the earth clamp, pull the triger, you should hear the relay click in, if it dosn't check the 5 mil anti serge fuse positioned on either the front of the set or on the control panel near the wire feed rollers inside the cabinet. usualy covered by a plastic screwed knob, make sure the unit is unpluged before any testing.
Jan 18, 2009 | Welding Tools
Hobart Handler 140 Mig Welder Logo
244 people viewed this question
Top Hobart Welding Tools Experts
Matt Olenzek
Matt Olenzek
Troy
Troy
Level 1 Expert
Are you a Hobart Welding Tool Expert? Answer questions, earn points and help others
