Question about Bunn NHB Coffee Maker
Unable to remove our sprayhead from our Bunn NHB Coffeemaker
We are unable to remove the sprayhead from our Bunn NHB Coffeemaker
  • 189 Answers
You might try putting a butter knife underneath the sprayhead to remove it. If this doesn't work, then please contact customer service and request a tool that can be provided to remove the sprayhead.
Posted on May 19, 2010
My bunn nhb makes a continuous "boiling" sound even after coffee has brewed.
Check with Bunn and see if there has been a recall. I did in Canada and they sent me a new machine complete with some Tim Horton's coffee! http://www.bunn.com/
Good Luck!
Nov 26, 2011 | Bunn NHB Coffee Maker
Our Bunn coffee maker has worked great for two years, but all of a sudden when we go to make coffee, the water pours out FAST and not the normal slow drip and the coffee is weak weak weak...we have cleaned...
It sounds like you are missing your sprayhead. If you will call Customer Service at 800-352-2866 with the model we will be able to send you out a new sprayhead.
Aug 18, 2010 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
I have a Bunn coffeemaker and it is not that old. It leaks from the bottom when you fill it with fresh water for a new pot of coffee. The number is NHB code date is 204305. Do you have any ideas?
The brewer probably has a bad seal or gasket. By the date code, your machine is 5 years old. If you call Bunn Customer Service they will be able to offer you an exchange of your old brewer for a new one at a reduced price.
May 29, 2010 | Bunn NHB Coffee Maker
Bunn thermal coffee maker used at home does not spray the grounds correctly and water overflows out of the basket during brew cycle. what can I do to correct this. I have already checked filters.
Please call Bunn Customer Service. There is a different sprayhead that can be used to prevent this problem from happening and is free of charge.
May 20, 2010 | Bunn NHB Coffee Maker
My Bunn coffeemaker NHB is leaking from the bottom onto my counter. Can this be fixed?
If you will call Customer Service with your Model and Date Code located on the bottom of the brewer, we can assist you with this problem.
Apr 28, 2010 | Bunn NHB Coffee Maker
Grounds in coffee. am using bunn coffee filters and still have a mess in my cup and in filter
Are you using a finer ground coffee? Or do you have a water softener, use filtered water or bottled water? If so, please call customer service to get a flow restrictor sprayhead which will eliminate this issue.
Dec 07, 2009 | Bunn NHB Coffee Maker
Coffeemaker
The Bunn coffee machine has an internal tank used for holding approx three potfulls of water at just below brewing temperature. When you add water for a potful, the thermostat senses cold water and starts the brew heater. The water level inside the tank comes up and goes through the sprayhead. This "surge" of water, that you call drips is normal. The hot water stratifies to the top of the tank, just like an electric water tank in a house. The internal pot heater kicks in and boils the water already in the tank, raising the water level in the siphon pipe to the sprayhead until the reservoir under the add water opening is empty.
Sep 15, 2007 | Bunn NHB Coffee Maker
Bunn Coffee Maker Problem
if you can unscrew the sprayhead. use a new baby syringe and squirt water in the pipe that goes down inside the tank [sprayhead] turn the coffeepot on its back so the tank drains into the sink and flush out the sprayhead pipe. you may be able to purchase a cleaning spring for bunn o matics from nelson appliance on the web.
Sep 06, 2007 | Bunn NHB Coffee Maker
Bunn NHB Coffee Maker Logo
370 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
