Question about Philips Magnavox DVD/VCR Dual Player
Have a Magnavox dvd/vcr player. I want to program it to start at the the same time, or to automatically play the dvd when the machine turns on without going through the menu function. Is this possible?
Nope! that is not a probs
Posted on May 14, 2009
Magnavox vcr/dvd combo the vcr part only plays for 8 seconds
What you have is called a transport problem in the VCR unit--the mechanism is either jammed or something in it that loads the tape is bad.
Every time it is used it cycles to self check the mechanism--if it fails it is usually a belt bad or a gear assembly not working.
Someone would have to open unit to see what is happening.
May 28, 2012 | Philips Magnavox MWR20V6 DVD Recorder/VCR
My disc records fine, plays great on the Magnavox, but no other player can read the disc?
You must finalize a disc before it can play on other machines. Please refer to your documentation for how to finalize a disc.
Jan 11, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Won't play DVDs.
I put in a dvd and get the "disc error" message. This magnavox dvd player is less than a year old.
Jan 05, 2010 | Philips Magnavox DVD/VCR Dual Player
I have a magnavox mwd2205 dvd/vcr combo with no remote. I've tried programming it to my Charter cable remote and to a GE universal remote, but can't get it to do anything but turn the machine on and off....
This DVD/VCR isn't compatible with the GE Universal remote. Sorry.
I would recommend contacting Magnavox (actually FUNAI CORP.) at www. magnavox.com, and seeing if they would be willing to send you a remote that was compatible with your player. There was another Magnavox player remote that also worked with Magnavox MWD2205. So it's possible that a number of remotes would work for you. Good luck! :)
Dec 28, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I have a 4 yr old magnavox dvd/vhs player and the dvd just started making a clicking noise while it was reading the dvd, played the dvd and then just completely shut off.... Help?
Laser will click loudly when diode is burnt out. Invest in a new machine. Cost of repair would prob be more than new machine. Good Luck.
Nov 20, 2009 | Philips Magnavox DVD/VCR Dual Player
DVD does not play on other players or computer
Hi and welcome to FixYa,
Your description indicates that the last step in the DVD recording has not been performed on these discs that were recorded on the Magnavox. This would be "finalize" or instruct the Magnavox that no other files would be written/recorded on the current disc. Thereafter, the Magnavox would complete the DVD disc making it playable in any other player. Normally, finalization would take a bit of time to complete.
Pls post back how things turned up. Good luck and thank you for using FixYa.
Feb 02, 2009 | Philips Magnavox DVD/VCR Dual Player
Magnavox MWD 2205 DVD/VCR combo: DVD only plays first couple of minutes of disk and then repeats same over and over
is this the begining of a dvd that plays the introduction over and over untill you press play again or select the play option on the intrduction? if not then try a cleaning cd for the laser , also make sure the repeat option has not be enabled when the dvd is played hope this helps! I'll check back to see if you need more help
electech
Oct 24, 2008 | Philips Magnavox DVD/VCR Dual Player
Playing recorded dvds on another player
Re-finalize one more time. On some Philips/Mag players, finalize fails the first time.
If it still won't work, then use a computer program like Dr. Divx to finalize the discs.
Aug 23, 2008 | Philips Magnavox DVD/VCR Dual Player
My vcr won't play back
I have a Magnavox zv457mg9 DVD&VCR combo ,and the vcr records for a short period(10minutes) and then cuts off. This happens each time I try to record on the VCR. Any suggestions??
Feb 26, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Philips Magnavox DVD/VCR Dual Player Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
