Question about HP Photosmart C6180 All-In-One InkJet Printer
Cannot adjust setting to print specific paper measurement
I need to print some invitations that are 5.5 x 8.5 when I go to change the paper setting I do not find this measurement. Can I manually enter this setting or am I missing something? Thank you for your help
    Champion:
  • 214 Answers
Your program should have a section in page setup to manage custom sizes. Enter this size. set size in your printer dialogue box and away you go! Inkypete
Posted on May 14, 2009
How to delete a custom paper size on an HPC6180
->Click the Settings tab.
->Click on Paper Size. A list of paper sizes will appear.
->Select the size you want.
->If none of the selections are suitable, select Custom. A box will appear inviting you to set your own measurements. Enter the width and length that you want.
->Click OK.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Dec 20, 2012 | HP Photosmart C6180 All-In-One InkJet...
Printing 5x7 card stock in HP 1510 injet all-in-one printer
You need to set up your printer preferences to accommodate the type and size of paper you wish to use, usually listed under printer/print or page set up.
Invariably, paper is loaded, butted to either left or right of the paper feed, but on the other side of the feed there should be a sliding stop which keeps your paper in place.
If feeding from the top feed, print side towards you, if printing from a tray at the bottom of the printer, print face down.
You can download a user manual from here once you've chosen your model printer:-
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=uk&cc=uk&h_page=hpcom&lang=en&h_client=S-A-R135-1&h_query=+HP+PSC+1510&submit.x=11&submit.y=7
Apr 22, 2010 | HP PSC 1510 All-In-One InkJet Printer
I was printing on a A4 thick (invitacion Card)
Make sure there is 1/16 to 1/32 inch space on each side of the paper in the paper tray.
Move the paper type selector back and forth 5 times, to make sure it is not stuck.
Feed the tray with a minimum of 20 sheets of paper and try to see if it loads paper through.
The paper thickness lever has two settings, one for plain paper, (thin paper 20# to 24#) and one for envelopes and thick paper.
It should be on the 0 setting for thin paper and on the + setting for thick paper and envelopes.
The paper adjustment lever may be adjusted in between the two settings to accommodate paper that is not standard or that the operating/environmental conditions have changed.
Make sure the paper is loaded far enough into the printer to ensure good contact between the paper and the paper feed mechanism.
Dec 05, 2009 | Epson Stylus Color 600 with GT-5500...
It looks great on the computer but prints out too far to the right. Have adjusted document several times but does not print properly a 5 x 8 invitation...can you help us out?
Try to update or download the latest firmware of the printer at kodak.com/go/downloads just choose the model of your pritner then follow the instructions.
If your using a MS word try to double check under the page settings if its set in 5x8 and also used the paper glide of your printer until it touch the edge of the 5x8 paper
Nov 07, 2009 | Kodak ESP 5 Printer
Paper size
Okay, go to your printer folder Start/Printers Right click on your printer (Officejet 6310) and click on Properties. You will see a button near the bottom called Printing Preferences. Here is where you choose your paper. You can make your choice here and choose to make it your default settings (click Apply to make the new paper your default to print your invitations...you will have to change back after). You may change the quality of print and paper type as well since the default setting won't provide the quality of print you desire. From here it's pretty straight forward. Feed your invitations into the paper tray as you would normal paper and try a test print for quality control. Once you've got the desired output, print the rest of your invitations.
Apr 16, 2009 | HP Officejet 6310 All-In-One InkJet...
Can't Print Invitations
There is a workaround for this problem by tricking the printer.
The paper sensor, on my printer model hp4500 seems to only sense the paper at the beggining of the print job.
What I did to trick the printer to print on odd size paper is slide the paper adjuster to 8.5 and put a regular white sheet in. Then put your odd size paper under it. When you print your document set the number of copies to 2 and print. The printer is going to sense that the paper is correct, and start the job.
Here is the tricky part... once the first 8.5x11 sheet is almost all the way through quickly slide the paper adjuster over to match the size of your odd width paper. The printer should pick up the odd paper and print the second copy. Fool you printa! You should be able to do batches of odd paper size under the first 8.5X11. I hope this helps.
Deny
Mar 27, 2009 | HP Photosmart C5580 All-In-One InkJet...
Printer says to re-insert paper face down.
You must have the default printer settings changed to "double-sided" printingor "print on Both sides".
Check in your printer properties: 'Right click' the printer icon. Select "properties", "Printing preferences", "finishing", un-check "print on both sides" (these options vary slightly by printer model, so just check around on the different buttons).
That's my best guess. :)
Mar 21, 2009 | HP Photosmart C5180 All-In-One InkJet...
Print 5 x 7 invitations on 3100
You need to adjust the paper size in page setup of the program that you are using to create the invitation. What program are you using?
May 19, 2008 | Dell 3100cn Laser Printer
Paper mismatch
Hi kingwa55,
I have an hp photosmart c4480 and was having the same problem printing wedding invitations. Same size 5.5"x8.5'. Im not sure if this will work on your printer, but this is what I had to do.
Click on Print, then Properties, then features.
About half way down there is a drop down box under sizing options.
Click on custom
Create a name, and put your width and height in.
Click Save and then OK
Completely X out of the print options.
Then Click
File, print, properties,features, click the drop down box under sizing options.
Click more and scroll to the bottom and it should be there.
If your options are different then mine, I'm sorry for wasting your time.
Apr 23, 2008 | HP Officejet 6310 All-In-One InkJet...
Print 5x7 invitations on my 950?
Change the size of the document on word to a standard sized document - such as 8-1/2 x 11. Then when you go to print the documents, set the printing preferences to print on 5x7 paper. That should do the trick.
Oct 04, 2007 | HP PSC 950 All-In-One InkJet Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
164 people viewed this question
Seeker5211
Seeker5211
