Question about Cobra 29 LTD CB Radio
Cobra 29 hi i cannot change or switch the stations. help.
    Novelist:
    Champion:
  • 211 Answers
Do you mean you can't change channels? If this is so, you may have the PA switch on. I Hope this helped, but your question is a bit vague. More details are needed. Good Luck
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 07, 2008
Cobra 29 cb not receiving station 1 thru 22
Cannot even begin to answer . It is complicated and tedious process but it all has to do with your processor and that its not obtaining the correct frequencies via the oscellator. In other words its in your vco section of the radio so get a schematic and a block diagram and go for it.
Feb 06, 2014 | Cobra Radio Communications
Cobra 29 LTD LX LE vr pots
vr1 "s" 9 setting on the tx meter vr2 voltage setting vr3 squelch vr4 amc vr5 p4 display on tx signal meter.
Mar 22, 2013 | Cobra 29 LTD CB Radio
What is rf gain cotrol on a cobra cb radio
Rf gain on a cobra 29 is the same as on any other radio. When you turn the knob all the way to the right the RF increases to draw in signals that are far away nut if you turn it to the left only the nearest stations will be picked up.
Sep 22, 2012 | Cobra 29 LTD CB Radio
How much will my wilson 5000 help my stock cobra 29
hi i have one of these on my car and find it not to be as good as the 1000 there ok on both tx/rx can handle 2000 watts output good for sideband use need alot of power behind it to see any change
Oct 14, 2009 | Cobra 29 LTD CB Radio
Cobra 29 LTD Bluetooth
You got your radio peaked? Most likely, however, the pot for the antenna warning indicator is VR6. I always check that after peaking a radio.
Jul 28, 2009 | Cobra 29 LTD CB Radio
Cobra 29 is one channel off, ch 7 is on ch 6 and so on
The radio needs to be tuned.  This should only be done by a licensed repair shop.  You will spend less money taking it to a shop than you will buying testing and tuning equipment needed to do it yourself, which would void the warranty.
Dec 11, 2008 | Cobra 29 LTD CB Radio
Cobra 29
To my knowledge and depending on what board your Cobra 29GTL used, R46 is 47ohms dropping resistor after the switched 12V. Its output is then filtered by C20, 100uF/16V. While it is true that a shorted C20 would burnout R46, the issue is most likely a shorted FET2 (P/N 2SK104H). Should FET2 proved to be shorted, then it is very possible also that inductor/coil near FET2 is defective (LT-A108?).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 15, 2008 | Cobra 29 LTD CB Radio
New power chip
To my knowledge on a Cobra 29 board, replacing TR14 (2SC2029) with a 2SC1969 is supposed to improve/increase the TX power output. Additionally however, L12, 13 & 14 must also be adjusted while the 29 is hooked up to a dummy load/watt meter. Should you wish to try for experimental purposes only:
  • Modulation improvement - adjust VR4 to desired level or cut D11or max talkpower remove TR18 .
  • replace TR14 with 2SC1307 (or 2SC1969).
Jul 08, 2008 | Cobra 29 LTD CB Radio
Low volume and problems with squelch
Check your speaker for a short.
Jul 06, 2008 | Cobra 29 LTD CB Radio
Cobra 29 LTD CB Radio Logo
Top Cobra Radio Communications Experts
Steve
Marvin
Marvin
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
