Question about Dell Computers & Internet
0E 6 not responding when opening
I have win xp home with sp3 and IE 7
Out of the blue I opened OE6 and when I would touch or move the mouse it would immediately go into the ''not responding'' mode and the mouse would turn into the hour glass.I would have to ctr/alt/delete to end OE6. I tried over & over to fix this from forum info, MS knowledge base, searched the internet for answers tried to install OE6 which I can't because I have IE 7. Reinstalled IE 7 with an overwrite thinking it might help. Can't uninstall IE 7 as it does not have a add/remove in control panel.
So help please, I desperately need my OE6 to open!
Thanks,
Charli
  • 2 more comments
  • charli418 May 14, 2009
    I have done everything that you have suggested and the situation is the same.
    What do I need to do now? I need to get into my OE6 as soon as I can.
    Thank you again for your assistance.
    Charli
    Thanks,
    Charli
    Thank you for your continued assistance.
    Installing IE 8 fixed the problem.
    I appreciate your kindness.
    Charli Pickett
    President:
  • 1,865 Answers
I have a couple of solutions. First is to reset IE7 with the following procedure.
  1. Start Internet Explorer.
  2. On the Tools menu, click Internet Options.
  3. On the Advanced tab, click Reset.
  4. In the Reset Internet Explorer Settings dialog box, click Reset to confirm.
If this doesn't work, then go to the following link to reinstall IE7
http://www.microsoft.com/downloads/details.aspx?FamilyId=9AE91EBE-3385-447C-8A30-081805B2F90B&displaylang=en
Posted on May 14, 2009
  • 1 more comment
  • buffalonyman
    buffalonyman May 14, 2009
    Another solution is to go to windows update and get any updates that are required
  • buffalonyman
    To rebuild Folders.dbx, or make it writeable if it is read-only
    1. Quit Outlook Express.
    2. Click Start, click Search, and then click Other files or folders.
    3. Under Look in, click the disk on which Windows is installed.
    4. In the Name of file or folder box, type:
      folders.dbx
    5. Click More advanced options.
    6. Select the Search system folders check box.
    7. Select the Search hidden files and folders check box.
    8. Click Search.
    9. In the results list, right-click Folders or Folders.dbx, and then click Properties.
    10. If the Read-only check box is selected, clear it, and then skip to step 13.
      If the Read-only check box is not selected, click Cancel.
    11. Right-click Folders or Folders.dbx, click Rename, and then type:
      folders.old
    12. Press ENTER.
    13. Restart Outlook Express.
  • buffalonyman
    More soultions
    1. Use roll back to a date when OE 6 worked
    2. You say you can open OE6, use your keyboard to clear out messages rather than your mouse.
    3.Do an online virus check.
    4. install IE8
    5. Install Outlook 2003
Why can i play hidden object adventure pack on my dell with Windows xp
Hi Jennifer,
When you say that you are unable to play , do you mean its not loading ? unable to install it? do you get a specific error message when you try to launch it ?
hidden object adventure pack:
  • System Requirements: Windows XP (Home & Pro) SP3, Windows Vista SP1, Windows 7 . , 800 MHz processor or greater. , 512MB RAM. , 237MB free hard drive space. , DirectX 7.0. Administrator privileges are required to properly install the program on Windows XP, Windows Vista , and Windows 7. Format: WIN XP,VISTA,WIN 7 Genre: ENTERTAINMENT Rating: E10+ Age: 8386390063
if your using windows XP , make sure that you have Windows XP (Home & Pro) SP3 and the rest of the specs mentioned above.
Thank you.
Dennis
Aug 03, 2014 | Video Game Consoles & Games
Sticky mouse eachine had win xp installed win 7 pointer still stuck
You need a new mouse. Upgrading an OS will not fix a hardware problem.
Jun 27, 2012 | E-Machines Computers & Internet
I have a 2002 HP Pavilion 304w & want to install SP3. I only have SP1. Can I do this? Will I still be able to keep my Outlook Express 6 without losing all my email? I've read that if I install IE8, I...
Yes you can do that. Everything will be intact after you install it, so don`t worry.The emails are store on the server not on your computer, so they`re safe too.
Mar 18, 2011 | HP Pavilion 304w (DB282AR#ABA) PC Desktop
Unable to use Micrografx Picture Publisher 10.0 with Win 7
Make sure that Micrografx Picture Publisher 10 pro installs into the X66 Program files folder.By default it will always install into the 64 bit program file if you have a 64bit installed.
If you have the 32 bit Windows 7 installed then right click with your mouse on the program before opening it up and select compatibility mode.Select XP SP3 compatibility mode.This works fine on my Windows 7 32bit. Use the first paragraph method if you have the 64bit Windows 7.
Regards Brian
Feb 14, 2011 | Micrografx Picture Publisher 10
Touch pad mouse will not move
There will be a button above the touch pad or using function key to disable it. try both and find out which is the prob. Some drivers may not installed properly. Run the touchpad driver in administrator mode and if you are having the xp driver set to xp sp3 compatible mode.
Jan 13, 2010 | Computers & Internet
Red X and Blank IE window
CHECK THE INTERNET CONNECTION AND MAKE SURE THAT YOUR CONNECTED. OPEN INTERNT EXPLORE AND GOTO:
TOOLS
INTERNET OPTIONS
CONNECTIONS
LAN SETTINGS
MAKE SURE THAT THE AUTOMATICALLY DETECT SETTINGS BOX IS CHECKED AND CLICK OK......
HOPE THIS HELPS
May 04, 2009 | Sony VAIO VGC-RB42G PC Desktop
Problems trying to install Internet Explorer 8
Firstly Remove SP3 through
http://support.microsoft.com/kb/950249
Then Download SP2, it works fine. Either way u can also go for SP3
Then try again for IE* or Mozilla
Hope It Works Out ur Problem
Apr 12, 2009 | Microsoft Internet Explorer 8
Uninstalled SP3 to get mouse to work.
Right click on my computer, click properties, click on Automatic Updates and select Turn Off Automatic Updates.
Open Control Panel, open Security Center. Then click on Change the way Security Center alerts me, Uncheck all three check boxes.
And now see if your problem cures
Nov 25, 2008 | Microsoft Windows XP Professional With...
Microsoft Natural Wireless Laser Mouse 6000 doesn't work
Hi
If you take the batteries out there is a screw in there. unscrew and open (not easy) with flat knife in the edges wiggling.
attach and touch all the inside wires. I have had the same problem and it is an internal connector problem. Opening and closing aint easy and will take a little patience but it will work.
Good luck
May 03, 2008 | Microsoft Wireless Optical Mouse
Computers & Internet Logo
76 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
