I went to use my micro this morning, there was no lites, nothing. Checked breaker, it was fine, unplugged and plugged back in, still nothing. I did notice about two weeks ago a sizzling sound for a short time and could'nt see anything that would have caused it. It didn't happen again. I know there is a fuse inside that can be replaced, but the screws are star shaped with a piece of metal sticking up in the center. Is there a special tool that I have to purchase to take it apart?
Yes these are torx safety bits could be a t-10,t-15, or t-20. Replace the fuse and see what you get.
If the unit is running, there's probably no reason to replace the fuse unless it's loose in the holder.
That sizzling is indicative of high voltage or high current. It may be signaling the imminent failue of the inverter.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
If it happens again, I would recommend that you contact your nearest Panasonic-authorized servicer.
You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
