Question about Canon NP 6085 Copier
Canon NP 7850 keeps blowing the fuser lamp in half!!
First error code when I arrived was E002. The fuser lamp was blown in half and black. The thermistor foils were peeling away from the its board. I replaced the lamp and the thermistor, and the copier warmed up and came to ready. Made some copies, and everything was OK. Next day the customer used it in the morning. They tried to use it later in the day, and E003 code was on the display. I went back, and the fuser lamp was blown in half, and black. Is this a shorted SSR, or something else??
  • essgee May 14, 2009
    Thanks Ed,
    The lamp was turning on and off when I replaced the thermistor and the lamp.
    essgee
  • 469 Answers
Your lamp is not turning off, could be the SSR, could be control board. Replace the lamp, thermistor and the SSR, but monitor fuser operation, make sure the lamp turns off.
If you have a digital thermometer, check the temp when the lamp finally turns off. If it is in Spec. then run a few copies this should cool the rollers and cause the lamp to relight.
If the lamp reached optimal temp but does not turn off, then the control board could be your issue.
Hope This is of some help.
Ed
Posted on May 14, 2009
My mechine display an error e002.
Error # 0002 indicates "Fuser temperature not rising at correct pace. Same possibilities as E000"
Error #000 refer to a number of possibilities "Fuser did not heat up. Lamp, thermal switch, thermistors, connections, AC driver, DC controller
Replace the Fuser Roller also known as the Pressure Roller or Upper Roller to resolve your problem.
Mar 08, 2011 | Canon NP 6035 Copier
It displays error code e002
its your fuser section,check heater lamp,thermofuse and thermistor if it not worn out.
Dec 20, 2010 | Canon NP 6035 Copier
My Canon copy NP 6035 if in turn it does not want to live. sound briefly returned to off himself. how the solution. thanks.
The copier comes ON then it turns it's self Off , Correct? Turn the copier back ON and hold the Main power switch ON and the display will show a error code. Read it and let the copier turn Off. You most likely have a dead AC short. The error code maybe a E0202 or E000 . One of the lamps are blown or broken and shorting out. You probly have a blown scanning Lamp or fuse. You may also, have a shorted out Scanner Power Cable. It's black and powers the scanner lamp > sometimes the cable crack's and exposes the AC wire. That is a fun job. It may just be a blown fuser lamp.. Good Luck
Sep 06, 2010 | Canon NP 6035 Copier
My Canon np 6028 display error 002
Theis code means that you have a problem with your fuser unit. It may be that one or both of the fuser lamps is not working. Or it could be a blown thermal fuse or thirmister.. Good Luck
Sep 04, 2010 | Canon NP 6035 Copier
Codes e004
The E002 & E004 fuser unit malfunction code.Please check and clean the heater lamps,fuser thermistors & thermofuses.Check or change the SSR.
Jul 15, 2009 | Canon NP 6551 Black and White Copier
Canon copier make is 6312
E002, fuser is not heating up, you will have to test the fuser lamp/lamps, thermal fuses, and connections.
I could also be the thermistors.
May 19, 2009 | Canon NP 6230 Copier
Error code e002
Refers to a problem in the fuser assy. Could be a blown thermistor or lamp. Remove fuser assy & check continuity on thermistor & lamps. Lamps must be disconnected to test. Error will have to be reset in service mode after replacing bad component.
Jun 02, 2008 | Canon NP 6551 Black and White Copier
Canon NP-6035 persistent E002
e002 error normally indicates that the heater {fuser} is off
to clear that in most canon models there is a small press switch is to be activated to reset the error
at the rear right side of machine there is a small cover take it out and look for that small black button, press it while or immediately after switching the machine ON , switch OFF and ON again
if the error still exist may a real damage in fuser e.g. blown thermo fuse or lamp
Jan 25, 2008 | Office Equipment & Supplies
CANON XEROX MODEL 6050
E002 - Fusing unit not heating up.
Replace fuser and reset code, best bet is to contact dealer.
Nov 14, 2007 | Canon NP 6050 Copier
There is a heating problem connected to the fuser. It could be the heater lamp or thermal switches. Lamp is most likely.
Aug 27, 2007 | Canon NP 6035 Copier
Canon NP 6085 Copier Logo
98 people viewed this question
old marine
old marine
