Question about Select Brands System on board CPU / VIDEO/ SOUND/ LAN ....just add memory and drives (BRAND ) (MSCLE266F) Motherboard
I Can't find where the power connector goes on my MSI motherboard
I just took apart my computer and I can't get it to work, I put it back together exactly as I found it. Except for the power button. I CAN'T FIND WHERE TO PUT IT BACK ON!!! PLEASE HELP!!!
  • 11,896 Answers
Between your fan and memory slot, there is a black box with pins, this is where the power switch goes to. There should be labels there for the wires.
you can download your manual here:
http://www.motherboard.cz/driver/mbdriver.htm
Posted on May 14, 2009
I want to take my computer apart but not sure what drivers i'll need once i wipe it clean and put it back together. i tryed once but know my front usb ports don't work
You would use the driver's from the computer's manufacturer's website for your make and model.
Get onlineand got to www.google.com In the google search box type: "MSISupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the drivers.
Jun 02, 2012 | Intel Motherboard
Hi, I have this mother board MSI P67A and Intel Core I5-2500K 3.3Ghz processor. I have it mounted in a Thermaltake V3 Mid Tower with a Ultra LSP550 550w power supply and also 2 Patriot Signature 4GB DDR3...
Welcome to Fixya. With the specs of the computer it seems that the power of 550W is enough and after changing the Power supply to 600W you same result. Most likely the problem is the motherboard if the board is brand new you can ask to a replacement to Tiger Direct and you can ask them since it still has a warranty.
If you have questions please let me know. Thanks for using Fixya
Mar 21, 2011 | Computers & Internet
I need a complete wiring diagram please. my friend took it out of the computer and unplugged all connecters. he cannot put it back together. can you help please.
you can download your motherborad msi 945pl Neo manual, here you can find everything about your motherboard.
http://download2.msi.com/files/downloads/mnu_exe/E7236v1.0.zip
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
manish
Mar 23, 2010 | MSI 945PL Neo-F Motherboard
How do i put back together my windows xp honme edition compaq presario sr1420uk pc any help would be appreciated.i took all the parts out of my pc and dont know how to put it back together again
It's the reverse process you used to take it apart...the last part you took out is the first part you put back in and the first part you took out will be the last you put back.....If you can't get it back together, put it in a box and ship it to me. I fix problems like this all the time.....
Jan 04, 2010 | Compaq Presario SR1000T (568657) PC...
Changed bottom screen tested before putting back
Happens sometimes it is one of two things:
1) When you put the DS back together is the ribbon from the top screen wound to tightly as this can cause the ribbon to pull out slightly from the socket on the motherbaord causing the blackout.
2) I have seen this happen only once before! The plsatic of the shell had a small chip where the battery connectors from the motherboard stick through into the battery compartment. THis tiny piece of plastic was stopping the final connection between battery and DS. Drove me mad, did all the usuals checked battery connections etc. Worht a look.
Nov 19, 2009 | Nintendo DS Lite Console
Connection cable on system board
power supply and or needs battery in it too work in conjunction with each other on toshiba
the connector cord for compaq now it could have left outside comp for external cd or hdd but im going to say its the power connector or too hdd
but if you give me description of connector i will know where it goes
May 09, 2008 | Compaq Armada M700 Notebook
PC Not Starting
When you say "...put computers back together..." what does that mean?
Check video cable pins. Check disk drive connector...make sure they are pushed in tight on mobo and drive connector.
T
Apr 27, 2008 | MSI 694T PRO (6309-470) Motherboard
Select Brands System on board CPU / VIDEO/ SOUND/ LAN ....just add memory and drives (BRAND ) (MSCLE266F) Motherboard Logo
156 people viewed this question
Top Select Brands Computers & Internet Experts
David Payne
David Payne
Are you a Select Brands Computer and Internet Expert? Answer questions, earn points and help others
