Question about RCA Audio Players & Recorders
Sound the sound is very low even when i turn it up how do i fix it
    Brigadier General:
  • 8,546 Answers
What source? What works? When did it start? What hardware? Do you think we read minds?
Posted on May 18, 2009
The sound output is very low even using earphones can the audio output be upgraded to give a normal listening level.
Probably not without using separate amplified speakers. Check the mixer levels are set correctly.
Apr 02, 2016 | Computers & Internet
My tablet sound is low even when i have my volume settings at the max
This may sound silly, bit do you have your tablet in a sleeve or cover? If so, check that the cover is not covering the speaker outlet(s) on the back of the tablet. If it is, a hole or slot cut into the cover over where the speakers are located should fix the problem.
By the way, a quick test to see if this is the proble is to operate the tablet with the cover removed. If the sound is now OK, it's the cover causing the problem. This happens more often than you might think...
Also, some tablet do have really poor audio systems and both low volume and low quality sound. Hopefully your tablet is not one of them.
Jan 01, 2015 | Tablets & eReaders
Watching streaming movies but sound very low even with speakers maxxed out. How can I boost volume?
Check your settings in Control Panel/Sounds and Audio Devices. Make sure vollume is turned up and that the default device under the Audio Tab for sound playback is set to your Altec speakers.
Aug 11, 2012 | HP Computers & Internet
Bought an 32inch LCD HDTV DVD Combo not even a year ago---there is picture but no sound---can't turn up sound with remote or even turn up sound manually--any ideas?i
Good day!!!
That problem is usually cause of low reception if you are using aerial antenna,if your are using cable or digital signal check your wiring and the worst is you have defective audio IC..
I will teach how to determine the exact trouble just click this link LCD HDTV ASSUMED TO FIX and click "get service"..
Thanks for using fixya...
Nov 03, 2011 | RCA L32HD32D 32 in. LCD HDTV
My Polaroid 1911 TXLB 19in television is not working properly. The volume is very very very low. We have a DVD player hook up to it and its been working fine. Last nite was working, shut it off and today...
check the Sounds with Local TV channels.Is it still low?If it is still low sound circuit has to be repaired.if it is ok,sound switching circuit has to be repaired(TV to Video)
Jun 14, 2011 | Televison & Video
My sharp aquos television sound is very low even on max.
I had this problem with my Charter and the box had a sound button on the actual box, not the remotes. Now I have switched to Direct TV Box and have found while not so low I can't hear it, it is much lower than I know it can be and have to turn it up in the higher numbers or turn on the surround sound to hear it. Anyone know what to do with Direct Box, Direct didn't know.
Sep 05, 2009 | Sharp LC-26D4U 26 in. LCD Television
Can't turn up the sound on my Sony Ericsson w300i
what i did i took off the back took the speaker out the wires are barley even touching its easy to fix just check it out mine came undone and it worked for me.
Apr 11, 2009 | Jabra Sony Ericsson W300 / w300i / W550i /...
Very low sound
Have you tried the settings in Control Panel - Sounds and Audio Devices.
The volume of the sound and speakers can be adjusted here - perhaps your main volume is set too low?
Good luck.
May 10, 2008 | Intel D865PERL Motherboard
My sound is very low
hi dear
i think it just about broadband connection, maybe your bandwith it's low to playing loud, just trying to download first , after that you can fix it with sound manager or related software
oke
cropp
Mar 27, 2008 | Acer Aspire 5050-3242 Notebook
Very low sound when using the internal dvd player
This is a known problem - there is no fix - if the dvd mech is replaced, the volume will still be the same. Sorry - - inside info
Sep 18, 2007 | Akai LCT2721AD 27 in. LCD Television
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
