2005 Jeep Liberty Logo
Posted on Dec 13, 2013
Removing the air filter housing 2005 jeep liberty
How do I remove the air filters housing from a 2005 jeep liberty It seems like it is attached to the wheel well
micw
Level 1:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Contributor 47 Answers
  • Posted on Jun 01, 2014
micw
Contributor
Level 1:
Night Owl:
Answers
47
Questions
0
Helped
29628
Points
63
Once you have the air hose and the lid off it just pulls straight up. May need to give it a good tug. There are no screws.
5 Related Answers
rockys performance motors
  • 303 Answers
  • Posted on Nov 23, 2008
SOURCE: 05 jeep wrangler no air/heat when blower is on low
sound like you have a bad blower resister some have a module next to the fan on the passenger side by your feet there is a resister that is inserted in to the blower box or black box that is a module that is inserted that neads to be changed
Ronnie Wilson
  • 1596 Answers
  • Posted on Feb 08, 2009
SOURCE: 1999 jeep cherokee do you have to remove the fuel pump to replace
The combination Fuel Filter/Fuel Pressure Regulator is located on the fuel pump module. The fuel pump module is located on top of fuel tank.
The filter/regulator may be removed without removing fuel pump module although fuel tank must be removed.
REMOVAL
  1. Remove fuel tank. Refer to Fuel Tank Removal/Installation.
  2. Clean area around filter/regulator.
  3. Disconnect fuel line at filter/regulator. Refer to Quick-Connect Fittings for procedures.
  4. Remove retainer clamp from top of filter/regulator. Clamp snaps to tabs on pump module. Discard old clamp.
  5. Pry filter/regulator from top of pump module with 2 screwdrivers. Unit is snapped into module
  6. Discard gasket below filter/regulator.
    1. Before discarding filter/regulator assembly, inspect assembly to verify that O-rings are intact. If the smallest of the two O-rings can not be found on bottom of filter/regulator, it may be necessary to remove it from the fuel inlet passage in fuel pump module.
    INSTALLATION
    1. Clean recessed area in pump module where filter/regulator is to be installed.
    2. Obtain new filter/regulator (two new O-rings should already be installed)
    3. Apply a small amount of clean engine oil to O-rings. Do not install O-rings separately into fuel pump module. They will be damaged when installing filter/regulator.
    4. Install new gasket to top of fuel pump module.
    5. Press new filter/regulator into top of pump module until it snaps into position (a positive click must be heard or felt).
    6. The arrow molded into top of fuel pump module should be pointed towards front of vehicle (12 O'clock position).
    7. Rotate filter/regulator until fuel supply tube (fitting) is pointed towards front of vehicle (12 O'clock position).
    8. Install new retainer clamp (clamp snaps over top of filter/regulator and locks to flanges on pump module).
    9. Connect fuel line at filter/regulator. Refer to Quick-Connect Fittings for procedures.
    10. Install fuel tank. Refer to Fuel Tank Removal/Installation.
WARNING: THE FUEL SYSTEM IS UNDER CONSTANT FUEL PRESSURE EVEN WITH THE ENGINE OFF. THIS PRESSURE MUST BE RELEASED BEFORE SERVICING FUEL TANK .
Two different procedures may be used to drain fuel tank (lowering tank or using DRB scan tool).
The quickest draining procedure involves lowering the fuel tank.
As an alternative procedure, the electric fuel pump may be activated allowing tank to be drained at fuel rail connection. Refer to DRB scan tool for fuel pump activation procedures. Before disconnecting fuel line at fuel rail, release fuel pressure. Refer to the Fuel System Pressure Release Procedure for procedures. Attach end of special test hose tool number 6541, 6539, 6631 or 6923 at fuel rail disconnection (tool number will depend on model and/or engine application). Position opposite end of this hose tool to an approved gasoline draining station. Activate fuel pump and drain tank until empty.
If electric fuel pump is not operating, tank must be lowered for fuel draining. Refer to following procedures.
FUEL TANK REMOVAL
  1. Disconnect negative battery cable at battery.
  2. Release fuel system pressure. Refer to the Fuel System Pressure Release.
  3. Raise and support vehicle.
  4. If Equipped: Remove fuel tank skid plate.
  5. Remove 4 fuel hose shield mounting bolts and remove fuel hose shield from body.
    1. Remove fuel tank fill hose and vent hose clamps at fuel tank filler tube. Remove both hoses at fuel filler tube.
    2. Remove exhaust tailpipe heat shield mounting bolts and remove shield. CAUTION: To protect fuel tank from exhaust heat, this shield must reinstalled after tank installation.
    3. Place a hydraulic jack to bottom of fuel tank. WARNING: PLACE A SHOP TOWEL AROUND FUEL LINES TO CATCH ANY EXCESS FUEL .
      1. Disconnect fuel supply line from fuel extension line near front of fuel tank. Refer to Fuel Tubes/Lines/Hoses and Clamps. Also refer to Quick-Connect Fittings for procedures.
      2. Disconnect EVAP canister vent line near front of tank.
      3. Disconnect fuel pump module electrical connector (pigtail harness) near front of tank. Harness connector is clipped to body.
        1. Remove two fuel tank strap nuts. Position both tank support straps away from tank.
        2. Carefully lower right side of tank while feeding both fuel hoses through access hole in body. Fuel Tank Full And Not Drained Using DRB Scan Tool: To prevent fuel loss through hoses, keep left side of tank higher than right side while lowering. Do not allow hose openings to drop lower than top of tank.
        3. Continue lowering tank until clear of vehicle. Place tank on floor with left side (hose side) higher than right side
          1. Drain tank by removing fuel fill hose at tank. Fuel fill hose is largest of 2 hoses. Insert the drain hose (from an approved gasoline draining station) into hose opening. Drain tank until empty.
          2. If fuel pump module removal is necessary, refer to Fuel Pump Module Removal/installation for procedures.
          INSTALLATION
          1. If fuel pump module is being installed, refer to Fuel Pump Module Removal/installation for procedures.
          2. Install fuel fill/vent hoses to tank fittings. To prevent hose from kinking, rotate each hose until index mark on hose is aligned to index tang on fuel tank.
          3. Install hose clamps to hoses. Position clamps between index marks on each hose.
          4. Position fuel tank to hydraulic jack.
          5. Raise tank into position while guiding fuel fill and vent hoses into and through access hole in body.
          6. Continue raising tank until positioned to body.
          7. Attach two fuel tank mounting straps and mounting nuts. Tighten nuts to 10 Nm (90 in. lbs.) torque. Do not over tighten nuts.
          8. Install both fuel hoses to fuel fill tube. Tighten both retaining clamps.
          9. Position fuel hose shield to body. Install and tighten 4 mounting bolts.
          10. Connect fuel pump module pigtail harness electrical connector near front of tank.
          11. Connect fuel pump module supply line near front of tank. Refer to Quick-Connect Fittings for procedures.
          12. Connect EVAP hose near front of tank.
          13. Install exhaust tailpipe heat shield.
          1. Install fuel tank skid plate (if equipped).
          1. Lower vehicle and connect battery cable to battery.
Anonymous
  • 3533 Answers
  • Posted on Mar 01, 2009
SOURCE: how to replace rear brake pads on 2005 jeep liberty
put the back of car on jack stands and secure the front tires so it does not roll and then remove the bolts off the back of the caliper there is normally two one at top and one at bottom and spray it with some kind of oil for rust and make sure you have the right size socket before you try to loosen them and once caliper is off and the old pads removed take one of the old pads and squeeze the piston on the caliper back in by using a "C" clamp and also remove some of the brake fluid from the master cylinder before you do this put the new ones back on and check the brake fluid and make sure it is full and then pump the brakes to make sure you have a good pedal also put some "No Squeak" brake stop on the back of the pads so they don't squeak they will have that where you buy the pads from
Anonymous
  • 64 Answers
  • Posted on Apr 06, 2009
SOURCE: how to change oil filter on 2008 jeep liberty 4x4 ?
yeah they will say that and it may be your last choice but I know it is in the front of the engine and you need a long extension and ratchet handle and a claw type filter wrench to get it. Worth investing in if your going to do it all the time yourself. but prob not for one time.
david dixon
  • 740 Answers
  • Posted on Dec 30, 2009
SOURCE: how to remove wheel hub assembly on jeep liberty
take the axle nut off and take the spindle off off.on the back of the spindle you will find three bolts.Remove the bolts and beat the hub and bearing out. the new one will go right in. not a hard job
How do i reinstall the air filter housing on 2005 jeep liberty
so someone else took it off?
are you talking the whole air filter housing or just the lid
we can see what you did , and that be first.
on my jeep the lid has snap off top, and obvious answer.
the whole thing is more complex. first all hoses clamps all lose.
then lid if off and you see bottom of box bolts, or side mounts on box,
those need to be put back.
its just a plastic box, and simply mounted to the body, with fastneners
what? needs to be known here, besides liberty tiny sizes and hard to to work on, Id sell it, get real jeep.
2answers
Cabin air filter
The 2006 Liberty does not have one. You can add one if you want though... On the Jeep forum Jeep Jeepster said: "Correct, the liberty doesnt have one. I added a filter media to help filter out dust":
http://www.jeepkj.com/forum/showthre...ghlight=filter
Removing air filter to replace headlight
remove the top part of the air filter housing like you where going to change the air filter. Wiggle the lower part of the air box (the part the air filter sits in) if it wiggles fairly easily pull up on it and the rubber grommets that hold it in place will release.
If it feels pretty solid when you wiggle it than you will need to look for a couple of bolts that hold it into place. A 10mm socket and some extensions will work to remove them.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Where is fuel filter located on a 2005 Jeep Liberty V6 gas engine?
I cannot seem to find a part number for this vehicle's fuel filter. It is probably a non-serviceable part (N/S) that is inaccessible; usually inside the fuel tank.
2answers
Changed fuel filter in my diesel liberty now it wont start
possible air in the fuel system. There may be a bleeder for you to open and purge the air from the fuel system
1helpful
I can't see how to get the air filter removed from a Plymouth voyger. Do you have to disconnect from the bottom once screws removed? Case doesn't seem to snap open.
remove the bolts holding the resonator from the top of the filter housing, loosten the hose clamp connecting the resonator housing to the intake manifold, remove hose connected to resonator housing, remove the bolt connecting the resonator housing to the radiator, now that the assembly is loose, remove it from the engine bay. You should see the filter box by now, remove the clamps around the air filter box and remove the lid.
see attached images for further clarification.
please rate :)
I have as 2005 jeep liberty and need to know what all I need to do a complete tune up on this vehicle. My jeep is a turbo diesel engine
plugs, boots, oil,oil filter ,fuel filter,air filter check rest of flid levels an belt or belts good luck
23helpful
Where is the cabin air filter located on a 2004 jeep liberty?
The cabin filter is right beneath the glove box on the passenger side of the car under the dashboard. open the glove box and remove a few screws and the filter wil be visible. Remove and replace.
1helpful
My ac/ will not move as much air when on the max setting as when I use air from the outside. It seems like something is not opening up to allow for air flow. Blower is working and the small amount of air...
your jeep might have a cabin air filter. alot of people dont know about them. typically they're behind the glove box. you'll need to remove it inorder to see the door for the filter. or check your owners manual it should tell you where it should be.
6helpful
Can't locate air filter...
1. Loosen clamp (1) and disconnect air duct at air cleaner cover (3). 2. Pry over 4 spring clips (5) from housing cover (spring clips retain cover to housing). 3. Release housing cover (3) from locating tabs on housing and remove cover (3). 4. Remove air cleaner element (filter) from housing.
Top Jeep Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Jeep Expert? Answer questions, earn points and help others
