Question about Garden
SMALL ENGINE PROBLEM
I HAVE A TECUMSEH 6.5 HP ENGINE THAT SAT FOR A COUPLE OF YEARS. THE ENGINE STARTS BUT WON'T STAY RUNNING UNLESS I PUMP THE PRIMER CONSTANTLY
  • Anonymous May 26, 2009
    Starts but will not stay running without priming it continually.
  • thenimaj May 11, 2010
    It sounds like the carburator is adjusted wrong. It should be a simple fix with a screw-driver, but it's also possible to damage an engine by adjusting the carburator up too high.
  • 11,896 Answers
Carb will need to removed and thouroughly cleaned.
Also you can file or clean coil where the contacts rub on flywheel.
Change your spark plug as well.
Posted on May 13, 2009
Car won't stay running
If the problem only happens when the engine is cold, a bad electric sensor is likely to blame. If the car stalls even when the engine is warm, the cause is likely a faulty electric fuel pump.
Why is it that my car starts but won't stay running? ' Reference.com
https://www.reference.com/vehicles/car-starts-won-t-stay-running-6449388a9326285d Car won stay running Google Search
Dec 15, 2016 | Cars & Trucks
Tecumseh starts won't idle unless you hold in the choke bulb
If you mean your having to pump the primer bulb to keep it running. Then the main jet is plugged.
1. Take jet(bowl nut) off the bottom of the carb
2. spray carb cleaner through all holes. (up to 4)
3. find a hemming pin and break of the sharp tip, run that through all small holes there may be one hidden in the threads.
4. repeat step 2. and dry with a shot of air( air dusting cans are ok).
These steps are for emissionized carbs( no mixture screws )
Oct 28, 2012 | Ultimate Sound Cyclone Rake Commercial Pro...
I have a 94 caddy seville and it sat for a couple years anyway I can get it to start with starter fluid but it won't stay running I think its the emergency fuel shut off switch but I can't find...
gm didn't have a shut off like that on that model but the fuel pump could have stuck from sitting try smacking the fuel tank while someone is cranking the engine over
Sep 27, 2012 | Cars & Trucks
83 ford mustang sat for two years now won't start
The fuel system is most likely gummed up from bad gasoline, flush the entire system, replace the fuel pump and the filter as well. Add a can of CHEMTOOL to the gas tank to help dissolve the varnish.
Jul 19, 2012 | Ford Mustang Cars & Trucks
Where is the primer ball
It may not have a primer ball. If it does, it would be attached to the carberator. If it starts, but won't stay running, that could mean your carberator needs to be cleaned/serviced.
May 29, 2012 | Mtd 22" Yard Machine Push Mower
I have a craftsman eager-1 4.5 hp mowerthat won't stay running. If I hold the primer bulb in, it runs. I've adjusted the screw all the in and it still won't keep running. Any ideas?
Do you hold the primer in or pump it? Pumping the primer forces the fuel into the intake bypassing the diaphragm's intended function. Assuming you pump the primer to keep it running your carburetor is dirty and should be cleaned. Ensure that your fuel is fresh and that your fuel can and fuel tank has no water in it. Ethanol in fuel will evaporate and cause condensation thus creating unwanted water.
Apr 20, 2012 | Craftsman Garden
6 HP Tecumseh Engine won't stay running
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
May 09, 2010 | Garden
Push mower runs then quits!!
My toro mower starts and will run for ablut 15 minutes and starts to cut out and eventually stop running. What could be the problem
Apr 01, 2009 | Craftsman Garden
Garden Logo
252 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
