SOURCE: bearing kit?
When you re-install the bearings make sure you use a good red appliance grease it is for high temp high speed use. Use a good amount of it then install the bearings the same way you took them out.
SOURCE: hotpoint aquarius plus WMA44
Will be blockage in sump hose .more info req. if this is not right
SOURCE: hotpoint aquarius extra filter
Normally in front of machine.Remove down plastic cover and then you see pump/filter,open and clean and make sure pump rotor is free to run.Jan
