Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Ultimate 2 whirlpool washer will go through the wash cycle then quit before it drains the water out or spins or rinses
  • pkorry2 May 14, 2009
    Our washer also goes through one cycle of agitating the load and then quits. It has something to do with the trigger thingy on the right hand side. If we load enough weight onto the lid (a brick and a box of soap), the trigger will be activated. Do we need a new trigger? What is the trigger's real name?
  • Anonymous May 18, 2009
    It will wash but wont rinse, drain, or spin
  • 47 Answers
SOUNDS TO ME LIKE EITHER THE TIMER HAS GONE BAD IN IT. MY LATE GRANDMOTHER HAD A WASHER THAT WOULD QUIT DURING THE CYCLE. OR IT COULD BE YOUR MOTOR OVERHEATING. CALL A REPAIRMAN AND SEE IF HE CAN FIX IT FOR YA. GOOD LUCK.
RODNEY
Posted on May 14, 2009
Washer not filling or agitating, during wash & rinse cycles
HI, this will occur if the timer mechanism has become unstable. you will need to replace this defective timer control module asap, if possible.
Jul 25, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Stops in the middle of wash cycle
Hi!
If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
The washer will not spin
my washer will not finish spin and reins cycles please HELP ME
Jan 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Washer - Imperial Series Quiet Wash 2
your washers drain hose is too far down the drain pipe which is causing a siphoning action pull the washers drain hose out pipe some you should be able to hear water dropping into the pipe the reason it only happens in the rinse cycle is because the water from wash is being drained and before the water vacuum is broken the rinse water comes in causing it to keep draining
Dec 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer will not Spin during SPIN CYCLES
Thanks for the question If your washer sorta spins and washes ok, your problem is with the transmissionTHanks for your question THe Appliance doc
Jul 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Not draining
what happens once it quits and you advance the timer back to a nother spin cycle does it spin or does the motor not start back
Apr 23, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer ultimate care
check for problem with the pump it is coupled to the motor, if it is spinning then it should also be pumping out the water
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
173 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
