Question about Maytag PYE2300AY Electric Dryer
Belt replacement on an electrical maytag dryer
I have the new belt and i have opened up the dryer completely. it seems like the belt is too big or i am def. doing something wrong. please help. my mom left me in charge and i have to get it done. :)
  • Valerie Pignataro May 13, 2009
    lift up the top?? sorry i am a chick i dont know what i am doing.
    i completely took off the front, i didnt know if that was right.
  • 11,896 Answers
Hi. thanks for the question. to replace belt . lift up top, remove front panel, slip belt over drum. reinstall front and top, and clean all lint . pull dryer from wall ,remove back panel . motor on right, idler pulley on left, pull belt through idler and to your motor.
Posted on May 13, 2009
  • Nate Stansfield
    Nate Stansfield May 13, 2009
    The belt will look a little to big. It has to go in and out of pulleys that put pressure on the belt to make it tighter. You will have to play around until it looks right.
    You can check out this website for step by step directions:
    http://repair2000.com/wpoolbelt.htm
My dryer ghets hot but the tumbler wont spin. I opened it up and the belt is very big not sure if that needs to be rplaced or could it be something else?
This is likely the belt has broken. Here is a link that should help Dryer belt replacement video You will also find videos of different model dryers that show belt replacement at the same site.
Nov 01, 2010 | Maytag Dryers
I have a Maytag Model pyet224ayw electric dryer, The belt broke and I replaced it. Now when I put the new belt on, every time that I turn it on the belt jumps off the tention pully. Can the problem be that...
http://www.applianceaid.com/maytag-dryers.html
this site has proper belt routing pictures for several brands maytag included might be helpful the only other thing i can think of the idler may be worn out or bent or drum may be tight not turning properly should turn freely with belt loose from inside dryer
should be able to push vanes and rotate drum easily
good luck ron
Dec 10, 2009 | Maytag PYE2300AY Electric Dryer
Need to change belt on maytag dryer but dont know how to do it on this model . any help would be great
Get the Model number and order a Dryer Maint Kit from either of these sites.
http://www.partselect.com/
http://www.repairclinic.com/
If you have the belt already then open the dryer door and there should be a couple screws in the opening where the door normally closes at the top. Remove those and then the door should be able to completely come off then you will have access to the belt area.
Good Luck!
Nov 06, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Installing a belt on a maytag dryer the belt seem to be too big what's the solution
you probably don't have it strung right thru the idler pulley by the motor, thats if you have the right length belt to start with,measure it with the old one to be sure
Oct 26, 2009 | Maytag SDE5401AYW Electric Dryer
My Maytag Performa dryer is blowing out cold air. How can I fix it myself?
remove frt cvr,then top then remove drum belt and drum, check for open heater element, defective thermal fuse,hi-limit switch, open neutral to element if it uses the neutral connection
Oct 18, 2009 | Maytag 7.0 Cu. Ft. Electric Dryer
Replace dryer belt
Pull the front panel off, remove the top screws and tilt top back. Rout the new belt around drum at the old wear spot with the grooved side against the drum. Next remove the back access door and rout the belt around the idler pulley and motor pulley. There is only one way to do this and get proper tension on the belt.
Also, when you order the belt, ask if it has a belt routing diagram on the belt package.
Apr 07, 2009 | Maytag PYE2300AY Electric Dryer
Belt came off try to replace but to big
You may have a tension pulley on it which you will have to run the belt through to make it tight. This is primarily for making it easier to put on. Also check the motor bracket that turns the belt and see that it is still in place and not loose. This can happen over time with all the vibration that occurs. Let me know how this turns out.
Jan 14, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
New dryer belt is rubbing top of idler arm spring
Go to repairclinic.com and click on the "Repair Help" link at the top of the page. On the next page look for "Dryer Belt Diagrams" under the Special Features section. There is an extensive list of dryer belt diagram illustrations available that you can print out. Maytag is listed. Hope this helps you.
Nov 11, 2008 | Dryers
Maytag Electric Dryer - replace belt
The belt needs to be above the metal. Otherwise the repair looks good. Easy fix. Thanks for the pic.
Oceti
Jan 03, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Atlantis dryer
Unfortunately the motor now needs to be replaced. New motors cost around $125-$150 and are fairly tricky to install.
Oct 15, 2007 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
294 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
