Question about Arris SURFboard SBG900 Wireless Router (DHSBG900)
My router gives two wireless connections
When I turn on my router, my computer detects two different wireless connections from the router, how can I delete one?? and, is this slowing my broadband capability??
  • 611 Answers
Go to the router page in that you got the wireless option in that just reconfigure it the device then you get the one wireless connection
Posted on May 14, 2009
I had to put my computer back to factory settings and now my Belkin wont go on wireless.It does work if i plug cable in.Is there anything i can do?
HI,
I see you set Windows back to defaults as you mentioned and now your Router will not go Wireless.
First Restoring Windows Back to Factory Defaults will not reset your Routers Settings to Defaults together with Windows.
So Most Probably the issue is since you restored windows back to factory defaults you may need to install the Wireless Driver again on the Machine / Computer to make your computers wireless card work again and be able to detect and connect to your Belkin Router.
try a difefernt device that can connect wireless to your Router or maybe a different Laptop to see if the Belkin is working fine wireless.
If any other Laptop will not detect the Belkin then try turning the Wireless Radio ON again in the Router Settings of Belkin.
But I suggest to check all your system drivers if installed for it to be wireless capable again on the issue, Restoring Windows back to Default will not change anything in the Belkin Router. I believe this is a Driver issue on the Wireless card of your Computer.
You mentioned the system does work if plugged in Wired right, check your drivers install every driver that needs to be installed from the Manufacturer Website of your Computer for proper and compatible drivers.
Have a nice day.
Aug 23, 2011 | Belkin N Wireless Router wireless router
I cant get a internet connection with dlink dir-300 (cable or wireless), pls help, it's working when i tried with different router...
Welcome to FixYa! In regards to your problem there are possible options you could follow. 1. Check first if your computer is detecting the router. Go to your Network Connections and see if its detecting a connection with the D-Link router that you have. 2. I suggest go to this site that has a manual for setting up a D-Link DIR-300 Wireless Router.Check if you missed any of the process. Steps: Go to Google.com then type "cant get a internet Problem with the D-Link DIR-300 Wireless Router" and then look for DIR 300 Wireless Router Manual. There you will find all that you need in setting up your router. Hope this helps! Thank you for using FixYa!
Jul 04, 2011 | D-Link DIR-300 Wireless Router
Able to detect other wireless networks (eg Neighbor's), but unable to detect my wireless router's signal. My wireless signal, however, is detected by other computers, and therefore is transmitting.
Uninstall The Belkin Router manager Software
This is important to maintain a stable connection
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Sep 22, 2010 | Belkin Basic Wireless Router
Able to detect other wireless networks (eg Neighbor's), but unable to detect wireless router's signal. Wireless signal, however, is detected by other computers, and therefore is transmitting.
I can detect my Linksys Travel Router but cannot connect to it...ive tried to connect 2 different lap tops both can detect the router but cannot connect to it. I am using Windows 7
You will need to check the wireless settings of the router.
If your network is secured then make sure that you are typing the correct network key.
also make sure that the DHCP server is enabled on the router.
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Jun 24, 2010 | Linksys Wireless-G Travel WTR54GS Router
Only 2 of our PCs can connect to our Linksys WRT150N router
No. All routers will support up to 254 devices or computers.
1. Check that the third computer is set to automatically get a IP address (called DHCP).
2. Check to make sure there are blinking lights on the back of the computer where the network cable connects.
3. network speed. your computer should be set to auto detect speed. You may have to edit the properties of your network adapter to set it this way.
If this is about a wireless setup, wireless can be touchy and sometimes difficult to get connected.
Types of wireless - older computers may not be able to connect to newer wireless routers for example it may use 802.11 B, and your router is set to only use G.
Its also possible that your setup is such that your ISP provides Internet Addresses, and they only give you two. If so, it will require you to configure your router so that all of the client computer are on the LAN.
If you can proide more info, I can help.
Dec 04, 2009 | Linksys Wireless-N WRT150N Router
My computers can't detect wireless signal from my
Yes ! the wireless network name could be different than the wired network name.
If you connect the cable to the router and the computer it works .
Click Here for step by step solutions
Nov 06, 2009 | D-Link AirPlus Xtreme G DI-624S Wireless...
No wireless detect connection
Hi
Note all changes to be made from wired computer only . Any computer that is phisically connected to the router.
Open the router setup page by typing in your default gateway address( router address) on the web browser
You can get it by
Start -> run -> cmd -> ipconfig
You will see the router setup page opening up
Check what it says . IF on the top it says Internet Status :: Connected then
1. Under wireless you'll see channell and ssid
2. Change channell to 6 or 11 .That gives you the best wireless signal strength . This is the most probable cause .
If you want you can also change the
3. Check your security key
4. And apply changes
5. Now on your wireless laptop go to Control panel ->Network connections -> wireless network connections -> right click -> deleate preffered networks -> refresh netweork list
6. You will find your network there select and connect.
Works great
If Ip status : says not connected
1. restore factory default
2. reconfigure router
3. reconnect
This shoud help and please let me know .
Mar 26, 2009 | Linksys Wireless-G WRT54G Router
Wireless connection problem
Hello There, are there any wireless computers that detects your router? If there is, most of the laptop computers has a built-in on/off (toggle) switch on the side to enable or disable the wireless card on your computer. Make sure it is "ON" then check if it will detect the wireless connection.
If it is a desktop, try to reboot the computer then check again. If none of the computers can detect your router, make sure that the wireless light on the router is lit up. You may also try changing the channel on the router.
Aug 03, 2008 | Airlink Computers & Internet
Wireless connection
If this laptop has a wireless switch, make sure it's on.
Did you get the wireless hub?
Wireless is controlled by the wireless zero service, which should turn on automatically when your adapter is detected.
You can turn it on manually in Control Panel/Admin Tools/Services
Nov 03, 2007 | Acer Aspire 3000 Notebook
Arris SURFboard SBG900 Wireless Router (DHSBG900) Logo
77 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Jerry
Jerry
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
