Question about Kenmore 22422 Top Load Washer
Kennmore top load washer mdl#11020712990 is not draining the water.
  • 5,911 Answers
A washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, repairclinic.com or appliancepartspros.com. Just use your model number as your search criteria. All three sites offer competitive pricing, so shop all three for the best price. If you still need assistance, please contact me and let me know. If my diagnosis is not correct, please post back and elaborate a bit more so I can assist you further. If your washer is not configured this way, or if you still have questions, please let me know.
NOTE: If your washer still goes through the normal cycles like it should (i.e., agitates, spins, etc.) and simply won't drain, you may have a drain pump clog, or in the drain lines somewhere. Verify your lid switch, first.
Posted on May 14, 2009
I have a kennmore elite front loader washer and have taken off the front bottom cover and cleaned out the drain (a pen, some coins and a clear ball) I took the hose off completely by loosening the coil...
try unplugging it and lkeave it unplugged for at least hour that should reset it ,sud of course refers to low water flow into pump but i am sure that has been resolved
Jul 20, 2011 | Kenmore Elite 45986 Front Load Washer
Washer machine
Sounds like the hot water solenoid is stuck.
Feb 11, 2008 | Kenmore 22422 Top Load Washer
Kenmore washer 11020712990 series 70 top loader. The washer will fill and agitate in the wash or rinse mode but will not drain or spin. Would appreciate help. Thank you.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.20712990&pathTaken=partSearch
and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
May 05, 2010 | Kenmore 24032\24036 Top Load Washer
Kennmore washing maching Model 11026722693 stop spinning out water ....
This is a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.26722693
If it neither drains nor spins, the first thing to check is the Lid Switch. This prevents the machine from draining and spinning if the lid is open.
I assume that you cannot hear the motor trying to turn.
Following is a Whirlpool installation and maintenance PDF on top load, direct drive washers. It has a description of how to by-pass the switch.
You can also use the following illustrated guide to see how to access the console.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
To bypass the switch, you only have to disconnect the power to the washer, remove the two plastic clips from the console, remove the two screws under the clips, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
If it works, the Lid Switch is a relatively inexpensive part.
If the washer still doesn't drain or spin, the problem points to the timer.
Oct 05, 2009 | Kenmore Washing Machines
My kennmore 70 series top load washer fills with water but once full will not perform any other functions and when it stops it will not start again until i have drained all the water.
This assumes that it is a basic top load, direct drive, neutral drain machine.
When you say that "once full will not perform any other functions and when it stops..." Do you mean that the timer goes through it's cycle but the machine doesn't agitate or spin?
If the timer runs, the problem points to the motor itself.
Following is a Whirlpool installation and maintenance manual with a troubleshooting guide and how to test the timer.
If you need to tear the machine down, please see GURU JSROCK516 Description of how to remove cabinet and access the transmission.
http://www.fixya.com/support/r699497-replacing_gearcase
Sep 21, 2009 | Kenmore Washing Machines
SPIN CYCLE- NOT SPINNING
Sounds like the lid switch is broken if it won't spin OR drain. Find hole under lid and push pen on plastic flap. If the plastic is not there or doesnt' "click" when you push it, there's the problem.
Mar 15, 2009 | Kenmore 24032\24036 Top Load Washer
Kennmore 22442
last belt drive kenmore came out in 1986..so doubt you find a belt on it unless you have a calypso model..if you have pump out but no spin motor to gearcase coupling is probably broke
May 05, 2008 | Kenmore 22442 Top Load Washer
Kenmore 22422 Top Load Washer Logo
166 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
