Question about Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator
Why do my ice cube coils get rusty and how canthis be fixed?
    Sergeant:
    Champion:
  • 214 Answers
Switch off your refrigerator for 5 hours. and again switch it on.............your problem will be solved
Posted on May 14, 2009
My samsung rfg297aa dispenses crushed ice whether its set on crushed or cubed. why will it no longer dispense cubes?
This answer probably comes too late for you (you posted the question 9 months ago), but I want to record it here for posterity, since I had the same problem, and searching on Google for it brought up your question.
Anyway, I managed to fix this very problem by removing an ice cube that was wedged in the ice dispensing mechanism. The way this unit works is that it pushes the ice cubes through the mechanism, which always rotates the "crushing blades". When you select "cubed" ice, a lever opens up the exit chute wider, which causes the blades to simply push out the ice cubes as they pass through. When you select "crushed" ice, the lever closes the "exit" for the ice cubes to be narrower, so that the ice cubes can't be pushed through by the blades, and instead get crushed by them. I had an ice cube wedged in there that had the same effect of closing the exit to be narrower. Removing it fixed the problem.
You might want to collect all the ice cubes that have accumulated in the ice bucket in a container, empty the ice bucket, clean out the mechanism from any obstructions, and then put the ice cubes back into the ice bucket.
Feb 16, 2011 | Samsung RFG297AA (285 cu ft) Bottom...
The ice dispenser only give crushed ice. It will not do the cubes anymore.
there is a soliniod in the back of the freezer wall that engages to disp cubed ice the coil has either frozen or melted down and won't open the chute to allow cubes out. this happens from time to time on all brands. if you have the coil out and let it thaw you might be able to save yourself from having to buy a part
Apr 23, 2010 | Frigidaire 22.6 Cu. Ft. Side-by-Side...
Ice cubes shrinking and crystalizing in freezer
what is heppening is the defrost circuit and compressor or trying to run at the same time! its either the timer itself or the limit switches inside the wall near the defrost heater coil are shorted closed
Jan 17, 2010 | Freezers
GE side by side CAN17 ice maker...white ''finger assembly'' that pivots has broken two fingers, and the ice cubes are stuck in the cube dispenser. Any ideas why this happens, and how to fix it without...
You will need to replace the icemaker. The sensor that activates the heat coil in the icemaker is bad. The heat sensor allows the cubes to be released from being frozen to the ice tray. Check ebay for a new icemaker. About one third the price of manufacturer for new factory unit.
Oct 27, 2009 | GE Refrigerators
Not making ice
replace complete im and water filter , 100 % it will work :)
Jun 26, 2009 | Amana Refrigerators
Ice Maker will not release the frozen ice cubes from tray
The icemaker use an avaporator system with an heatinc coil and a fan to release cubes.
In your case either the heating coil or the fan in the icemaker must be replaced.
parts can be purchased from partselect.com.
May 31, 2009 | Maytag MSD2454G Side by Side Refrigerator
Ice Cube Tray Sticks
53282922_1db7fdbcf7_m.jpgHeavy Frost on the Coils
This is good! This indicates a defrosting system failure which is a simple control problem. It also means that the sealed system (compressor, evaporator coil, and all associated tubing) is fine as wine in summertime. Defrost system problems are easy fixes that anyone with a pulse can do with maybe just a little help from their friends. The problem will either be the defrost timer (or Adaptive Defrost Control board, if so equipped), the defrost thermostat, or the defrost heater. To locate these parts in your fridge, check out these cool, interactive parts diagrams.
Jul 13, 2008 | Refrigerators
Ice cubes are not crushing
take out the auger assembly (plastic pan with metal coil in it) and dump out the ice and clean and defrost it. let it dry before returning it to the freezer. sometimes ice will buildup and cause this problem.
Jul 10, 2008 | Frigidaire Refrigerators
Ice cube cycle time very high
i suspect a defective liquid line or pump down seleonid coil. just make sure you hear the "click" when it starts up if not the selenoid coils could be defective. also verify that the condenser fan is running,because if not you are short-cycling on high head pressure. please contact if you need any additional info
Jun 11, 2008 | Hoshizaki Commercial Freezer KM-500MAH
Ice Tray Freezes & ice builds up around internal workings of ice cube holder
Check and make sure you door seal is tight. Take a dollar bill and place it between the door jam and gasket, close the door and then pull the bill slowly out. It should be rather tight all the way around. So you will have to do several checks all the way around the door. If you have a bad spot call and have them either replace the gasket or adjust the door.The other thing you can do (I have found most if not all manufacturers require this) empty your ice maker once a week. The problem comes from your refer being a self defrost. There is a heater coil that gets as hot as a range element to defrost the evap coil. It is the defrost cycle that causes the ice to melt down a bit. And the defrost cycles every 12 to 24 hours causing the cubes on top to melt down some. So as your bucket fills whatever was on top melts a bit and by the time you are ready to use several layers may be melted causing them to stick together.
Jun 07, 2007 | KitchenAid Superba Architect KSCS25INSS...
Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator Logo
83 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
