Question about Troy Garden
String replacement how do i replace the string
  • 420 Answers
Consult the owners manual, if you have lost it see if one is available for purchase or download. If the trimmer is relatively new take it back to the retailer and ask for help. If they do not know ask if they will copy the pages from the manual for you. Troy built also has a great web site for their customers, try finding the manual at mtdproducts.com
Posted on May 14, 2009
How do I replace string trimmer string on 4cycle Troy bilt string ttrimmer
verify that you are using the proper diameter trimmer line, if you have the proper line, replace the head of the trimmer
Sep 14, 2014 | Troy Garden
Tip
Replacing a Christmas light Bulb
Replacing a Bulb The ideal replacement is one from an identical "replacement" string bought at the same time as the "operating" string. Anything else is a much less desirable option. Many strings have two separate circuits of bulbs. Within each circuit, all the bulbs are wired in series. They each see the same small fraction of the line voltage, but only as long as the bulbs operate identically. Different strings can have bulbs of significantly different resistance, yet all bulbs will operate at the same voltage, as long as the bulbs are similar within a circuit. But if we place a high-resistance (typically dimmer) bulb in a generally low-resistance (typically brighter) circuit, that bulb can see far more voltage than it was designed to handle. In that situation, the bulb may simply burn out in a fraction of a second. Another issue seems to be warm-up time: All incandescent bulbs increase their resistance as they warm up. But even bulbs with the same ultimate operating voltage can warm up at different rates. And if a fast-warming bulb is placed in a slow-warming string, it can quickly see much more voltage than expected, and may blow out. It is much, much better to buy two strings to operate one string, and then use the other simply for replacement bulbs. But that requires prior planning. For existing strings, there may be an option: If two or more strings were bought at the same time, we can take one out of service, put it in a zip bag and use it for replacement bulbs. For existing lone strings, there still may be an option: Convert a 100-bulb string to a 50-bulb operating string and a 50-bulb dark replacement string. That can be as simple as taking bulbs as needed from one half of the string and using them in the other half. Of course, then we end up with half a string that looks like it desperately needs work. An alternative is to cut the string in the middle and end up with one fully-working short string plus a short string of replacement bulbs that we can keep in a bag. Typically, three wires are twisted together across most of a string, but only two are twisted at the start, middle, and end. So if we look for the two-wire section in the middle, we can cut there (after first turning the power off). On the working half, we can fold each of the two just-cut wires back upon itself and wrap each separately with tape, or separately insulate with electrical heat-shrink tubing.
on Dec 07, 2009 | Kitchen Appliances - Others
Gutair
Have your mom or dad take you and guitar to the music store you are buying your strings from and they will show because they will want you to buy your strings from them. If you have the strings already, go to www.youtube.com and search for "replace guitar strings"
Jun 11, 2013 | Music
How often should I replace my bow's string?
If you're taking good care of your bow's string you can replace it every2 to 3 years. Taking care of your string means you should wax the string everycouple of weeks, and thoroughly clean your bow after an intense use or at leastevery weekend. When you'll notice thatthe string is getting dry that's a sign to get a new one.
Jul 30, 2012 | Archery
HOW DO I INSTALL A NEW STRING IN A PRO CUT 11 for Ryobi RLT30CD trimmer
LINE REPLACEMENT (Fig. 8) (For Reel EasyTM Head) Use 2.4mm monofilament string. Use original manufacturer's replacement string for best performance. n Stop the engine and disconnect the spark plug wire. n Cut one piece of string approximately 7.6m in length. n Rotate knob on string head until line on knob aligns with arrows on top of string head. n Insert one end of string into eyelet located on the side of the string head and push until string comes out through eyelet on the other side. Continue to push string through the string head until the middle section of the string is inside the string head and string outside the string head is evenly divided on each side. n Rotate the knob counterclockwise on the string head to wind the string. Wind the string until approximately 20cm remains protruding from the string head. INSTALLING STRING IN PRO CUT II STRING HEAD Use monofilament string between 2.4 mm and 2.7 mm diameter. Use original manufacturer's replacement string for best performance. n Stop the engine and disconnect the spark plug wire. n Gather two of the pre-cut lengths of trimmer line provided or cut two pieces of trimmer line, in 28 cm lengths. n Insert the strings into the slots located on the sides of the string head. String should be pushed in until approximately 2 cm protrudes from the holes on the top of the string head. n Remove old string by pulling it from the holes located on the top of the string head. http://www.screwfix.com/sfd/i/cat/pdfs/89/p4763889.pdf
Oct 29, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Replace pull string (how to put string on after taking cover off)
Basically, pull the string through the winding hole and knot it off insuring no more than .25" tail on the knot and pull tight. :)
Jul 22, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
Replace string on trimmer
Hi
check in you tube .
The video is talking about trimmer strings in general , but my experience is that all trimmers are more or less the same.
hope it helps
http://www.youtube.com/watch?v=WFu66Q6J62Q
Jul 16, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
I need directions to replace string on black and decker cordless 18v grasshog
Go to home depot. look at the floor model and the replacement spools they sell there. Reverse engineer the stringing process or but a pre-loaded spool.
Otherwise,
1. Squeeze the tabs on the side of the head of the unit to remove the spool cover.
2. remove spool.
3. place end of string in small hole in center ring of spool.
4. wide spool with string in the direction of the arrows printed on the spool. DO NOT OVERLOAD!.
5. snap string into notch on spool and cut string leaving 6" exposed.
6. thread 6" of string through hole in side of unit head, replace spool, and replace cover.
7. go cut grass.
Jul 07, 2009 | Black & Decker String Trimmer Cordless 12"...
String will not feed when bumped
I've never had any luck with those stupid bump heads. Every time I would refill them, the string would get caught up. They bind up. I finally replaced the bump head with a string head that you place short pieces of string in. They're not perfect either. You have to pre-cut the string to about 9-12 inches in length, and just replace the piece when it's time.
Jun 28, 2009 | Troy Bilt Tb70ss Gas Trimmer
Require Manual for Ryobi PTL 2543 25cc line trimmer
Or sometimes you unscrew a retaining bolt set into a plastic "lug", the spool drops out, refill t with line, replace it putting line through holes in the spool casing, refit the "lug" and tighten it again. I think I have the manual for this though and if so maybe I can send you a link to images on MSN Homepage to help you..
Feb 22, 2009 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
210 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Wade Mobley
Wade Mobley
Are you a Troy Garden Expert? Answer questions, earn points and help others
