Question about Kodak EasyShare Z740 Digital Camera
Transferring from internal memory to memory card
I have taken some pics on the internal memory and previously found a way to transfer them to the memory card. Now I can't seem to be able to do this, because as soon as I put the memory card in to transfer them to, the camera reads the card's memory, not the internal.
  • Yesha Jan 14, 2008
    well i have a same problem tht i cant transfer photos from my internal memory of sony cyber shot cmaera into a computer.
  • Anonymous Mar 15, 2014
    camera won't read card -can't get it to change from internal memory continues to read internal storage
Connect camera to computer without disk. Go to "my computer", click on the camera icon, it should say how many pictures you have and ask what you want to do with them.
Posted on Oct 28, 2007
After transferring pics to my pc, when memory card is back in camera, it says no files are there. how do i retain pics on memory card to show on camera?
Check for a setting in the software that deletes pictures fom the card when transferring pictures. Set it to another setting, if this is available.
Jul 04, 2010 | Casio EXILIM EX-Z1000 Digital Camera
Problem transferring pictures to PC
do you have the ability to attempt transfering the pictures onto another computer  maybe its just that computer  what type of card reader are you using  is it factory installed or aftermarket try installing a different card and see it you can transfer pictures from your camera to the computer then  maybe its a file type(format)problem  theres what i have good luck   let me know how it goes
Mar 28, 2009 | Pentax Optio A10 Digital Camera
Unrecongnized file format
Hi there
Connect the camera to the PC, transfer the good pics to a folder on the PC, then use the camera's menu to format the card for use again, if you format the card before transferring the pics, you will loose them all.
Good luck and thanks for using Fixya!!!
Feb 19, 2009 | Kodak EasyShare C643 Digital Camera
Hi i have a casio exilim and i am using a 2gb memory card in it, i went out last night and took lots of pictures after each pic was taken i viewed it to make sure it was ok or if i needed to take another...
You problem set your camera to use internal memory only. Set the memory function to memory card only and all pictures will go to the memory card until it is full. You can probably still transfer your pic files from internal memory to your card.
Nov 23, 2008 | Cameras
Cannot transfer images
the pics you are trying to transfer might be too big for the phone,try to reduce their size/dimension. if it doesnt work, use a memory card reader to transfer the pics directly into the memory card of your phone
May 25, 2008 | Nokia N95 Cellular Phone
Picture Transfer issues
Delete the pics off your memory card.
Transferring them to a CD is only copying them, not deleting them off the card, so at this stage, the card is still full.
If you have a card reader, insert the card and format it.
This will delete everything on the card, making it ready for use again.
If not, follow the directctions for your camera to delete/re-format a card in the camera.
Hope this helps,
Mar 24, 2008 | Cameras
Transferring pics
No, the camera needs its own power to power the camera's CPU, USB interface and internal memory. It has to have its own power to communicate properly to your laptop.
However if your camera uses a memory card or stick, you can remove the card/stick and plug it into your laptop and retrieve the pictures that way without using your camera.
- Jim
Jan 30, 2008 | Kodak EasyShare CX7530 Digital Camera
Kodak dx 6490
Try uninstalling the program and then install the earlier version via the CD that came with the camera. If your computer has a built in SD reader, you could use the drag and drop method of transferring your photos as I find that is the easiest and hassle-free way.
Jan 26, 2008 | Kodak EasyShare DX6490 Digital Camera
Cannot access pics
Once you took pictures without a memory card, all pictures taken will automatically be saved on the INTERNAL MEMORY of the camera.
When taking pictures with a memory card, all pictures are just saved on the memory card itself.
If you are seeing 100-757 on the LCD screen. It means that there are already 757 pictures taken from the first time you've used the camera.
It is possible that some of the pictures are in the internal memory and some are in the memory card.
STEPS to DOUBLE CHECK:
1) Remove memory card out of the camera
- Turn on camera
- View pictures on the internal memory
by just pressing on the PLAY mode button
(lowest of the 3 little buttons)
- Pictures seen are just the ones saved on the internal memory
2) Return memory card back in the camera
- Turn on camera
by just pressing on the PLAY mode button (
- Pictures seen are just the ones saved on the memory card itself
*** If you want to transfer pictures on the internal memory of the camera to your MEMORY CARD, you just have to follow the steps below:
- Make sure there is a memory card inside the camera
- Turn on camera
- Press on PLAY mode button to view pictures
- Press MENU/OK button
- Keep scrolling to the right until you see COPY TO CARD
- Select YES using the arrow keys
- Press MENU/OK to confirm
* When you've done these steps, all pictures from the INTERNAL MEMORY of the camera will be copied to your MEMORY CARD but it depends on the space left on your memory card
** If still, you could not view the pictures, it's possible that the pictures are really gone when you have transferred the previous pictures to your computer.
** Once you have transferred pictures to your PC, and you have deleted those on your camera, the FILE NAME of the pictures will not start from 100-001 again unless you have reset the file name on the settings of your camera.
In example, i already have 256 pictures on my camera so the filename reads 100-256 for the last picture taken. And then i decided to transfer those 256 pictures to my PC and i deleted those immediately after being transferred. So, as i took another picture, FILENAME will start with 100-257 if i have not reset
the FILE NAME settings to 100-001.
Hope i've helped you enough.
Jan 02, 2008 | Samsung Digimax S630 Digital Camera
Transferring pics
I think there is a copy to card option in your camera.
It would enable you to transfer pictures from internal memory to your SD card.
You may check the website of your Camera Manufacturer and download the English manual online.
Oct 10, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Kodak EasyShare Z740 Digital Camera Logo
628 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
