15 Amp circuit breaker keeps on tripping , as as
Dimplex electric fireplace - Model - Mod A , Serial # 27106DO1S 181 ,15 Amp circuit breaker keeps on tripping , as as soon its re-setted
    New Friend:
  • 92 Answers
Breaker tripping right of way means bad breaker or dead short. which means something has burned out or is wired incorrectly
Posted on May 14, 2009
I have a dehumidifier model AHM65LKM1 65 puts when I turn machine on it keeps tripping
Dehumidifier tripping AFCI - DoItYourself.com Community Forums
www.doityourself.com > ... > Electrical - AC & DC
Oct 1, 2011 - My dehumidifier is on a 15 Amp circuit with an AFCI breaker. ... What I mean by that is that it can run without tripping for days or only a few hours ...
Sep 27, 2015 | Dehumidifiers
Trip Circuit Breaker
The circuit breakers may both be functioning properly. What might be happening is that both circuits have other current drawing appliances on them. The circuit breakers react to the sum of all of the currents drawn by all of the devices on that circuit. So, if you have a 15 amp microwave and an 8 amp refrigerator on the same circuit, you would overload a 20 amp circuit by 3 amps.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Apr 14, 2014 | LG LMV1813ST Microwave Oven
My dimplex electric fireplace model HEF22 wouldn't turn on
take out fireplace flame, 4 screws, in the middle is a thin sq. black box 1.5 inchs sq. with an insulated screw driver pull it forward. you should here beep,
if u do- unplug-get a good tape,put tape to keep it forward, what happens is it pulled backwards and the two pins slipped out of the circuit board. dust while u arre in there. hope that works for u. mine is working.keep fingers ccrossed. HAPPY HOLIDAYS
Apr 10, 2012 | ACE Dimplex (r) Compact Electric Fireplace...
Hi, I don't know what the reset switch on my dimplex ofc2000ti looks like, anyone any ideas? Power to unit but not heating up, all connections inside fine. Hopefully it overloaded and tripped.
Turn the Master On/Off Switch to OFF and unplug the unit from the wall receptacle. Leave it unplugged for 12 - 15 minutes. That should give it enough time to reset itself. Then plug it back in and give it a try. Also, make sure that the wall receptacle is working properly and hasn't tripped the circuit breaker in your home's circuit breaker panel. If it did, something is seriously wrong electrically, with the heater.
Hope this helps you solve the problem. Please don't forget to rate my response to your question.
Thanks!
Mar 25, 2011 | Dimplex OFC2000TI Heater
Our dimplex electric fireplace model number 28106D3F shut off and won't turn back on
Turn the Master ON/OFF Switch to OFF. Unplug the fireplace from the wall receptacle and leave unplugged for 10 - 15 minutes. This will give it time t reset itself. In the future, if you finding you're have to do this more often. Unplug the fireplace, stop using it and call Dimplex USA Technical Service 888-346-7539 for further instructions.
Mar 09, 2011 | Heating & Cooling
HI THE 3 INDICATER LIGHTS WERE ALL ON SHOWING THAT THE HEAT SHOULD HAVE BEEN ON FULL CAPASITY!!BUT THERE WAS NO HEAT BLOWING OUT OF THE GRILL!!
Not an unusual problem with any electric fireplace heater. I suspect the overheat circuit has shut the heating element down. Or the element has burned up (that's not unusual either).
In any event, turn the fireplace OFF and unplug it. Wait 30 minutes before plugging it back in. During that time, the overheat circuit may reset itself. If that fails to solve the problem call The Technical Service Dept of Dimplex USA at 888-346-7539, Monday - Friday, 8:00 a.m. - 4:30 p.m. EST. If it ends up needing parts, you can order them at that time.
Have the Model # and Serial # of the fireplace, handy. As you will need to provide that information to them, as well as the date of purchase.
Mar 02, 2011 | Dimplex DF3003 Electric MidSize Heater
Plug the new fan motor, nothing
Sounds as if the Fan Switch may also be faulty. Or the new fan motor is defective. Is the flame function on the electric fireplace working? If the flame function is working, than obviously the fault is either in the fan switch or the new fan motor.
If the motor has a regular receptacle type plug on the end of the cord, try plugging it directly to a wall outlet and see if it works. If you're able to do that, then the problem is in the fireplace's fan switch or in the wiring circuitry going to the fan motor. Perhaps, this is what was wrong all along and not the fan motor, itself.
If nothing is working, check the wall receptacle that the fireplace is plugged into, by plugging in an electric lamp. If the lamp won't turn on, then there's a circuit breaker tripped in your homes circuit breaker panel. Check the circuit breaker panel for a tripped breaker and with nothing plugged into the offending receptacle, reset the breaker. Plug the fireplace back into the receptacle, turn it on and see if it trips the circuit breaker. If it does, there's an electrical short some where in the fireplace. Look for burned or frayed wiring, as well as bad connections.
Hope this helps solve your problem.
Feb 15, 2011 | Dimplex DF3003 Electric MidSize Heater
Keep tripping breakers can i just remove the 15 amp breaker and replace it with a 20 amp ??
I would not go to larger breaker size until I knew why 15 amp breaker is trippingIf you find out that 15 amp breaker is tripping because it is being overloaded or that breaker is getting weak. Then I would replace breaker with the same size because they may have wired some with 14-2 wire instead 12-2, I would not feel comfortable pulling 20 amps, on 14-2 wire. That is my suggestion for what it's worth. Thank you.
Nov 20, 2010 | Sea and Sea Blue Sea 7327 Circuit Breaker...
Heater in fireplace keeps tripping and has to be unplugged to reset (new unit)
heater is drawing to many amps for the heater to run correctly check the circuit it is on and possibly move to a different location on a circuit that has more amps from panel box.
Dec 10, 2009 | ACE Dimplex (r) Compact Electric Fireplace...
Heating & Cooling Logo
339 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
