Question about HP Officejet 5610 All-In-One InkJet Printer
Paper does not release as t should (or used to) from my HP 5610 all-in-one printer. When it does release (after pressing "OK" several times, it does release. Also, the printer is not straight...the margin on the left side of paper is crooked, slanting inwards.
cariandco
  • 39 Answers
SOURCE: Printing on paper is crooked
I would recommend a good cleaning of the rollers with a damp rag (old t-shirts are great for this). Some canned air to blow out the insides always seems to improve operation.
If this is helpful to you, would you please rate this solution? Thanks!
Posted on Jul 18, 2008
SOURCE: The print cartridge cradle cannot move.
cant we fix it on our own
Posted on Sep 25, 2008
SOURCE: HP Deskjet F2180 Margins incorrect for label printing
I eventually managed to print my labels one sheet at a time by forcing the label top edge down the page. You can insert one or two lines above the label template and adjust the font size to get the right distance. It took a bit of trial & error but got there in the end. Hope it helps you
Posted on Dec 11, 2008
"The print cartridge cradle cannot move."
I fixed this problem by disconnecting the power cord from the power-strip and connecting it directly into the wall. My printer was not getting enough voltage from the power-strip. I hope this helps.
Posted on Jan 13, 2009
tumi001
  • 102 Answers
SOURCE: my hp officejet 5610 all in one keeps saying paper
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab47
Posted on Jul 17, 2009
How to fix an HP 5610v All-in-One cartridge jam
1.Try to move the carriage manually back and forth
2. Try to check for any paper jam because at times 5610 give false error message
3. Try to reset the printer
Unplug the power cord from the back of the printer while the printer is ON
Press and hold the # and 6 button at the same time
While holding them plug in the power cord
Once the printer turns on release the button
It will take a minute and 2 and will reset the printer
Apr 20, 2011 | HP Officejet 5610 All-In-One InkJet...
Hello, my printer had several paper jams... Now, once the paper jams are gone, it skips and then shoots the paper out. I can not align the paper or calibrate it.
- Press and hold the "*" key.
- Press the "#" key and release both keys.
- Display should say "Enter Special Key Combo" then release the keys and press "1", "2" and "3" buttons in sequence.
- then you will get few options, now look for an option that says "System Menu or System Information" using arrows keys.
- Press "OK" on it & now look for "semi full re-set and press ok".
- Now printer will turn off and will turn on automatically after few seconds.
- Now printer will align it automaticaly.
Feb 25, 2011 | HP Photosmart C6280 Printer
HP 5610 all-in-one fake "paper jam"
I request you to please perform the below steps to reslove false paper jam..
Step one: Perform a partial reset
  1. Disconnect the power cord from the product.
  2. Press and hold # and 3 while reconnecting the power cord to the product, and then release both buttons.
  3. Try making a color copy by pressing the Start Copy Color button on the product control panel.
    • If the partial reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next step to try a semi-full reset.
Step two: Perform a semi-full reset CAUTION: Performing a semi-full reset deletes any saved phone numbers on the product.
  2. Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
    • If the semi-full reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next solution.
Sep 02, 2009 | HP Officejet 5610 All-In-One InkJet...
Papper Jamm
hi,
ab73
Jun 25, 2009 | HP Officejet 5610 All-In-One InkJet...
Hp office jet 5610- can't print
Please check for any paper jam inside the machine, Phone off hook message is becoz if you use the same phone line for fax and telephone, thats normal. Follow the steps below,,
1) unplug the power cord at the both ends from the printer and wall outlet. connect to wall out let directly dont connect to printer.
2)Press and hold # and 6 while reconnecting the power cord to the product hold for 1 min after plugging the power cord, and then release both buttons, this should resolve the issue.
Regards,  raj_p5983
Jan 22, 2009 | HP Officejet 5610 All-In-One InkJet...
Hp officejet g85 all in one
- try to unplug the power cord of the printer
- do the semi full reset
- press and hold the # and 6 keys
- and while holding the 2 buttons replug the power cord of the printer.
- do not release the two buttons yet
- wait for the printer to starts up
- if it turn off, release the two buttons
- then it will appear the smei-NVM reset
note: this can only be done once.
Jul 24, 2008 | HP Officejet 5610 All-In-One InkJet...
Paper jam
Fiend your solution direct from hp. Here is your solution...
334
Jun 29, 2008 | HP Officejet 5610 All-In-One InkJet...
Hp 5610 all in one printer.
5610 will not download, says no connection to computer.
Dec 17, 2007 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
405 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
