i tried everything to free up disk space but nothing works i now have 0 bytes of space free can any1 helpi tried everything to free up disk space but nothing works i now have 0 bytes of space free can any1 help
You can't post conmments that contain an email address.
you can remove temporary internet files, and turn off, then turn on again system restore. Both should free up a bit of space. Otherwise, Check your hard drive using a different antivirus program. If your hard drive is split into multiple partitions, you could repartition it to give more space to the system drive (usually C:)
HARD DISK MAINTENANCE TO KEEP COMPUTER RUNNING EFFICIENTLY.
Hard
disk maintenance should be carried once a month to make your computer run
efficiently.
This
removes redundant and temporary files, recovers disk space and speed up hard
disk access.
Disk Cleanup should be done
first - Click My Computer - then right click on the C drive then click
Properties, then click Disk Cleanup - let it examine the C drive then it will
calculate the amount of disk space it will recover, tick all the boxes to
recover the maximum disk space and then Click OK and then Yes to perform
these actions. If you have a D drive then repeat these steps on this drive too.
Next the C drive needs to
be Defrag. This process converts fragmented files
into continuous files and this speeds up disk access and makes the hard disk
not work as hard. Click on Start - All Programs - Accessories - System
Tools - Disk Defragmenter - click to highlight the C
drive and click Analyse - then click Defragment.
When this is completed
repeat these steps for the D Drive if you have a D drive.
Disk
Cleanup and Defrag can take a long time to complete,
especially if these tasks have not been for a long time.
Hard
efficiently.
This
disk access.
Disk
If you have low memory (RAM) then install more RAM. If you have low memory (hard disk space) the delete unwanted data files and uninstall unwanted programs. ALSO Carry out HARD DISK MAINTENANCE Hard disk maintenance should be carried once a month to make your computer run efficiently. This removes redundant and temporary files, recovers disk space and speed up hard disk access. Disk Cleanup should be done first - Click My Computer - then right click on the C drive then click Properties, then click Disk Cleanup - let it examine the C drive then it will calculate the amount of disk space it will recover, tick all the boxes to recover the maximum disk space and then Click OK and then Yes to perform these actions. If you have a D drive then repeat these steps on this drive too. Next the C drive needs to be Defrag. This process converts fragmented files into continuous files and this speeds up disk access and makes the hard disk not work as hard. Click on Start - All Programs - Accessories - System Tools - Disk Defragmenter - click to highlight the C drive and click Analyse - then click Defragment. When this is completed repeat these steps for the D Drive if you have a D drive. Disk Cleanup and Defrag can take a long time to complete, especially if these tasks have not been for a long time.
Hello
To free some space on your hard disk, you may un-install some un-used applications from your computer. or you may install this software to another location like drive d or drive e if you may have.
Hope it helps,
do rate the solution if so
The low disc space message refers to the amount of free disc space on your c drive. The c drive is the drive on which your windows is installed, thus yu need to delete some games or not neccesary files to free up some space on your drive. Hope this can help you.
This means your Harddrive(HDD) is nearly full with files and there is no more room to save/work on the harddrive.
You will have to delete some saved files or to uninstall some programs that you are not using anymore, this will create some free space on your HDD. Also do a right click on the Recycle bin/Empty recycle bin and it wil clear some space... If you need more help, let me know, I am happy to help you...
Yes. you have 221 gb available disk storage left. 5 gb will hardly make a dent in that.
You can right click on the computer icon and then select properties to view a pie chart representation of available space if that makes it easier for you.
Memory cannot be "full", Hard Disk space can be full. Is this what you are referring to? To free up more memory you can shut down some programs, you can also uninstall programs and delete files to free up more hard disk space. Or buy a new hard drive.
Thank you, but what are RAR Archieves do you have the steps i can use to proceed with this process.
Thanks
