Dymo LabelWriter 330 Thermal Printer Logo
A
Anonymous Posted on Dec 13, 2013
Begins printing mid-label - Dymo LabelWriter 330 Thermal Printer
2answers
INTERMCK PRINTER PM4I HOW TO ADJUST THE PRINTING PONIT ON THE LABLE. ITS PRINT IN THE TOP OF THE LABEL I NEED IT IN THE MID,OF THE CENTER
Check margins and label size dimensions. Sometimes it helps to use a different size label to get the desired outcome. Adjust, adjust, adjust.
Labels not moving forward enough
Check that you have activated tyhe right detection and not using continuous material in the driver. You should use Transmissive or blackmark depending on your labels.
2answers
It begins to print then stops half way
Having the same problem here... very random... send a print job of labels and it will print the whole lot, or freeze at random points but always halfway through a label... no error message... unplug usb and replug doesnt do anything, but unplug and replug power and off it goes printing more lables but may even freeze again after only a few more have come out... also, every day the first print job of the day prints half the label and pauses for about 10 seconds then keeps going...
- Windows XP Pro SP3
- LabelWriter 400 as supplied out of the box
- Genuine DYMO labels
How do I load labels in monarch 1100 price gun
    Loading
  1. At the back of the pricing gun, there's an opening with two spindles to hold a roll of labels. There's also a slot and two small, black rollers, where you'll place the first label to begin feeding them into the gun.
    Insert a roll of labels into the gun opening so that the beginning of the roll is at the back and comes up over the top of the gun. Insert the beginning of the roll into the slot, squeezing the trigger halfway. Push the labels through the gun until they come out at the front. Thread the labels up and under the black plate on the front of the gun and then under the rubber roller. Squeeze the trigger again and pull six or seven labels out. Discard the labels, leaving the paper backing. Thread the paper backing into the underside of the gun, next to the handle, in the direction indicated by the arrow. Push the paper backing while squeezing the trigger until the gun begins dispensing labels.
    Printing
  1. If the print on the labels is off-center, place a penny in the slot on the right side of the gun and hold it in place. Using another penny, turn the adjuster on the left side of the gun in a clockwise direction, printing test labels to check your correction. Keep turning the adjuster until the print is centered.
    To replace the ink cartridge, turn the latch on the right side of the gun to an upright position. Pull the door out. The ink roller is on the end of the door in a plastic holder. Push the holder apart slightly to remove the old ink roller and insert a new one. Replace the door and turn the latch to hold it in place.
2helpful
Not printing all labels
Do a calibration, this should fix the issue. Also make sure that the label stopper (silver peg on label holder) is pressed firmly against the labels. This will stop the labels from sliding around during a print, throwing off the calibration. Also check to make sure the sensors are free of any dust.
Too much tape
Hi, it seem your label maker is set to the last(amount) of labels printed. Go to: Print Labels, click; Number of Labels; clear to set to (1) Label. That should stop the run off of labels. Thanks paul70f9
Printer working fine - when it stopped printing in mid of alabel♠
If reinstalling the drivers doesn't work... sadly I think it's time for a new one..!
1helpful
Not Printing Correctly
Try reinstalling the printer driver using the CD with label on it LX-300+.
Stops printing after sending job
try to reset to factory defult,
run calibration and sensor profile.
if dont help,
it is possible that the power suply or logic board is faulty.
Top Dymo Office Equipment & Supplies Experts
Daniel Blask
Daniel Blask
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
