Question about Dell Computers & Internet
Keeps powering on and off.
When you turn the Dell Inspiron 7800 on it keeps powering on & off.Till you un plug the a/c adpater.And it trys to Boot.
  • dewyshd6116 May 20, 2009
    I have complety cleaned it.Don't
    have a battery yet.But have a new a/c adpater.
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Remove the battery and only hook up the ac adaptor and see if the laptop acts normal. If it does then either your battery is defective or the power is so low that it can't get enough juice out of the battery.
  • Dell Master
  • 2,404 Answers
Keep in mind since you cleaned it out, only have the AC adaptor hooked up to rule the battery out. If the laptop stays on with only the ac adaptor hooked up and doesn't shut off then you know that the battery is faulty. If it still shuts off even with just the ac adaptor hooked up then it could be the ac adaptor.
Also check one more thing, with only the ac adaptor hooked up, wiggle the cord where it plugs into the laptop and see if the laptop shuts off, if it does then the dc jack on the motherboard is loose and needs to be resoldered back into place so it stays put.
Posted on May 20, 2009
  • 3 Answers
It might be over heating try opening it up abd cleaning it out. if that dosent work you might need a new power supply, or bios update.
Posted on May 14, 2009
Dell inspiron 1520 won't turn on.
Remove the battery from its compartment on the side of your Dell Inspiron laptop computer.
Remove the power adapter from its plug on the side of the Dell Inspiron (if your laptop is currently plugged into a wall outlet).
Press down and hold the "Power" button on the laptop for one to two minutes. This will dispel the excess electrical current that is built up inside the laptop.
Put the battery back inside the compartment of your Dell Inspiron.
Plug your power adapter back into the side of the Dell Inspiron. Press "Power." Your laptop computer will now turn on.
hope this helps
Oct 08, 2012 | Dell Inspiron 1420 1501 1520 1521 1525...
I have a dell inspiron 1150 when i connect the charger the battery and the power light keeps on blinking and nothing happens oh turning the power button
Sounds like the adapter is being overloaded ... Dell is one of 2 or 3 manufacturers using a 3 wire adapter plug jack. And ... well ... lets say they can be problematic ... it's a great system but very sensitive to battery malfunctions. I suggest you remove the battery then pug the adapter in ... if all is OK then have the battery checked
Feb 23, 2011 | Dell Inspiron 1150 Notebook
Dell inspiron 1525 battery not charging
Try to isolate the battery by plugging the power adapter to it. Then remove the power adapter & press/hold the power button for 5 seconds. Insert the battery, turn on the pc & insert the power adapter , check if the battery is charging. If it is still the same, contact their Dell Inspiron tech support 1-800-601-3355 for battery replacement possibly...
May 28, 2010 | Dell Inspiron 1525 Laptop Jet Black
My dell inspiron 531 desktop enters auto detect power save mode
start your computer in safemode and then turn off all power saving features
Apr 10, 2010 | Dell Inspiron 531s Desktop Computer
My dell inspiron 6000 keeps logging off
update the system bios from www.support.dell.com
check the power plan settings..
clean the vent from comnpressed air can or vacume cleaner
if still does not resolve the issue replace the heatsink & fan assembly.
Mar 15, 2010 | Dell Inspiron 6000 8x DVD/CDRW Combo Drive...
I have dell inspiron 1100 with 6450 MAh battery which is death already, i am looking to buy new one, before doing it i would like to get some advise what is the difference between 4400 MAh, 5200 MAh, 6450...
MAH is short for Milli Amp Hr...
4400MAH battery - short time for the battery to discharge....it may work for 4 to 5 hrs....
7800MAH will work longer for say 8 to 10 hrs.....
also depends on what applications u use...if it contains many graphics and you keep watching movies then the working hrs gets further shorter....
hope this clarifies....offcourse...the 7800 will cost you more...than the 4400....
as far as what is suitable to you laptop check the mfg website or the manual that came with the notebook...some times...the power adpator also gives the battery specifications that must be used...
reg
let me know...
Mar 12, 2010 | Dell Inspiron 1100 Notebook
I have a dell inspiron 6000 laptop When i press the start button the power lights stay on for about 5 seconds , then it switches off again. I dose not seam to engage the the operating system I would like...
Check that your power supply/AC adpater is plugged in and working. It could be that you are running on the battery only and if the battery is drained, it tries to start then shuts down again.
Feb 11, 2010 | Dell Inspiron 6000 Notebook
My dell laptop gives me a error code of 0146 amd keeps rebooting
Error Code 0146 refers to failure to find or load NTLDR files, needed to run your operating system. Place your Restore disk in the DVD drive, power up the computer, hold down the F12 key till boot screen shows up. Boot from DVD and run Repair to restore these files.
Sep 25, 2009 | Dell Inspiron 1525 Notebook
Computers & Internet Logo
132 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
