Question about Garden
My neighbour has a cub cadet LT1042, and he just put oil in it and now the oil light is on and the digital dash is flashing Oil and then CH6
He is an older gentleman, and as he had just added oil to the mower, I had him stop and when I checked the level, it was overfilled by quite a bit. I drained some out to bring it down to the full level, but the alarm still was flashing. I told him to go ahead and cut his grass, and while he was cutting the alarm went away. It must hang on for a short time after the condition has returned to normal. Does anyone know where you can access the meanings of the codes that may come up on this machine for future issues?
Posted on May 14, 2009
The code isn't CH6 its CHG. It's a timer to remind you to change the oil after 100 hrs of use.
Posted on May 01, 2010
HOW TO RESET THE BLINKING OIL LIGHT ON A CUB CADET RZT
The dashboard for Cub Cadet/MTD mowers includes hour meter, Low oil, or time for oil change, PTO, and other lights. If the oil light is flashing, it means 1 of 2 things. Low Oil Level, or it is time to perform maintenance by changing Oil and Filter. After this process, the light will reset itself after a few more hours of running.
Sep 08, 2014 | Cub Cadet RZT L42 42" 22HP Zero Turn Mower...
Cant remove oil filter on Cub Cadet LT1050
grab the filter with a pipe wrwnch or drive a screw driver through it and turn it. good luck. Ron
Sep 14, 2013 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Oil light on cub cadet zero turn radium mower is flashing
could be oil pump pressure to low for that engine
May 25, 2013 | Cub Cadet Garden
I changed the oil on my cub cadet lt1042, the oil light is still on
THE AIR FILTER SHOULD MAKE NO DIFFERENCE, THE LIGHT MAY BE AN OIL PRESSURE LIGHT NOT LEVEL LIGHT.
May 02, 2012 | Cub Cadet Street Sign- tractor lawn riding...
Oil light keeps flashing, Check Oil but the oil gage says that it is full.
The flashing comes on just before the 50 hour mark, then again every 50 hours. It has nothing to do with the actual oil in the engine. It is a reminder only to change the oil. It will then reset after the 50 hour intervals. You dont need to do anything to shut it off.
Hopr this helps
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Nov 11, 2010 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
I have a cub cadet lt1550 and the oil light is blinking and a ch6 code is flashing. checked the oil and it is full. just wanted to know if something is wrong or that is a reminder to change oil and if it...
The mower is programmed to remind you to change the oil every 50 hours. It will continue blinking for 2 hours. It will begin blinking again at 100 hours and every 50 hours after that. There is no manual reset.
May 20, 2010 | Briggs & Stratton Garden
Cub Cadet LT1042 PTO won't disengage
If its an electric PTO then the switch on the dash is bad, Its a lever type ungagement then the little break shoes that rub on the blade spindles are either worn out or mis adjusted.If it started when you changed the blade drive belt its possibly the wrong belt??
Oct 25, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
886 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
