Question about HP OfficeJet 7410 All-In-One InkJet Printer
HP 7410 printer displays error ''remove and check colour cartridge
When a new colour cartridge (HP 96) is installed in printer it will not accept and displays an error message ''remove and check colour cartridge'' The cartridge is genuine HP and new from the packet with the protection strip peeled off.
  • Anonymous May 16, 2009
    I removed it, now sure what I'm checking for, and no matter what, I keep getting this error message. Even tried a new cartridge. I'm dead in the water. Help!
I think that spring must have gotten loose that holds the cartridge in place, right hand side, put it back where it belongs, might want to compare with the other, black cartridge side.  Good Luck!
Posted on Jun 02, 2009
Display has "remove and check
It seems simple enough, but this is one of the most effective ways of fixing printer cartridge error. Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached.
To reattach the cartridge check the following steps :
turn on the lid of the printer and then remove the cartridge from the printer head.
Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report.
Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Nov 11, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Error message HP Officejet 7310 "remove and check cartridge on right. Removed cartridge, checked it (nothing), installed it back - still same message. Installed new original HP cartridge - still same...
Can you find a friend with a similar HP printer, i.e., one that accepts the same model-number of ink-cartridge? If the cartridge gives the same error-message in the other printer, it's time to responsibly recycle your "dead" cartridge, and give the brand-new cartridge to your friend, for his/her usage.
Nov 25, 2009 | HP OfficeJet 7310 All-In-One InkJet...
I have a HP 7410 All in one. Recently, it keeps
to make sure about the cause of the issue.. you have to try with another set of cartridges.. if it doesnt work you can replace the cartridges as well..
otherwise you can try with some resets as well
Oct 20, 2009 | HP OfficeJet 7410 All-In-One InkJet...
My HP Officejet 7410 xi is showing an error message that states "Remove and check color cartridge". I have tried replacing the old cartridge with two separate new ones and I still get the error message.
Apparently, there is a known problem with this printer series (7310 / 7410). When you replace the cartridge, there is a metal wire that keeps the cartridge in place. This wire comes away from the wall as you slide the cartridge in and makes a hole in the ribbon cable.
Unfortunately, there is not much that you can do, other than to contact HP. Hopefully, your printer is still under warranty.
Jun 15, 2009 | HP OfficeJet 7410 All-In-One InkJet...
My printer will not accept a new black cartridge.
ITS NOT THE BLACK CARTRIDGE!!! Try changing the colour cartridge and see what happens. When a 9600 checks ink levels it does the black ink first, then the colour, if the colour is low it goes back and checks the black again but will constantly give an error message for the black cartridge. Sounds bizarre but try just the black cartridge in with no colour. print a test page in black only, if that does not print then it is a fault. Also make sure the driver is updated!!!
Feb 16, 2009 | HP DeskJet 9650 InkJet Printer
Color cartridge problem
Check the color side of the carriage....there is a metal piece in there that breaks free from the side and will "stab" the circuitry board that the cartridge comes in contact with...you will probably see a hole in it...I have replaced several print carriages...fairly common problem with all of the HP printers that use the 96 and 97 cartridges...hope this helps
Apr 30, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Hp psc 1510 - replacing cartridge problem
Look under your HP tools, there may be an option for printer maintenance. Open that tool if it is available and click on install new cartridge.
Mar 20, 2008 | HP PSC 1510 All-In-One InkJet Printer
Cartridge problems with the P915 Lexmark printer.
Check that the contacts are clean. Also try another catridge. Even a new on can be bad...
Geno
Mar 04, 2008 | Lexmark P915 InkJet Photo Printer
HP OFFICEJET 7410 ALL-IN ONE PRINTER GIVES MESSAGE TO REMOVE/CHECK CARTRIDGE ON RIGHT EVEN AFTER NEW HP 96 BLACK AND HP 97 TRICOLOR CARTRIDGES INSTALLED.
Were you sure to (1) remove the blue tape over the contacts, and (2) not to touch said contacts? You can try cleaning them with a lint free cloth and distilled water or isopropyl alcohol.
Jan 23, 2008 | Computers & Internet
Remove and check colour cartridge HP 23, HpPSC500 error
Did you trying cleaning the cartridge contacts on your machine?
Jun 23, 2007 | HP PSC 500 All-In-One Printer
HP OfficeJet 7410 All-In-One InkJet Printer Logo
414 people viewed this question
Seeker5211
Seeker5211
