Question about RCA F32648 32" TV
Im just trying to figure out what ratio i should burn my dvds at to fit the screen? some 4:5 ratio looks weird, but then again it could just be the movie
  • 66 Answers
You want 4:3 for a 32" RCA & NTSC.
Posted on May 13, 2009
Aspect ratio problem -- will not display 4:3
You should have an option in your menu for "ratio lock"... many older screens have a ratio lock setting that you can enable or disable. Hope that works!
Jan 15, 2014 | Televison & Video
Top and bottom of screen are cut off how do we adjust to get screen to fit
Press the "Aspect" button on the remote until the picture looks appropriate. You are probably trying to display a 4:3 ratio channel on your 16:9 ratio TV. You are probably viewing it in "zoom" mode, which does not stretch the 4:3 ratio video, but enlarges it until it fits the width of the screen, which zooms part of the video off the top and bottom of the screen.
Mar 07, 2011 | Panasonic PT-53WX54 53" Rear Projection...
LG 50" the pitcher is off the screen each side by
Ok, first make sure you or someone in family didn't hit the "HD Zoom" on your cable remote or whatever kind of remote you have. On ours - Cable- if you hit it once it is in "Normal" picture which on ours has black around edges on a non Hd channel. Then if you hit it again it Zooms once makes pix very large and if you hit button a third time brings it into a wide screen Zoom that fills the Tv screen. If we are viewing HD channels I put it on Normal which will fill the screen and give you the best HD pix. If we are viewing a NON HD channel, then normal will have black on sides, so I hit the Zoom a couple times to fill in the screen. My brother in law had this problem and couldn't figure out why his Sports channel Scores were always half cut off the screen! it was zoomed in too much for that channel. His sports channel was in HD so needed to be on normal instead of zoomed in.
if it is not the Cable remote then this is a second possible cause:
The other thing that happened to me was - we hardly ever use our original TV remote that came with the TV. but one day our picture looked weird and the cable remote didn't adjust it. One of us had hit the "P SIZE" button on the TV remote. this changes your pix from - 4:3 ratio to 16:9 ratio and vice versa. I put clicked that button and on the TV it shows whether it is at 4:3 or 16:9. For newer wide screen TVs you want that set at 16:9 ratio.
All cable company remotes probably are a bit different so check with your company ... to find out where the zoom control is on their remote.
Feb 27, 2011 | LG Televison & Video
How to zoom in on info
When TVs first appeared, they had an picture ratio of 4:3, which matched that of most movie screens at the time. Terrified of losing their business, movie studios struck back with "widescreen" films using 1.85:1 or 2.35:1 ratios. When widescreen TVs started appearing, they emulated those same ratios, but many TV shows (and some movies) were still in 4:3---and we were eventually left with a bit of a mess. Canny manufacturers, including LG, have solved the problem by allowing you to adjust the picture ratio on the TV to fit the program you're watching. If it's not set properly, however, your image will look distorted or cut off. A quick bit of troubleshooting can fix the problem easily.
  1. Press the "Menu" button on the remote and scroll down to the "Option" title (it should be second from the bottom ). Then select "Aspect Ratio." You should see a list of ratio options. You simply need to pick the one which fits the show you're watching.
  2. Choose the 4:3 ratio for older movies and TV programs. You should see a pair of bars on the left and right side of the screen. (That's okay: the bars keep the program in the same proportion in which it was filmed.)
  3. Select the 16:9 ratio for widescreen movies and for more recent shows to match their longer width. For some movies, you may see black bars and the top and bottom of the screen. Again, that allows the movie to be shown in the manner it was filmed.
  4. Pick "Set By Program" to automatically switch the LG TV between 4:3 and 16:9 to match whatever show is on at the time.
  5. Select "Horizon" to horizontally expand the image onscreen. It will fill the whole screen---eliminating the black bars to the left and the right---but it may look distorted.
  6. Use the "Zoom 1" option to zoom the image forward. That will eliminate the black bars at the top or the bottom of the screen, though you will cut off the edges of the image.
  7. Pick the "Zoom 2" button to select a midway point between "Horizon" and "Zoom 1." The picture is stretched, but not as much as with "Horizon," and fills the screen, but doesn't cut off as much as "Zoom 1."
  8. Use the "Cinema Zoom" button to enlarge the picture to fit the screen. This option allows you to adjust the proportion to your liking, rather than use the set proportions of the other aspect options.
  9. Exit the menu when you are done and watch your programming normally.
Feb 04, 2011 | LG Televison & Video
I cannot figure out how to adjust the aspect ratio. The people look very FAT and I have never been able to adjust any T.V. using the buttons on the set. Help! 32" visio does not have some features on the...
Its not called aspect ratio on the TV menu. Its likely called 'Format'. It could also be called cinema, wide, 16:9,4:3, Picture, etc. The remote is EXTREMELY likely to have the picture adjustment button. 'Auto' should work the best.
However...
Most cable pictures are in 4:3. This will leave black bands on the side of the screen. Zoom helps, but you loose the top and bottom of the picture.
Most DVDs are 4:3 (Standard) unless you connect with RGB cables or HDMI cable. The DVD may need to be switched to Progressive to get the best effect. An upconverting DVD will have the most impressive results.
Mar 30, 2010 | Televison & Video
DVD's won't finish Formating. Getting error message: Windows was unable to finish formating. DVD Burner smelled weird, like hot plastic. Worked fine before never had a problem. What could it be ? Is the...
i did everyting today to fix this. bought new dvds, name brands different, tried finding codes, called the number. trust me. try this. clean it. thats All i did. cleaned it with a dvd cd cleaning disc, the one with two little brushes on it, nothing special, ran it until i heard the beep, popped my dvd in, they all worked. everyone, im still recording. i ran it about four times. now, if you tried to burn a dvd, and got the error, throw that dvd away. because i tried about ten dvds. after i fixed it, THOSE dvds were no longer usable. dont know why. hope this works.
Sep 28, 2009 | GoVideo Go Video VR3840 DVD Recorder/VCR
Screen shift for Panasonic TH37PD25
This is an issue you must take up with your new cable provider.
Apr 08, 2017 | Panasonic TH-37PD25U/P 37 in. EDTV-Ready...
Aspect ratio
push setup on remote. go to video, select "16:9".
i was looking for a way to get rid of zoom logo from screen and decided to select 16:9 instead of 4:3 in setup. hope this helps
Oct 30, 2008 | Cyberhome CH-DVD 300 DVD Player
Reads and writes cds,reads dvds but does not burn dvds,
This drive is normally supplied with a couple of Dells.
(because of compatibility) Inspiron 700m,710m
If you have another machine for testing?
check the disk for contents to see if the data burn happened,
this will explain a few things in your processes.
Uninstall/Reinstall the drive and reboot then try again.
Have you tried a full system reinstall yet?
Did it fix your problem?Please let me know thanks
Jul 15, 2008 | Sony (DWQ30AB2) DVD RW Dual Layer Burner
DVD reading problems
you may need to update drivers for your dvd and computer..check for those on the makers website
Mar 20, 2008 | Lite On (SOHC-5232K) (SOHC-5232K-BULK)...
RCA F32648 32" TV Logo
55 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
