Question about Kenmore 72062 Gas Dryer
Won't stay hot more that 30 seconds
Starts fine, runs hot for a while then no heat at all. Just replaced the coils and no luck.
  • Kenmore Master
  • 8,220 Answers
Check your connections to those coils.
Posted on May 14, 2009
Palaris ranger 500 4x4 gets hot won't run cools off starts back
Yuu have got a over heating problem, Or the coil is hooch,
Nov 10, 2012 | Cars & Trucks
I have a gas dryer, model MDG7657AWW that will not stay heated. Every time I put it on, the flame comes on for about 21 seconds & then shuts off. I replaced the igniter, hi limit thermostat, cycling t
On a gas dryer the heat normally only comes on for 30 seconds or until the drum temp reaches 160f at which time the flame is shut down by the cycling thermostat. The drum temp then starts to drop. When the drum temp reaches 105f then another blast of heat is issued for 30 more seconds.That is how they work. Put it all back together and trow a load in there.
Oct 28, 2011 | Dryers
Won't keep running quits after about 30 min. you let it sit awhile and it starts all over again.i replaced the air filter and fuel filter.still has the same problem only has 110 hrs. on it
Sounds like your gas cap is not venting. Your fuel tank has to breath in order deliver fuel, so make sure the check valve in the gas cap is working. You can test that theory by removing the cap, and running the machine with a rag over the gas filler neck. Other things to look for would be fuel lines getting hot, or an over heating fuel pump. If it sounds like it runs out of gas when it does die, I would suspect fuel delivery. If thats not it however, check for spark once the machine dies, a magnito or coil can't be ruled out. Keep me posted please! Good luck!
Sep 28, 2011 | Garden
The dryer works fine in TimeDry mode, but in Intellidry mode it dries very slowly. The "Moisture Moniture" indicator lights start and stay at "Less Dry". I have replaced the moisture...
you could have bad gas coils.if the timer doesn't advance in auto dry most likely you're having heat problems,when the dryer heats and then the heat shuts off then the timer will advance,when the heat comes back on the timer stops,it does this until the clothes are dry.gas coils when starting to fail will work normally until they get hot and then no heat until the coils cool down then they will work again,on time dry the timer just keeps counting down until the time runs out no matter what's happening to the dryer.i've seen the coils fail after the first 10 minutes and other times for 20 to 30 minutes but usually if the load is big and in time dry the clothes will feel warm and you'll need to dry them a second time to get them fully dry,also while you're in ther you should clean out the dryer at least once a year,clean out the duct that the lint filter slides into,vacuum out the cabinet where the motor is and blow out the vent line,if it's a long run i use a leaf blower to blow out the line,remove it from the back of the dryer,stick the leaf blower into the vent line and blow it out,i've blown out birds nest out of some lines, your clothes will dry on time,you won't go through so many parts and you won't have to worry about a dryer fire,the gas coils are on top of the gas valve,remove the two phillips screws,lift off the cover and change out the coils.next time you use the dryer keep an eye on it,after it runs for 20 minutws start checking it,you'll hear a click,then another click and the flame will lite,look into the gas tube and if the flame isn't liting then you have bad gas coils.
Sep 10, 2011 | Maytag MDG7600AW Gas Dryer
Maytag Neptune MGD9700A The heater was getting warm but not drying hot. I replaced the coils (servos) first. This did not solve the issue. Then I replaced the Thermistor, the thermostat and a second...
remove venting from back of dryer and run a test load with clothes if it dryes clothes with venting off then its a venting problem.....remove from back of dryer
Jan 31, 2011 | Dryers
Engine starts and runs,mows for 30 min then chokes
i had the same problem i talked to a repair shop and they said the coil was going bad and when it heats up there is a short in it (follow the spark plug wire back to the motor and the coil is there ) i replaced the coil pack and problem solved, hope this helps.
May 14, 2010 | Garden
I have a R-150. starts runs and fames out in 30 seconds and continues to blow fuel for about 20 to 30 seconds and then I assume flame sensor shuts it down. Im thinking ignition coil. Any ideas. Thanx
What usually causes that is the ignition component is not hot enough to sustain a hot enough temperature to keep the fuel burning some have a spark ignition some have a hot surface ignition,try replacing it and it should work fine.
Sep 02, 2009 | Reddy Heater-30-55,000 BTU Variable
Car starts and runs fine then after 30 min or so runs rough
Check the primary and secondary resistance on your coil and resistance and gap on your spark plugs. Sounds like you have a high temp foul out.
Jul 31, 2009 | 1983 Ford Crown Victoria
Kenmore 72062 Gas Dryer Logo
106 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
