Question about Sharp AR-M277 All-In-One Printer
We own a Sharp AR-M277 copier, scanner, fax machine that we use on our network. The scanner feature worked great, however, after 500 scans it stopped working. Someone told us that it was just a trial & a scanner board needs to be purchased? This does not make sense being it worked fine & we have all the software. It either can or can't scan with what is already installed. Any help would be appreciated.
  • howardmillst May 13, 2009
    Yes, it copies & faxes fine thru the network & independently. The scanner worked fine for many months then all of a sudden when we tried to scan a message saying "an optional scanner kit is not included" displayed. Well I know it has one because I purchased it with one & it worked before.
    Any insight would be appreciated.
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    can you still copy and fax with it?
The machine was put in a demo mode for scanning. What you will need to do, is contact an authorized Sharp dealer and purchase an MX-NSX2 kit and that will enable scanning and also purchase you a copy of a program called Sharpdesk.
Posted on Aug 11, 2009
Due to a power surge, my Sharp AR-M277 won't turn
There is a 20A fuse on the AC power board it is most likely blown. Follow the power cable to the board the big white ceramic fuse is the main, check continuity with meter and replace.
Sep 02, 2011 | Sharp AR-M277 Digital Copier Copier
Our sharp ar-m277 is a network printer and my pc is the only one not able to print from it. this problem just happened out of nowhere. I have tried everything I know to fix it. Any suggestions?
check the network ip of ur computer .is it on network or not.if not then u have to check the LAN port of ur pc as it may be fried.sometimes it happens.then u can add a lan card to make it work ,not costly .
but first check ur ip.
Aug 15, 2011 | Sharp AR-M277 Digital Copier Copier
Does a Sharp AR-M277 use 1 or 2 bags of developer?
Hi, the Sharp AR-M277 takes 1 bag developer (type AR-271MD).
Jan 05, 2011 | Sharp AR-M277 Digital Copier Copier
How to scan a document using a Sharp copier model number AR-M277.
Requires optional network scan kit. When installed it comes with software for scanning
Jul 17, 2010 | Sharp AR-M277 Digital Copier Copier
AR-M237 PRINTS BUT DOES NOT SCAN
You may have a problem with the physical board connected to the machine, try re seating the card with the machine off and unplugged. Its a data issue over the network, it may be the board itself. Try re seating it first.
Mar 23, 2010 | Sharp AR-M237 Copier
Network scanning issue with sharp arm205
This machine can only scan across a network when the Sharp network box is installed and 512mb extra memory is installed in the copier
May 23, 2009 | Sharp AR-M205 Copier
Sharp AR-M450 can't scan to e-mail
Check your primary and secondary dns entry.Also a return admin address is required.
Regards Ed
Mar 27, 2008 | Sharp AL-1641CS Laser Digital Copier
Network Error on display
Have you setup your smtp address on the machine? From any workstation in the same network open your web browser. Key in the IP address of the mfp copier. Goes to network setup and key-in your smtp address.
Sep 14, 2007 | Sharp AR-M277 Black and White Copier
Sharp AR-M277 All-In-One Printer Logo
1,248 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
