Question about LG Studioworks 700S 17" CRT Monitor
Serious problem My monitor suddenly stops the display, the screen goes all blank; also the brightness doesn't remain stable
Yes, it works to the system.
I just reduce the refresh rate of my Monitor and the FLICKERING problem goes for the while.
But, after 5 mins. it starts doing the same but the frequency of FLICKERING of going off the brightness is not same after changing the refresh rate.
Will you please tell me how this thing works.
my e-mail id is nisitg@gmail.com
Posted on Nov 24, 2007
  • 1,006 Answers
Check WGA if it is correctlly put on and go to DISPLAY PROPERTIES - SETTINGS - ADVANCED -MONITOR
Posted on Oct 15, 2007
I have a dell studio 1558 laptop, suddenly while using the laptop the screen for blank so i did a hard shutdown. After that i tried starting my laptop, but there was only blank screen. I attached my...
Seems like a two fold issue here. The blank screen is possibly a faulty laptop display or inverter but the blue screen is caused by powering off the laptop whilst it was doing something and now has damaged files. With your external monitor connected power up and try to reach Safe Mode and let windows find the issue and attempt a repair or press F8 and select repair OS. When you have repaired the OS, shine a bright light at the laptop screen and see if the inverter is not running or a dead screen.
Oct 28, 2014 | Computers & Internet
Monitor not working
If the computer is working but only display doesn't maybe there is problem with display matrix or inverter. The inverter is cheap(20-40$), but if there is a problem with matrix it will be more expensive. To be sure go to computer service.
Jul 26, 2012 | HEWLETT-PACKARD HP ProBook 4320s Notebook
The screen goes blank after 1 second display, flicks back again to the display for 1 second and back to blank, this goes on non stop. The little led next to the on/off button goes from green to yellow...
pandres, Your monitor will need troubleshooting to find out reason why the 2 "cold-cathode-fluorescent-lamps" fail to remain lighted. They provide "white light" so you can see what is on the lcd panel. Connect a "known good" monitor to your pc to prove monitor is bad. If pc is ok, then your monitor will need repair. This type problem not new and is very common for all brands of ccfl back-lit lcd monitors. Watch some video clips at YOUTUBE that show disassembly and repair of ccfl lcd monitors. Read fixya profiles of "budmrtn" buddymc" "12fixlouie" for more information. 12fixlouie
Sep 08, 2010 | Neovo S 19 19 in. Flat Panel LCD Monitor
MY DELL 1525 TURNS ON AND THE NORMAL BLUE SCREEN APPEARS. THEN ALL OF THE SUDDEN IT GOES BRIGHT GREEN, THEN BRIGHT YELLOW, AND STAYS BRIGHT YELLOW
Please connect your laptop to an external monitor and see if the output is the same. If it displays fine on the monitor, then we are looking at either a screen cable problem or a screen problem. If the display is the same as on the laptop, then it is a problem with the display adapter on the mother board.
All the best.
Jan 14, 2010 | Dell Inspiron 1525 Notebook
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
Monitor displays properly then screen goes blank
it seems tht the monitor has gone bad & needs to be replaced....try running a monitor self test by unplugging the monitor cable frm the back of the cmputer & make sure the monitor is receving power frm the wall outlet....chk if the monitor displays anything......let me knw if it wrks
Jul 11, 2008 | Dell 1703FPs 17" TFT LCD Flat Panel...
Remove dry solder at Vertical IC if problem not solves replace VERTICAL IC and pf104
Darshan
Jul 05, 2008 | LG Studioworks 552V 15" CRT Monitor
Screen goes blank
Hi jkm007, Sounds like the back light inverter board is bad. It's a very common problem. LCD's use four small cold compact fluorescent bulbs to back light the display. (thats what gives the LCD it's brightness allowing you to see it) The inverter board runs these lights and when they go bad they will typically show symptoms like you have or the monitor power light comes on and you have either no display or a very dim display. If you ever have one that has no display but the power light is on you can check by shining a flashlight directly into the LCD from the front (right into the screen) if you can see an image then it's either the inverter board (most likely) or the CCFL bulbs have gone bad. The inverter board and CCFL's are replaceable. Good Luck, El Duderino
Nov 12, 2006 | Videoseven V7 L19PS 19" LCD Monitor
LG Studioworks 700S 17" CRT Monitor Logo
152 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
