Question about Sony Televison & Video
What could be wrong ?
My lcd projection tv shut off automatic this morning...i try to turn it on and the green on light comes on and then goes right back off to the red light....the red light flashes 6 times...
  • 431 Answers
Hi Please check your manuel I think this is an indicator that your bulb may have gone , usually with most projectors this is what a red flashing light means . At the price they are | hope for your sake I am wrong but I dont think so Sorry .. regards vortash
Posted on May 13, 2009
My panasonic pt-521cx16 starts, green light flashes, then shuts itself off again
Have you even replaced the bulb / lamp on this TV - other than the green light - did they turn solid red / orange at any point? My initial thought is you need to replace the bulb.
Jan 22, 2018 | Panasonic PT-52LCX66 Projection Television
My rca 52" tv was working this morning than shut
Replace the Deflection board. You can get the replacement deflection board from www.tvrepairworld.com
Nov 08, 2010 | RCA D52W19 52" Rear Projection Television
I have a GE 52 inch projection screen TV. I have replaced three CP's: 150, 114, 120. I also replaced the flyback. The TV worked only a couple of times. I turned it on, then off, and right back on. I only...
You can start with resolder deflection board around Hori output, coils and Big diodes also make sure 2 ribbon connectors are pushed in correctly and in good CK Both Ribbons .
Mar 24, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
I turn the tv. on , the green light comes on then
When you turn it on and it shuts off---ON THE FRONT OF THE SET PRESS AND HOLD BOTH THE MENU AND INPUT(DEVICE) BUTTONS TOGETHER FOR AT LEAST 5 SECONDS AND RELEASE BOTH BUTTONS.
Power light should blink a two digit error code---for example: 2 blinks, a pause and 2 blinks--This is the most common error code.
Let me know what error code you get and I will tell you what it means and if 2-2 what the problem is.
If this information helped you, rate this solution as I do this here for FREE.
SD TECH
Nov 12, 2009 | Mitsubishi WS-65807 65" Rear Projection...
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Pioneer 53
Unplug the TV for maybe 10 minutes, then turn it on. Sometimes these units simply need to recycle. If that doesn't work, you've likely got serious problems.
Apr 11, 2017 | Pioneer SD-533HD5 53" Rear Projection HDTV
52" RCA Rear Projection TV. It doesn't turn on right way.
bad capacitors in the power supply is most likely.
could have bad ihvt and output transistor
Feb 23, 2009 | RCA P52926 52" Rear Projection Television
Won't come on
hy i got a toshiba 42" LCD tv ,when i press the power boton
iget the red light,& it stay that way ontil i pressthe power back off
thanks for any help
Jun 26, 2008 | Toshiba 62HM95 62" HDTV
AV 50D501 JVC projection T.V.
sounds like a bad connection in the deflection circuit. you need a repair tech
Dec 16, 2007 | JVC AV-56WP30 56" Rear Projection...
Televison & Video Logo
74 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
