Question about Canon PIXMA MP780 All-In-One InkJet Printer
Toner reset it there any posibility where i can reset Sharp AR toners, example, AR-202, AR-270 etc.
  • 2,427 Answers
There are chips aviable that are called resetters
google them
Posted on Dec 31, 2007
SOURCE:
F2-02with sharp ar-275
Toner supply abnormality
check toner motor and DV mag sensor
Jun 14, 2014 | Sharp AR-M237 Copier
Sharp AR M700N toner not fusing properly
your bushing at fusser unit is worn out
Jun 03, 2013 | Sharp AR-M700N Copier
Sharp AR 5316 Maching Toner LED Light 3 Min. Blinking, and them start. Please Toner Curm reseting code.
Have you tried to replace the toner???? Are you sure the light that is blinking for the toner?????
Jan 13, 2013 | Sharp AR-5316 Advanced Digital Imager...
Sharp a163 photocopier ero u2 40 and h4
U2 40 is a CRUM comunication error with the toner (wrong toner chip on toner cartridge or wrong toner cartridge) try a new toner.
H4 is a fuser trouble code. Check to make sure all conection are right, Theres a few posible problems for H4, power board, MCU board, thermistor, or broken heat lamp.
Aug 30, 2010 | Sharp AR-160 Copier
U2 fault on Sharp AR-206
Error code U2 in Sharp copier AR 206 shows error or failure of toner crimp you can try to solve by replacing toner crimp
Or by reseting the error code by fallowing procedure
press c intrrupt 0 ( zero ) intrrupt contoneously after pressing all the light on control will go off then press 16 then press start switch
your prob will 100% solve.
if any more prob pl inform
May 20, 2009 | Sharp Office Equipment & Supplies
I have a Sharp AR-507. Error F2-00. How to fix?
It could also be the sponge roller in the toner hopper. The old ones started to deteriorate after a while so sharp modified them.
May 08, 2009 | Sharp AR-507 Copier
Sharp copier ar-bc320 error code??
the DK message means it is time to replace the black drum unit. the drum unit is called an ARC26DU. open the front cover. remove the toner cartridge/s by lifting the green lever and pulling the toner out. Open the left side door. look at where you just pulled out the toner and there is one screw (facing you) holding each drum in place - loosen the screw and pull the drum unit out towards you....slide in the new drum unit.
to reset drum counter go into SIM mode by pressing the following keys one after the other "P" "*" "C" "*" then 24 and start/copy key then 7 then select the color drum you are replacing and confirm reset. make sure copier restarts afterwards
DO NOT refill these toner cartridges (even if you can find someone to do it) The toner cartridges for these machines have generally had ongoing problems as far as longevity and quality - refilling them will only make it worse.
Apr 20, 2009 | Sharp Office Equipment & Supplies
Add toner still blinking of sharp AR-5316
the best you can do is to replace the toner cartridge itself. It won't work if you just refill it.
Oct 31, 2008 | Sharp AR-5316 Advanced Digital Imager...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
101 people viewed this question
Clive
Clive
old marine
old marine
