Question about Toshiba Satellite A105-S4384 Notebook
The serial no. of the charger is 03408500 and it is connected to 3 differnt toshiba laptops what r they?
  • Chris Hingee
    Chris Hingee May 11, 2010
    Please explain your problem clearly.
My toshiba P205-S6307 battery is not charging when plugged in
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test your toshiba p205 charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
Jan 07, 2013 | Microsoft Computers & Internet
My computer says plugged in, not charging
Dead battery. Test battery, try another cord/charger to verify.
Dec 01, 2012 | Toshiba Satellite A135-S4527 Notebook
I have a toshiba laptop and I can not read the serial number on the bottom. The charger is broken. How do I know which charger to order?
There are a couple of ways to do this. First, there should be a product and/or serial number on the charger itself. You could google these numbers. Also, sometimes, when you remove the battery there is more info about the laptop. Maybe the label where the serial number is unreadable has a readable produst number example (p/n). Lastly, often the replacements from the manufacture are expensive. You can get a universal charger at someplace like Best Buy for around $60.00.
One more possibility. When you turn on your computer, it may have some information about the computer on the screen before it boots to windows. You may be able to go into setup and se the model of the motherboard which could help in your search.
Nov 30, 2011 | Toshiba Computers & Internet
My charger for my Toshiba broke, yet I don't remember what the full name for my laptop is. I have the serial number though.
You can find If there is some information on some label on the bottom of your laptop or on your laptop battery. For one series laptops the laptop charger of one brand always is the same. You can try to find if there is the charger you need in this Toshiba AC adapter shop Or you can choose a universal AC adapter for your laptop
Jul 16, 2011 | Toshiba Computers & Internet
I have just bought a new Toshiba Laptop running windows 7. I have a BT router and have connected it by cable not wireless. At first it connects to the internet automatically with no problem, but...
Try to acess internet form a differnt sourse,see if problem repeats,next make sure your wireless is off if you are connected hard wire.If you connect ok from a differnt sourse no problem,your problem should be with isp provider
Jan 11, 2011 | Computers & Internet
I have a toshiba satelite 4300 series and it cannot be opened unless otherwise connected to a charger. also, it says that there are viruses. where and how to download anti virus? where is the nearest...
The reason for your not being able to switch on the laptop without the charger could be a dead battery.
You can get free antivirus from AVG at http://free.avg.com/in-en/download-avg-anti-virus-free
You can locate the nearest centre from this URL: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/globalEntitlement.jsp. Enter the serial number of the laptop to get further details.
Oct 25, 2010 | Toshiba Axiom 60GB HDD Satellite Pro 4300,...
TOSHIBA SATELLITE A200 BATTERY PROBLEMS
This problem is very common and can be because of any of these reasons-
1-Wrong Charger,in case you are using some other charger ..i mean other than the one which came with your TOSHIBA laptop.
2-The transformer of the charger is releasing more than the rated voltage.
3-The earth terminal (one of 3 terminals of charger pin) is short (not working)..
I would recommend you to get TOSHIBA CHARGER OF SAME MODEL from your friend or go to TOSHIBA STORE and ask them for TOSHIBA (ORIGINAL) and connect it to see whether laptop its charging or not.
If it works then you need to change your charger
and if not,then you need to get the charging circuit repaired.
NEVER USE SOME OTHER CHARGER (OTHER THAN TOSHIBA) IT CAN SHORTEN THE LIFE OF YOUR BATTERY AND CAN EVEN SHORT YOUR CHARGING CIRCUIT.
have a nice time ahead...take care
Jun 25, 2010 | Computers & Internet
Toshiba Satellite laptop won't start
From Toshiba Manual:
"Over a period of time, and depending on the usage of the
computer, the brightness of the LCD Screen will
deteriorate. This is an intrinsic characteristic of LCD
technology.
Screen will dim when the computer is operated on
battery power and you may not be able to increase the
brightness of the screen.
Try pushing Screen contrast to Max when on AC charger connected.
Allow several hours charging battery with PC off.
If battery does not completle charge Or if older than 3 years CHANGE it.
Jan 04, 2009 | Toshiba Satellite A65-S126 Notebook
Toshiba Satellite A105-S4384 Notebook Logo
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
