Question about Black & Decker Lawn Mower Replacement Blade Mb-850
Black & Decker 8008 Blade Replacement Procedure
I bought a used Black & Decker Model 8008, Type 3 Electric Lawn Mower. I went to remove the blade to either sharpen or replace. I removed the bottom nut, but the blade will not come off and when I put the nut back on, everything seems going up thru the housing.  I tried to find a manual to download so I could self-diagnose the problem, but I haven't been able to find one anywhere on the net.
Can you direct me to a location for preferably a free download, or else provide some guidance on the proper way to remove and reinstall the blade.
Thanks.
Dennis McCurdy
rancherolv@hotmail.com
  • rancherolv May 13, 2009
    Should have read "everything seems LOOSE going up thru the housing"
SOURCE: black and decker mm675 lawn hog
Wedge a short piece of 2x4 between the blade and the housing,
turn clockwise to tighten !
Posted on May 23, 2008
  • 313 Answers
SOURCE: removal of blade from black & decker lawn mower gx530
i used impact gun with 3<4 socket and run the impact in reverse
Posted on May 29, 2008
SOURCE: When trying to remove nut to change blade on my
Try to get on the shaft with a pair of vise grips. Let me know if this does the trick.donnyb60
Posted on Mar 23, 2009
  • 62 Answers
SOURCE: Where can I find a Manual for Black Decker 19\'' Mower
Is this the lawnhog model MM875?
http://www.blackanddecker.com/ProductGuide/Product-Details.aspx?ProductID=2508
Check here for the owners manual
Posted on Apr 18, 2009
  • 52 Answers
SOURCE: Stopped. Black and Decker Lawn Hog 18-Inch Electric Lawn mowe
you could check the brush connection on the motor or your switch mat not be making contact
Posted on Apr 15, 2010
Black and decker electric mower hums but blade does not turn. appears the brake is not releasing for the blade.
Something has the motor unable to turn. Do not turn on till you locate the source of the problem lest you burn it out.
Aug 02, 2016 | Black and Decker USA Black & Decker MM1800...
Black & decker MM 850 Electric Lawn mower/mulcher. Upon start up, there is major vibration. No way I can run it like this..
Try removing the blade. If the mower runs smooth, replace or balance it.
If not, the mower shaft may be bent. Did you hit something hard with the blade?
Gary
Aug 11, 2011 | Black & Decker 19" Electric Lawnhog...
Cannot tighten blad for 18" Electric B&D Mulching Mower
You may be missing a couple of washers, 2 flat and one lock waasherAre all the pieces there. Sometimes it calls for a spCER
May 26, 2010 | Black & Decker Black and Decker Mm575 18"...
Mower Blades
most lawnmower shops can help you prob just a worn keyway ! or goto black&decker.com for closest repair shop?
Aug 27, 2009 | Electric Lawn Mower
BLack and decker electric lawn mower blaDE IS loose and not turn
If it's like mine (MM 875), it has a plastic "clutch" that has little edges on it that broke off when I was chopping sticks with the mower ;-) Went to the local B&D place and got a new one for less than $3.
But now I'm worrying about the nut holding the blade on -- if I try to get it good and tight, the plastic "clutch" spins around off-kilter... Funny how I never even looked at the blade after I bought the mower used, but never worried about the blade being loose and flying off.
Mar 03, 2009 | Electric Lawn Mower
How to remove blades from black and decker lawn mower
all switch off for safety. hold the blade & turn nut to counter clockwise. i use impact gun. socket 3/4".
Jul 22, 2008 | Black & Decker 19" Electric Lawnhog...
Removal of blade from black & decker lawn mower gx530
May 26, 2008 | Black & Decker 19" Electric Lawnhog...
Replacement batterys for cmm1200 black&decker electric mower
You can find replacement batteries on amazon, click here and take a look: Amazon com Black and Decker 24 0 Volt Lawn Mower Battery 90508011. I hope this was helpful. Cheers
May 04, 2008 | Black & Decker 19" Electric Lawnhog...
Saw your post about Black and Decker MM525 Lawn Mower
Most lawn mower mfgs offer a mulching kit which usually consists of a metal plate to block the discharge opening and a mulching blade which just has a longer sharpenned cutting edge.
With a little labor you can make your own.
Johnww1422@aol.com
Apr 19, 2008 | Black & Decker 19" Electric Lawnhog...
Black & Decker Lawn Mower Replacement Blade Mb-850 Logo
188 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
