Question about M-Audio Audiophile USB Audio and MIDI Interface (Macintosh and and Windows) External Sound System
Running micro korg and MPC through Audiophile
I've recently realized that only both sets of inputs do not work simulataneously.
I want to run my Micro Korg and MPC through the audiophile. Is that possible.....can i hear both music from my computer and the micro korg independently? Can the micro korg/MPC play without having to go through the comp?
Would it make more sense to simply buy a basic analog mixer and run the audiophile as its own channel along with each other device (MPC and Micro Korg)?
This question is not too clear but i hope someone can assist with the basic funcitons of this device.
Thanks so much!
4 Suggested Answers
Mrvica
  • 167 Answers
SOURCE: M-Audio Audiophile External Sound
this is the link you needed!!!
http://www.m-audio.com/index.php?do=support&tab=driver
Posted on Jan 24, 2008
digritz
  • 530 Answers
SOURCE: installation of audiophile 192
Here is a list computer beeps and what they mean.
  • No Beeps: Short, No power, Bad CPU/MB, Loose Peripherals
  • One Beep: Everything is normal and Computer POSTed fine
  • Two Beeps: POST/CMOS Error
  • One Long Beep, One Short Beep: Motherboard Problem
  • One Long Beep, Two Short Beeps: Video Problem
  • One Long Beep, Three Short Beeps: Video Problem
  • Three Long Beeps: Keyboard Error
  • Repeated Long Beeps: Memory Error
  • Continuous Hi-Lo Beeps: CPU Overheating
Most times the beeping is caused by a bad/loose connection somewhere or card not seated properly.
Try disconnecting and reconnecting everything again. Make sure that all the power plugs are connected properly even if you didn't mess with them. Moving things around can sometimes be enough to give you the "BEEPS". ";-}
If you are still having much beeping and no computing you can try my personal favorite.
Start first with verbal threats. Next move to a second floor window and, while you explain whats going to happen if it doesn't knock it off, open the window.
If that fails give it the pitch.
Believe it or not I have used this technique and after reassembly and repair.....No more beep.
I hope this helps but if not let me know and we will try something else.
Posted on Dec 03, 2009
  • 1768 Answers
SOURCE: HI there
the latency is in the sound card.
usually you can set the CPU cache to 512 in a program or synthesizer.
Your Korg softwear may be able to ajust this if it is on your pc. Most PC have the sound card built into the mother board thereby not cutting the performance.
2. You will have to purchase a external sound card for your Audio and midi interface to get the least amount of latency.
The PC cabinet with all it components has a lot of EMI (Electromagnetic interference) that cause some of the latency issues with these device. If you can live with 2ms latency which the human ear can't determine then you can render a acceptable audio and midi setup, The Ableton Live 8 series has a latency setting for the CPU in the program. Download the demo and see if you notice a difference.
Posted on Apr 16, 2010
My korg micro-x synthesizer gets hot at the ac power input on the keyboard
hot connections indicate a short or bad connection ( like an arc welder )
loose wires or solder dry joint or broken wires creating a high resistance and heat in this area
Aug 06, 2016 | Korg Music
Korg Microkorg XL Vocoder Not Working (No Sound)
Check the mic and connections all through its input into the unit. I would check the cartridge of the mic for continuity for the reason that (I think but not 100% sure) on this model, I think there has to be sound at the mic or it does go silent in vocode mode. This is how it digitizes the mic and keys together. The played keys cannot put onto pitch the sound it is NOT picking up at the mic. I think there is a problem with the mic.
Mar 07, 2014 | Korg Micro Microkorg Xl Synthesizer...
I can't get it to change input with the remote.
Tried to unplug the set for a while so the micro can reset itself? What if any lights on the front of the set are on or blinking?
Apr 23, 2012 | Televison & Video
I recently purchased a new M-Audio Audiophile 192 sound card but I cannot get it to work, I don't hear anything coming from my speakers (M-Audio AV40s), which I know are working because I tested them...
This could be that the Onboard Sound Card is turn on in the Basic Input Output Settings, these control wich devices start and run when you computer is first turned on. Commonly known as the BIOS there very often is a setting in there for the sound to come from the onboard sound card or the one installed seperately. You must access this setting when you first sstart your computer, and switch it to disable onboard sound.
Sep 16, 2011 | M-Audio Audiophile 192 Sound Card
Can I run my Dell laptop with Vista with the Boss Micro Recorder ? want to play music that is in my laptop
You can use it, but realize that you do all the work on the Micro BR and just download the result to the PC as an MP3 file. The PC treats the device just like a memory stick
Jan 14, 2010 | Boss Micro BR Digital Recorder
Trend Micro Interent Secuirty PRO v.2 is guarding me too much
Your computer has a virus and has disabled Trend Micro from working correctly. This virus you have is very hard to remove manually. I run this program on all of my customers computers to rid of the virus. It cost $30.00 but will save you hundreds in computer repair.
http://www.enigmasoftware.com/
This is the only spyware remover that will rid what you have. You can download the free trial but it will only let you see if you have the virus/spyware and will not let you remove until you pay. It's worth it, takes 5 minutes to rid computer of viruses!
Your Trend Micro will work properly after you get rid of virus.
The other program that wants you to purchase is a fake....do not enetr your info in the page.
May 09, 2009 | Trend Micro Internet Security 2008(Pc)...
Triton Le
when you are setting your midi track on the mpc are you changing to 2A-Device02 for the 2nd track? 3A-Device02 would be the 3rd track and so on. Let me know if that helps. you should make a new track for each instrument you record from the triton to the mpc, helps when dumping.
Feb 18, 2009 | Korg Legacy Collection
Firewall deactivated
Try going into Start --> (Settings) --> Control Panel --> Add/Remove Programs
Remove the Trend Micro but if you have a product key make sure you have noted it.
Restart then re-install Trend Micro or other Firewall software
Nov 06, 2008 | Trend Micro PC-cillin Internet Security...
Starts running thru channels and inputs
The Micro switches are leaky. They are soldered on the control panel in the front. Either replace the panel or the switchs. You can test this by unsoldering all the switchs and leaving the IR Sensor. You can control the set by using the remote remote . If this help let me know.
Oct 14, 2008 | RCA P61960 61" Rear Projection Television
Open Questions:
M-Audio Audiophile USB Audio and MIDI Interface (Macintosh and and Windows) External Sound System Logo
Top M-Audio Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
John Bolton
Jim Goldsmith
Jim Goldsmith
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
