Question about Alpine CDA-9827 CD Player
Wiring i wood like to know where to connect the pink /black wire for the signal int.
  • 626 Answers
According to the wiring diagram, it is for an Audio Interrupt.
Which means, if you have a car kit, bluetooth, or wired, you can connect this wire to it so the Head Unit will MUTE or Attenuate.
If you dont have a car kit, you dont need to connect it to anything.
Best of Luck.
Posted on Oct 15, 2007
Looking for wiring diagram for door locks on a 2005 f250
PASSIVE ANTI-THEFT YES TRANSPONDER SEE NOTES 12 VOLTS Yellow Ignition harness IGNITION RED / green Ignition harness IGNITION 2 Blue/green This wire is only required on the V-10 Gas engine. ACCESSORY RED / black Ignition harness ACCESSORY 2 Gray / YELLOW Ignition harness STARTER Dk.green Ignition harness KEY SENSE BLACK/ pink In airbag plug on right side of st. column TACH SIGNAL Use an injector DIESEL TACH SIGNAL GREEN / WHITE SEE NOTES Look below the relay box under the dash for a large loomed harness. There are some wires taped to the harness terminated with heat shrink tubing. You will find the GREEN / WHITE among these wires. LOCK WHITE/ red In harness above gas pedal On 4 door models, these wire are negative trigger. Vehicles with no keyless entry, colors are Pink / YELLOW for lock and Pink/green for unlock in 5-wire reverse polarity. They will be found in either kickpanel. UNLOCK BLACK/ white In harness above gas pedal On 4 door models, these wire are negative trigger. Vehicles with no keyless entry, colors are Pink / YELLOW for lock and Pink/green for unlock in 5-wire reverse polarity. They will be found in either kickpanel. DRIVER LOCK MOTOR Pink/black In harness above gas pedal DRIVER UNLOCK MOTOR RED / orange In harness above gas pedal PASSENGER UNLOCK MOTOR Pink/orange In harness above gas pedal GLO-PLUG SIGNAL DATA ONLY USE DELAY TIMER DOORPIN BLACK/ blue Above parking brake in DKP The vehicle's computer sends out diagnostic pulses on this wire every 15-20 minutes. This may cause an after-market alarm to false. It is suggested that you add a relay to this wire when connecting to an alarm system. See the appropriate diagram for exact wiring instructions. FACTORY ARM Yellow/black Above parking brake in DKP This is the driver's doorpin wire. Pulse this wire at the same time as lock to arm the factory alarm. FACTORY DISARM Dk.GREEN/ purple In harness above gas pedal BRAKESWITCH Green At switch above brake pedal PARKLIGHTS Brown At light switch harness HAND BRAKE Lt.GREEN/ red At plug above handbrake lever HORN Dk.blue In airbag plug on right side of st. column
Dec 25, 2017 | Cars & Trucks
Replacing fan. Wires from ceiling are grey pink white & bare copper. Wired to light switch. What wire connects to what? Ok so we just bought the place. The painters removed the old fans that had no...
Sounds like you have two hot wires. Just need to find out which wire goes to the wall switch. Try gray to black from fan,pink to black/white wire.white to white & green to green. If this doesn't work swich the pink & gray wires.
Feb 03, 2013 | Dryers
I need to know where 3 wires connect on a goodman pc036-1b rev e package unit air condtioner and central heat system.
Contact Goodman directly to request a wiring diagram for model pc036-1b, rev. e. It is important to specify rev. e.
Nov 01, 2017 | Heating & Cooling
I am installing a CD player in a 2004 Nissan Sentra and I need to find the wiring diagram to show me how. Can you help?
see connection colors below and let me know if you have questions.
2004 Nissan Sentra wire colors aftermarket radio wire colors
Car Radio Constant 12v+ Wire: Pink, yellow
Car Radio Switched 12v+ Wire: Blue, red
Car Radio Ground Wire: Gray, black
Car Radio Illumination Wire: Red/Green, N/A (tape off factory wire)
Car Stereo Dimmer Wire: Red/Yellow, N/A (tape off factory wire)
there is no factory amplifier wire, blue (tape off radio wire)
Left Front Speaker Positive Wire (+): Pink, white
Left Front Speaker Negative Wire (-): Blue, white/black
Right Front Speaker Positive Wire (+): White, gray
Right Front Speaker Negative Wire (-): Black, gray/black
Left Rear Speaker Positive Wire (+): Light Green, green
Left Rear Speaker Negative Wire (-): Violet, green/black
Right Rear Speaker Positive Wire (+): Blue, violet
Right Rear Speaker Negative Wire (-): Pink, violet/black
Aug 21, 2011 | Car Audio & Video
There are four differently color coded cables coming from my 2002 daewoo lanos that WOULD connect to a 4 wire heated downstream oxygen sensor but the connector has been severed and is nowhere to be found. ...
red/white is 12v goes to pink (12 v for heater). black goes to black (ground)..... brown/white goes to brown/white (signal from ecm) purple/white to purple/white for (signal to ecm).
Jun 12, 2010 | Daewoo Lanos Cars & Trucks
Need to locate signal light flasher 2001 dodge intrepid
If you mean the flasher, which makes the turn signals and hazards to blink, then...
It's a combo flasher which operates both the turn signals and the hazard lights. To access the combo flasher with ease remove the drivers knee bolster and then remove the brake release cable end from the handles notch, then disconnect the harness from the trunk release switch. Next there will be a reinforcement panel, remove that as well. Finally locate and replace the combo flasher from behind this panel. It is a black box that has a harness connected to it with a pink wire, a black and yellow wire, a red wire, a dark blue and pink wire, and finally a black wire. To help locate the flasher either turn the turn signal on or apply the hazards and listen for its location.
Apr 17, 2009 | 2003 Dodge Intrepid
Can not find turn flasher on 1999 dodge intrepid
Right, it is a combo flasher which operates both the turn signals and the hazard lights. To access the combo flasher with ease remove the drivers knee bolster and then remove the brake release cable end from the handles notch, then disconnect the harness from the trunk release switch. Next there will be a reinforcement panel, remove that as well. Finally locate and replace the combo flasher from behind this panel. It is a black box that has a harness connected to it with a pink wire, a black and yellow wire, a red wire, a dark blue and pink wire, and finally a black wire. To help locate the flasher either turn the turn signal on or apply the hazards and listen for its location.
Mar 03, 2009 | 2003 Dodge Intrepid
I doesn't work
gound pink wire in order to make video play
Feb 12, 2009 | Pyle PLTS76U Car DVD Player
CDA-9815
dont connect the pink/black wire just trouble these are signal interupt lead wires cap and tape off and the orange wire is the dimmer wire for when you turn your lights on and off
May 06, 2008 | Alpine CDA-9815 CD Player
Alpine IDA-x100 and KCE-300BT
Hi
what you need to do is to start off make sure both units are powered from the same point you will see why below. Make sure you connect the Audio Interrupt out lead (pink/black) from the 300bt to the x001 INT IN pink/black wire
Go to general settings turn off the int mute setting, (you proberly have it turned off already the reason your not seeing it) try resetting it using the small button behind the face plate. This should allow you to see the int mute setting. Go to the bluetooth settings and select adaptor. Disconnect power to both units. ( you will need to re apply power to both units at the same time) after around 10mins. when you re-connect the power make sure ALL bluetooth units around the car are turned off. You should now have success in pairing the phone and having the X001 recognise the 300 bt.
Feb 20, 2008 | Car Audio & Video
Alpine CDA-9827 CD Player Logo
359 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
