Question about Denon AVR-2803 Receiver
Denon Avr 2803
Picture on TV has no color, black and white only when run through the receiver.  Both DSS and DVD.  How do you get it back to color picture?
  • Jimmy 1 Oct 15, 2007
    Wife was dusting unit when problem occured.
  • pcguy71 Jan 13, 2008
    I have the Denon AVR1707 and now whatever I plug into the TV S-Video input port outputs only black and white video signal. It was fine for a year. If I take the DVD S-Video cable (which still shows in colour) and plug into the TV S-Video input port, the output is black and white. The DVD and VCR S-Video ports still work fine. There's no loose connections, it's not the cables or the input source. It seems like it's an internal problem with the receiver but I thought I'd check the web first to see if there's any quick fix....
  • 93 Answers
Could be bad connection. Try to tight connection cables on receiver and TV.
Posted on Oct 15, 2007
I can't seem to get the tuner to work on my Denon AVR 2803 receiver.
It can't hurt.
You will lose all your settings though. So you'll have to set the amp up again from scratch.
Before you do initialise, let's just check.... You plugged in a FM or AM aerial, right?
Sep 13, 2014 | Denon AVR-2803 Receiver
After a power outage my denon 2803 receiver will not turn on.
Hello. First unplug and replug in your receivers. When you push the power button, you should hear 1 click. Within 5 seconds, you should hear a second click. Can you please tell me the results?
Thank you.
Sep 15, 2012 | Denon AVR-2803 Receiver
I can't get a menu screen up on my Denon AVR 2803.
Did someone turn the OSD off on the menu? You might try a reset of the receiver. This would be in your manual.
Aug 23, 2012 | Denon Avr 2803 7.1 Channel 875 Watt...
I've got a Denon AVR 2803 surround sound system. I recently purchased and Xbox 360 and haven't had any success with installing it. Last night I removed my DVD player from my TV and installed the Xbox and...
Hi, and yes there is hope, there's a saying that when something is tedious and or boring to read "it reads like stereo instructions ".The first thing to make sure of is you have a rather stiff connecting cable called a "TOSLINK" cable this has squarish ends and plugs into the "DIGITAL AUDIO OUTPUT" of the x-box 360 and then plug the other end into whichever input your using for the x-box. A dead giveaway to the jack to use on x-box is that it may actually be lit up red while playing. it also may be labeled "PCM/LPCM" versus digital audio. Anyway that should get you your surround sound on your stereo. Thanks for choosing FixYa, Let us know if there's anything else we can help with,and good luck, Prodzilla
Apr 13, 2011 | Denon AVR-2803 Receiver
Hi, just connected a Blu Ray player to my sytem. I connected the player via HDMI direct to the TV and the audio output direct into Optical 2 on the Denon. Problem is that there is no sound. Also...
We can't make assumptions about proper and complete setup if you don't explicitly mention the steps involved, so... did you assign and select the digital inputs properly?
Page 23 etc
BTW: I concur with your decision to send the video directly to the TV from the BD even though Denon and others expect it to make a hop through the receiver first.
Get into your BD and find its audio out setup. Make sure its settings for digital audio output bit rates, speaker presence, type, size, distance and bass-handling are set correctly.
Jan 30, 2011 | Denon AVR-2803 Receiver
Denon AVR-2807 HDMI out signal
i seem to have a similar problem with my Denon AVR 4310CI . The output to my LCD TV just went green . On checking with some people , they suggested resetting . it didnt work . Any probable reasons
Feb 06, 2010 | Denon AVR-2805 Receiver
No picture
the reason you can't get a signal is the denon 1708 will not pass the 1080p, switch the DVD output res. to 1080i or 720p and it will work
Feb 02, 2009 | Denon AVR-1708 Receiver
Black & White picture
reset the amp by pulling the plug leave for 1 hour disconect the cable box thats the cause the cable box is putting votage into the amp. if the amp is still the same the cable box has detroyed your amp abit of advice these cable boxes are bad news they destroy lots of peoples gear stear clear . any way you amp probably has burnt components loads to fix sorry i have seen this so many times over the years regards kirk ps it not a setting
Sep 01, 2008 | Denon AVR-3806 Receiver
Video performance question
The 2801 (I used to have a 2803) is just an AV receiver, so it doesn't do any video processing.
If you get a DVD player with HDMI or DVI output, you'll be better off doing what you said - bypass the receiver for video and connecting the video directly to your TV, and the audio to your receiver.
It makes things less convenient since you can't switch inputs only with the receiver's remote, but you'll get a much better picture.
If you really need to control the whole system with a single remote, consider getting a Logitech Harmony remote or something similar. They're very convenient.
Apr 05, 2008 | Denon AVR-2801 Receiver
Denon 1905/785 - lost color feeding tv
Your Denon 1905 might be setting it under HDMI for video source.You need to correct it by going to menu,as you browse through the setting,you should able to find video select or video output. It is on the manual.
Remember,you need to run a composite video cable from the video output behind your receiver to your TV video input for this step.
Mar 09, 2008 | Denon AVR-2807 Receiver
Denon AVR-2803 Receiver Logo
197 people viewed this question
Top Denon Audio Players & Recorders Experts
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
