E4 message on Singer Fashion Mate 7256
Contact singer support and ask them, here is the link
Customer Support
SOURCE: Singer Fashion Mate digital error E4.
E4 error.its the bobbin shaft error.first try to clean the bobbin case then turn the machine on for some minutes then turn on and check out.if still the same error then
Check the bobbin winder shaft. If it is pushed over when you try to run the machine you may get the error.adjust it properly.and check out.
if still the same problem the bobbin shaft needs to be replaced.as its slipping out.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
