Question about Brother MFC-5460CN InkJet Printer
Line on copy
Brother MFC-5460 has a heavy line line on copies fed thru the AFC only.  How do I fix this?
    Champion:
  • 214 Answers
In the ADF there should be a glass strip where the sheet is scanned. Not sure on Brother but you should be able to open and lift the top out of the way. Clean the glass with cloth and water- Windex. Should fix that problem
Posted on May 14, 2009
  • jimmythekid Aug 11, 2011
    On the Brother MFC-5460CN (or any other scanner with ADF), lift the top back and look for the small glass strip. It is to the left of the large glass plate. The smaller one is the reader for the ADF. The strip is about 3/4 inch and is as wide as the larger glass plate. I cleaned the large plate first, not seeing the smaller plate and still had the vertical line. I then found the smaller glass plate, cleaned it, and the vertical line went away. The trick is to clean both plates. Hope this helps.
I get a black line when scanning, ( not when printing)how do i fix it
This is commonly caused by a mark on the scanner plate. If you place your document to scan on the scanner plate (Lift the lid and place it on the glass plate) and scan or copy the document does it come out clean? If you feed the document through the Auto Document Feeder doe the line appear?
If when place on the plate it is clean but fed through the ADF there is a line, then when you lift the lid on the scanner you will see a narrow glass plate at the end (Normally the left end) of the scanner plate. Give this glass a clean and your mark will go away.
If the scan or copy is lined when using the Flatbed scanner and the ADF then the problem will be in the scanner lamp which will be probably uneconomical to fix.
Oct 09, 2014 | Brother MFC 6490CW InkJet Printer
When i use the automatic data feeder, i get a line on my copies
Hi Donald,
I suggest You Go to Official Brother Printer Page For You Brother Printer Problem On Below Brother forum URL Link:
host220 brother com In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Brother Printer Support
Nov 15, 2013 | Brother Network-Ready All-In-One Laser...
Brother MFC-7820N Printer--vertical lines
You need to clean the scanner glass. Also known as the strip glass. It is a 1 inch wide strip of glass that runs from the front to the back. Your documents pass over this glass when they are scanned. Some of the wax crayon probably smeared off onto the glass and now when you scan the scanner sees these marks as stationary and thus records them as solid lines. Just look into the scanner section where your documents are fed in or depending on model, some are just to the left of the large original glass.
Good Luck and thank you for using Fixya.
Feb 25, 2010 | Brother MFC-7820N Printer
Black line on copies produced
Take a look at your drum. If there's a green tab on the exterior, move that all the way to the left. That should get rid of the black line.
Jul 16, 2009 | Brother MFC-7440N Laser Printer
Line when we fax or make copies from the top feed
clean the narrow strip of glass to the left of the large glass.
razors
Apr 10, 2009 | Brother MFC-9420CN All-In-One Laser...
Mfc-7420 Black Line horizontal across paper in 3 places
try moving the small blue slider on top of the drum cartridge side to side 10 times.
Mar 10, 2009 | Brother MFC 7420 All-In-One Laser Printer
BROTHER MFC 7420 PRINTER SOLID VERTICAL LINE...
Open te lid and look at the glass. You have dirt or white-out or something on the thin strip of glass to the left. Clean that glass!
Oct 07, 2008 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 5840-CN - line appearing on copies
I have no idea whats happening here.. But it sounds a bit like when he prints from the pc, it uses a different paper stock? Could it be the paper from a direct copy is being used from a different source or tray? Or maybe it's like a 'draft' copy?
I know thats not much help, but if you want, I can spend some time investigatiing this.. But as over a hundred people have never bothered to reply to my posts, I'm a bit reluctant to waste time, unless it's appreciated.. Let me know if you really want to get involved at a deeper level..
May 22, 2008 | Brother MFC-5840CN All-In-One InkJet...
Thick Black Line on my copies and faxes
Can't image it being anything but scan glass, if prints are fine, are you sure you cleaning scan glass(inside of where originals are fed)?
If so then scanner lamp faulty, but I've never come across it myself on this model.
Oct 26, 2007 | Brother MFC 8500 All-In-One Laser Printer
Print Problem - vertical lines
If the problem only occurs when using the document feeder, the problem is not usually caused by the drum. When using the document feeder, try to notice where the scanner (the light assembly under your scan glass)stops just before the paper is being fed. Some multifunction machines have a small piece of glass that is separate from the large scan glass and the scanner assembly stays parked underneith it as the original is being fed over it. Most likely there is something on the glass where the scanner parks as originals are being fed thru the feeder. When putting your original on the large scan glass to copy, the mark on the glass will only show as a spot, but will show as a vertical line thru the whole copy when using the feeder.
Feb 23, 2007 | Brother MFC-7820N Laser Printer
Brother MFC-5460CN InkJet Printer Logo
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
