Question about Asko W6021 Front Load Washer
Asko w6021 washer leaves clothes damp and often stops mid cycle
Any thoughts on what is going on? The pump is definately working, but even after the 1200 rpm spin cycle the clothes are pretty wet. Could there be a problem with a water sensor?
Also, very often the machine stops mid cycle and the door won't open. It will start up again right after.
  • barbaracasti May 14, 2009
    Thank you so much for your reply. Would those things be true on a front-loader? I can see that the machine is spinning like mad, as it should. The motor appears to be fine, still sounds like a jet plane take off. And even though the pump turns on and drains out most of the water, a little is always left to spin around in the drum. Weird.
Rodney,
Just wanted to give you some feedback. You responded to my problem this morning and suggested that I replace my heating element in our dryer. You were right on the money and we are up and running and the wife is happy!
Thank you and much appreciated!
Jeff
Posted on May 14, 2009
  • 47 Answers
I AM NOT MUCH OF A MECHANIC, BUT I DO KNOW THAT IF WATER DOESN'T SPIN OUT OF THE WASHER, IT COULD BE THAT YOUR BELT IS BROKEN OR YOU NEED TO REPLACE THE MOTOR COUPLING.
Posted on May 13, 2009
  • CoolRod41 May 14, 2009
    BARBARA,
    IT COULD BE YOUR WATER SENSOR. I AM NOT A MECHANIC, BUT IT COULD BE THE WATER SENSOR. CALL YOUR LOCAL REPAIRMAN AND SEE IF HE CAN HELP YA.
    BEST REGARDS,
    RODNEY
My Asko washing machine wont go into spin cycle it just keeps on washing after 3 hours I had to turn it off now what
call a technician in
the problem is most likely in the program board not progressing the wash cycle
Jul 12, 2016 | Asko W6021 Front Load Washer
Fault 02
Hi
Fault code 2 indicates "Water level too high "
Please look for the following causes:
· Plugged/Bad water pump
· Faulty water valve
If you are not able to check these, it may be necessary to call for a technician. Always be careful of electricity!
Jan 02, 2008 | Asko W6021 Front Load Washer
I have an ASKO W6021 Quattro 1200 RPM. It does not complete the wash cycle. If I turn the know to rinse, it does rinse and completes. I tried it without any clothes in it and it does the same thing. I also...
Check that the cold water is turned on. The washing machine uses cold water to rinse, and if the cold water is not on, unit will end without completing cycle.
Mar 14, 2011 | Asko W6021 Front Load Washer
My Asko Front load washer model W6021 Prewash
hi you need to replace the inlet valve,take off the top panel and you will see the valve behind the soap drawer with the black hoses.you can get a book from asko.com.au
Jun 15, 2010 | Asko W6021 Front Load Washer
My Asko washer does not complete the wash cycle. It does not rinse the clothes.
Hi, With the Asko there are several possible things that can interupt the cycle either during wash or drain/spin. Have you checked the pump insert/button trap for debris or obstruction of any kind ? ( below main door to the left ) Are you using "he" ( lo-sudsing ) detergent ? Does the machine provide any error code, i.e. If it's a mechanical timer model does it stop at "C" or "S" or if electronic a symbol in the display ? Will it complete a cycle without any items in the basket ( empty ) ? Will the unit rorate in both directions and will it spin if you try both parts of that specific cycle ? This will help determine if the problem is with the drive motor brushes. Let me know, any answer you can provide here will put us closer to a solution to your washer problem. If you could confirm the model number that would be very helpful too. Thanks and good luck, I will try and reply as soon as I see you've posted a response. Macmarkus :)
Apr 08, 2010 | Asko W6021 Front Load Washer
I have an asko 11505 clothes washer. For some reason, it is not going through all of the spinning cycle, it spins for a short time, then stops abrutely. I cleaned the coin stop, cleaned out all water...
My Asko 11505 washer fills only a little water then shuts off. If I drain the washer with the drain hose from under the machine, then the machine will start up and fill enough water to fill the hose again, then shut off.
Oct 19, 2009 | Asko Washing Machines
Asko Washer W6021 Problem
CHECK THE BRUSHES ON THE MOTOR, FOR BEING WORN DOWN!
REGARDS........TREVOR. FLEETWOOD UK.
Mar 09, 2009 | Asko W6021 Front Load Washer
My ASKO washing machine will not go through its regular cycle
it may need the carbons in the motor replaced part no 8801195, is it pumping out the water if it doesnt the door wont release.
Sep 06, 2008 | Asko W6021 Front Load Washer
Asko W6021 Front Load Washer Logo
617 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
