Question about Hitachi 51F500 51" Rear Projection HDTV-Ready Television
Double images double colored images (one on top of the other)i.e. a persons face will look normal but underneath shows a red reflection or it will show the name of a program and then have the same name underneath but in red or going up in an angle.
  • Anonymous May 22, 2009
    I have a Sony KP-41S3U and half the screen is normal and the other half totally distorted with bright red and green reflections. It has been a brilliant TV ~ is it a total right off or can it be remedied at a reasonable cost?
  • 431 Answers
Hi .. This sounds like a convergence problem have you got an auto convergence setting in your menu please check .
This problem usually only appears on CRT type projectors ,and if your set is an older one or used quite a lot then it could be assign of low tube emissions meaning the crt are wearing out ( a bit like an lcd model when the bulb goes ) or just that you need an engineer to reset the convergence or maybe even fix a few dry joints on the scan coils .. if the tubes are low engineers have a device called a rejuvinator that gives them a bit more life if they are not too far gone so either wy I think you need to contact a local engineer to sort this one out for you .... regards Vortash
Posted on May 13, 2009
Three men are standing at a border and the last men can only see the two men standing at front and the second last men can see only the first and first cant see anybody standing then a commander brings...
The first man is facing something reflective, like water, so he can see his own image, but not that of the two people standing in line right behind him.
Sep 28, 2010 | Computers & Internet
The picture is showing a double image and is distored.
The problem you are refering to is more than likely a convergence problem. The convergence circuit in your tv is controlled by an IC (integrated circuit) stk392-110 and it makes the 3 colors (red, blue, green) line up/converge together to create a clear picture. You'll know when this part needs to be replaced because the picture you see is 3d looking and possibly bowed on the top or bottom or on the sides in any or all 3 colors.
Jan 24, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Red color on top
Sounds like you need your convergence amplifiers replaced. Approx. $200-$300 depending on repair shop,
Jul 08, 2009 | Samsung HCM5525W 55" Rear Projection...
Double images
hi, convergence circuit has failed, will need a tech or someone very proficient at solder work to replace your convergence ic`s & possible support parts, if your that person re-post and i`ll try to help ya, video-tek
Jun 06, 2009 | Hitachi 57F500 57" Rear Projection...
Model# AV48WP30 Picture show double vision. Colors cant be adjus
you need to replace the convergence ICs and associated resistors you can get the repair kit at the following link for your model which contains the two ICs and all the feed resistors plus step by step instructions with detailed photos how to do the repair. Heres the link to the kit for your model.
http://servicemanuals.vstore.ca/product_info.php/pName/av48wp30-convergence-repair-kit/cName/convergence-repair-kits
Mar 05, 2009 | JVC AV-48WP30 48" Rear Projection...
Double Image Red and Green
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Feb 08, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
TV has shadowing double images/colors are uneven
It sounds like the problem one can have from a weak signal. This kind of problem is normally associated with the use of an antenna which is receiving the primary signal, then a secondary one that is being reflected to you from a distance; an echo. The first signal is the one you are seeing best, then from some distance, the same signal is being sent back to you with a time delay of a few microseconds causing a shift in the images. A repositioning of the antenna orientation is the only solution.
If you are on cable, you will need to call them and holler about the signal quality. Thinking this through, I don't think this can happen when receiving satellite signals since the antenna is pointed toward the sky and the chances of any noticeable reflection are close to nil.
Nov 26, 2008 | Akai LCT2785TA 27 in. LCD Television
I have a HP laserjet P2015 printer. Please could you tell me in what part of the paper container do I put envelopes, to have an address printed on them.
http://h71016.www7.hp.com/html/interactive/lj2015/model.html?jumpid=re_r2515_3d/ProdCat/IPG/VAcontent/BlackWhitePrinters/LaserJetP2015/3D|ProdPage|flash&clang=enna
plz paste the link into your browser and you will find the required information
Jun 24, 2008 | Office Equipment & Supplies
When using flash the reflection have a pink tint
Lens block assy may be defactive. Consult Sony service center
Jan 16, 2007 | Sony Cyber-Shot DSC-F717 Digital Camera
Hitachi 51F500 51" Rear Projection HDTV-Ready Television Logo
369 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
