Question about Smeg FME24X Microwave Oven
Smeg SA987CX error message E plus a high pitched continuous sound. Need to disconnect power to stop. This only seems to happen when I microwave. Does anyone know what is wrong and how to fix.
  • 431 Answers
Sounds like the Magnetron in your Microwave has shorted out causing it to scream .. lol own purely none technical term .
Its actually a harmonic caused by the magnetron's anode resonating , usual fault caused by breakdown of the filaments , it is pretty much had it a new magnetron would cost almost as much as a new microwave . it may just possibly be the power supply with an oscillator fault but again that is a symptom of a serious power drain problem that also points to the mag ... sorry Regards Vortash
Posted on May 13, 2009
Why does it display error 2 after five seconds?
What is the model? On this link for their brand error 2 means temperature higher than expected inside the oven or the temperature sensor is not working right.
Smeg SA987CX Installation And Operating Instructions Manual To Stop The...
Nov 26, 2015 | Microwave Ovens
Easy to fix a microwave that's not heating - or throw away?
They are relatively easy to fix, but perhaps, not cost-effective. It depends on the age. I never bother with anything over 8 years old unless it's a very inexpensive fix. If the high voltage rectifier is bad, I'd fix. If the magnetron is bad, I would not fix. Other possible causes of the problem exist, too.
May 05, 2014 | Microwave Ovens
Why does my SMEG microwave keep tripping the main power box
There is a short in the microwave oven, possible causes, the power transformer, a shorted magnetron, cracked high voltage diode, and finally a shorted high voltage capacitor.
Mar 18, 2012 | Microwave Ovens
My Microwave continues to run unless door is open. I do not think it is heating though when I shut the door. When I close the door and push buttons nothing happens. I get a high pitched sound when I...
The high pitch sound to me may be coming from the speaker on the main circuit board. Try to unplug for a few minutes, reset clock time and then try again. If same issue, may need new PC board. When you say Microwave continues to run are you meaning the Turntable is turning and the fan running?? Or is it just timing down. Almost never does it actually keep heating. On GE units I mostly find bad door switches will cause a back feed and make the tray turn and the cooling fan for the mag to run. To see if that is the problem You have to look at the door switches behind the front panel on the left side and see if any of them have any browned connections on the terminals where they push ontl the back of the switch. That will cause the fan and turntable toi run, but wouldnt cause a high pitch squeal. These companies use switches wtih small 3/16 terminals that dont give a good enough grab on the switch, they get loose and hot and make the switch go bad. I replace that switch with a switch with 1/4 inch terminals and runa short section of Hi temp wite to it and it wont go bad again. Just cheaply made!! Also I guess the squeal could come from the turntable motor area. So By fixing the switch problem it could fix your squeal. With nothing else running you may be able to hear motor and coupling noise you couldnt hear before.
Aug 17, 2017 | GE XL1800 1100 Watts Microwave Oven
Buzzing sound when the vent fan is turned on. Sound is high pitched, and I can't tell if it's coming from the top or bottom. Any suggestions?
I don't know if this applies in your case but I have had fans with metal blades that would resonate with a high pitched ringing sound. It may also be that a blade is slightly contacting a metalic mesh filter cartridge.
Jun 25, 2009 | GE JVM1860 Microwave Oven
I have recently been given a Smeg microwave, product No, SA987CX, but I have no instruction manual and would like to know where I can find one.
I have looked and I can't find one either. You can mail Smeg in the UK at support@smeg-service.co.uk They may be able to point you in the right direction.
Mar 01, 2009 | Smeg FME24X Microwave Oven
Works - but the sound has changed
Possibly, the "fault" was the buzzing in the first place! Buzzing is usually a cabinet vibration caused by magnetic fields from the "gubbins". If the buzzing should occur again, try pushing/ pulling/ poking the cabinet while the oven is running, you may find a position that causes the buzz to stop.
Another possibility is you previously had something else placed in close proximity to the oven.
If a rattling cabinet is the problem, either try to reposition something, or just ignore it!
Apr 29, 2008 | Maytag MMV4205 Microwave Oven
High pitched hum/buzz
By high-pitched, you mean it is not that same frequency as when it's cooking? Is the tone near or the same as the beep you hear when you press a key? Please post a little more information so we can help better.
Nov 27, 2006 | Kenmore 66469 / 66462 / 66464 Microwave...
Smeg FME24X Microwave Oven Logo
349 people viewed this question
Top Smeg Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Smeg Microwave Oven Expert? Answer questions, earn points and help others
